How to Make Wired Speakers Wireless?
416 viewsSpeakers
To get your wired speakers grooving wirelessly, you’ve got a couple of neat tricks up your sleeve. Let’s dive right in and see how you can make the magic happen.
First off, you’ve got choices. Two paths to consider:
  1. Wireless Music Streamer: This handy device piggybacks on your existing amplifier or receiver.
  2. Streaming Amplifier: Swap out your current setup for an amplifier packed with streaming goodies.
Alright, so let’s break it down step-by-step and get your speakers singing:
1. Scope Out Your Setup: Are you a gadget lover getting an external streamer, or crossing your fingers for a brand new streaming amplifier? You’ll need to figure this out.
  • With a Wireless Music Streamer, devices like the Sonos Port or the WiiM Pro are your buddies. They hook up to your amplifier almost effortlessly with stereo RCA, optical, or coaxial cables.
  • Opting for a Streaming Amplifier like the Sonos Amp or SVS Prime Wireless Pro SoundBase means you’re getting right into the action by connecting directly to your speakers.
2. Gather Your Gear: Make sure your Wi-Fi can handle a party. Get your smartphone or tablet ready for setup, and grab those analog stereo RCA cables or speaker cables, depending on your choice.
3. If You’re Rolling with a Wireless Music Streamer:
  1. Connect Cables: Plug those RCA cables into the amplifier input from your streamer. If you’re feeling digital, go for optical or coaxial connections.
  2. Download Control App: Hop onto your app store and grab the control app for your streamer. It’ll guide you through connecting to Wi-Fi—just make sure you remember your password.
  3. Configure Music Services: Dive into the app and log in to all your favorite music services. You’ll be spinning tunes in no time.
  4. Kick Back and Play Music: With everything set up, start your listening session—wave goodbye to those pesky wires!
4. Connecting a Streaming Amplifier:
  1. Connect Speakers: This one’s straightforward—attach your speakers directly using speaker cables, making sure everything’s in sync with the positive and negative terminals.
  2. Download Control App: Just like before, download the app and connect to your Wi-Fi network by following the instructions.
  3. Configure Music Services: Log into those music apps and prepare for an endless stream of tunes.
  4. Rock Out Wirelessly: Your wired speakers have officially gone wireless, so let the vibe session commence!
A Couple More Things to Keep in Mind:
  • Audio Quality: When picking between analog and digital connections, think about the DAC capabilities of your devices—they’re key for killer sound quality.
  • Multi-Room Jamming: Many of these solutions let you sync up multiple speakers for a sound fiesta across your home.
  • Bluetooth vs Wi-Fi: While Bluetooth is a nifty tool, Wi-Fi will usually give you better sound quality and range without the usual Bluetooth hiccups.
By focusing on what you really want and being smart with your setup, you can turn those wired speakers into a wireless wonderland, all without losing your vibe.
So, you’re tired of those tangled cables tripping you up, but you can’t trade in your trusty wired speakers for some fancy new wireless ones just yet. No sweat! Let’s jump into how you can give your speakers a wireless makeover, because honestly, who doesn’t love a bit of freedom when setting up their sound system?
Ways to Cut the Cord
  1. Bluetooth Adapters
    • What’s it all about: Ditching the cables for short-range wireless audio.
    • The Magic Behind It: Pop a Bluetooth receiver onto your speaker’s input, and voila, it’s ready to flirt with your smartphone!
    • Steps:
      • Pick up a Bluetooth adapter (like the TaoTronics TT-BA07).
      • Get it cozy with the speaker using a 3.5mm/RCA cable.
      • Give it some juice via USB or let it go rogue on battery.
      • Pair it up through your phone’s Bluetooth settings.
    • The Catch: You might need to dance around your room to stay connected—there’s a range limit, and it’s not the greatest for keeping video and sound in sync.
  2. Wi-Fi Audio Systems
    • What’s the Big Deal: Streaming tunes without compression, even playing across multiple rooms. Perfect for all you audiophiles out there.
    • Making it Work: Let a Wi-Fi transmitter lead the way, turning your speakers into part of a home-wide orchestra.
    • Steps:
      • Grab a Wi-Fi audio transmitter (like the Arylic A50).
      • Hook it to your router via Ethernet or Wi-Fi.
      • Connect it to the speaker with some classic cables.
      • Use the Arylic Up2Stream app to call the shots.
    • Why it Rocks: Unbeatable sound quality and it keeps harmony across different rooms.
  3. Wireless Audio Transmitters
    • What’s Going On: Spread high-quality sound far and wide, especially for home theaters.
    • The Trick: Works over radio frequencies, so no sound quality issues here.
    • Steps:
      • Link the transmitter with your sound source (TV, PC, whatever).
      • Sit the receiver on your wired speaker.
      • Power them up and get them talking by tuning the frequency.
    • Perfect For: When Wi-Fi and Bluetooth give you the cold shoulder.
  4. Smart Audio Hubs
    • What They Do: Make your speakers chat with Alexa, Google Assistant, and other smart buddies.
    • How to Pull It Off: Devices like Echo Link are your new best friends in turning speakers smart.
    • Steps:
      • Connect the hub to the speaker via aux/optical cable.
      • Set up the hub using its app.
      • Just tell it what music to play and watch the magic happen.
  • Latency: Bluetooth isn’t perfect—grab an aptX Low Latency device if video sync is crucial.
  • Power Supply: Make sure your wireless gear doesn’t run out of juice mid-song.
  • Compatibility: Double-check connector types before you buy anything.
  • Sound Quality: Wi-Fi generally beats Bluetooth hands down when purists demand audio fidelity.
Stepping It Up: Multi-Room Amplifiers
For the big leagues, consider amplifiers like the Arylic S10 Pro. They toss wireless streaming into the mix while supporting your trusty wired speakers all at once. They can even fine-tune the sound to your liking via app control.
Why Bother Making Wired Speakers Wireless?
Here’s the bottom line: Going wireless gives you more options to arrange your speakers without shelling out tons of cash for new gear. Plus, it’s a nifty way to merge old-school tech with the latest trends—like mixing wired subwoofers with wireless satellites. So why not give it a whirl?
Pro Tip: Try a cheaper Bluetooth option first to test the waters, then you can decide if splurging on Wi-Fi systems is the way to go.
Turning your wired speakers into wireless ones can be done pretty easily with a few handy tricks! Here’s what you can try:
First up, get yourself a wireless speaker kit. These nifty kits come with a transmitter and receiver. To set it up, plug the transmitter into your audio source like your TV or stereo using RCA or AUX cables, then wire your speakers up to the receiver. Sync ‘em together, and boom—you’re ready to vibe to your tunes without the tangled mess.
Next, consider Bluetooth amplifiers if your speakers don’t have their own amp. Here’s the deal: buy a Bluetooth amplifier that matches your speaker’s power needs. Hook up your speakers to this gizmo using some speaker wire. Pair your phone or tablet with the amplifier, and you’re all set to stream your favorite playlists directly to your speakers wirelessly.
There’s also the option of using a wireless audio transmitter and receiver system. This setup often brings in clearer sound and some cool features. Connect a transmitter to your audio source, and the receiver to your speaker or amplifier. Make sure they’re on the same frequency, and you’ll enjoy crisp wireless sound with hardly any interference.
Lastly, if your place is hooked up with Wi-Fi, think about getting Wi-Fi audio receivers. These are perfect for linking your wired speakers into a wireless world. Get the receiver connected to your speakers or stereo amplifier, hitch it to your home Wi-Fi, and stream away using a compatible app—it’s like magic!
Honestly, converting your wired speakers is a breeze and opens up a world of convenience. With these tricks, you’re ready to enjoy seamless sound without the hassle of cables.
