How to Make Wired Printer to Wireless?
312 viewsPrinters
To turn your trusty wired printer into a wireless superhero, there are a few tricks up your sleeve. It all depends on what your printer can do and how your home network is set up. Let’s dive into the options and see how you can free your printer from those cables.
Method 1: Hook Up Your Printer to Your Router’s USB
If your router has a USB port, you’re already halfway there. It’s like giving your printer a direct line to Wi-Fi goodness. Here’s the scoop:
  1. Check Router Compatibility: First, make sure your router’s USB port is good to go for printer sharing.
  2. Connect the Printer: Just plug the printer’s USB cable into the router.
  3. Power Up: Flip on the power for both the router and the printer.
  4. Router Setup: Jump onto your router’s settings, usually through its IP address, and find anything like “Printer Server” or “USB Settings.” Enable those bad boys.
  5. Add Your Printer:
    • For Windows: Just mosey on over to Settings, then Devices, then Printers & Scanners, and click on “Add a Printer or Scanner.”
    • For macOS: Head into System Preferences, then Printers & Scanners, and hit the “+” sign to add it.
With everything set up, you’re ready to print wirelessly from any device connected to your Wi-Fi network. Magic, right?
Method 2: Ethernet Connection
If your printer’s got an Ethernet port but no wireless flair, you can still get it on the network:
  1. Plug It In: Connect one end of an Ethernet cable to the printer and the other to a LAN port on your router.
  2. Turn On Devices: Make sure your trusty devices are powered up and ready.
  3. Network Configuration: Get into your printer’s menu via its control panel and make sure network printing is enabled.
  4. Add Your Printer: Same dance as Method 1 to get your devices to recognize the printer.
This isn’t true wireless, but hey, it gets the job done without needing a direct line from your device each time.
Method 3: Go Wireless with an Adapter
If you’re out of options so far, don’t worry—wireless adapters can save the day:
  1. Grab an Adapter: Find a wireless print server or adapter that jives with your printer.
  2. Get It Connected: Follow the instructions to connect it via USB or Ethernet.
  3. Wireless Network Setup: Use its software or web interface to connect the adapter to your Wi-Fi network.
  4. Add Your Printer: Follow the steps again to get your device connected.
This route can be hit or miss, especially if your gear is more vintage.
Method 4: Dedicated Print Server
Another ace in the hole is using a dedicated print server:
  1. Buy a Print Server: Pick one that can connect with the ports your printer has.
  2. Hook It Up: Plug the print server into the printer—USB if it has it, otherwise similar setup as before.
  3. Network Settings: Fire up the manual and follow the setup steps.
  4. Add Your Printer: Make sure it’s now visible over Wi-Fi on your devices.
These servers tend to be really reliable and do the job without much fuss.
Method 5: Share Through a Computer
Got a desktop that’s always on? You can share its connection with your printer:
  1. Direct Connection: Keep your printer physically linked to the computer.
  2. Enable Sharing (Windows): Hit the Control Panel, go to Devices and Printers, right-click your printer, go to “Printer Properties,” and tick “Share this printer.”
  3. Enable Sharing (Mac): System Preferences, then Sharing, and check “Printer Sharing.”
  4. Get the Word Out: Ensure other devices can access through this computer—make sure everything’s configured just right.
Just remember, your computer has to stay on to keep the sharing alive.
And there you have it! Each of these paths lets you cut those printer cords without having to splurge on new equipment, unless you absolutely must. Good luck, and happy printing!
Transform Your Wired Printer into a Wireless Wonder
Say goodbye to USB cables and hello to the ease of wireless printing. Being able to print from any device, anytime, is a game-changer for homes and offices. Let’s chat about some ways to cut those cords and increase your printer’s convenience.
So, Why Bother Going Wireless?
The thing with wired printers is that they keep you tied down with those pesky USB or Ethernet connections. By going wireless, you open up a world where:
  • You can print from practically any device—smartphones, tablets, you name it.
  • No more having to rearrange your whole desk area trying to make space.
  • Everyone in the house or office can easily share the printer without any tangles.
Ways to Ditch the Wires
  1. Wireless Print Server Magic
    Think of a print server as a Wi-Fi matchmaker for your printer.
    • Here’s how:
    • Hook your printer to the server with USB or Ethernet.
    • Follow the server’s manual to connect to your Wi-Fi.
    • Add the printer to your devices using the server’s IP.
    • Pros: Steady as a rock, handles more than one printer.
    • Cons: It’ll cost you a bit (about a hundred bucks or so).
  2. Make Your Computer a Print Hub
    Let your computer do double duty as a print facilitator.
    • Here’s a quick run-through:
    • Connect and install the printer on your computer via USB.
    • Turn on printer sharing:
    • Windows: Settings > Devices > Printers > “Share this printer”.
    • Mac: System Preferences > Printers & Scanners > “Share this printer”.
    • Link other gadgets through the network to your printer.
    • Pros: Doesn’t cost a dime, uses what you already have.
    • Cons: Your computer has to stay on—so, no powering down!
  3. Soften the Tech Load with a Wireless Adapter
    If your printer can handle it, a wireless adapter is a nice and easy fix.
    • Here’s how to roll:
    • Check if your printer can use one (peek at the manual).
    • Plug the adapter into your printer’s USB port.
    • Follow prompts to hop on the Wi-Fi bandwagon.
    • Pros: Quick setup with barely any extra gear.
    • Cons: Only works if your printer’s built for it.
  4. Go Through the Router Route
    Some modern routers can moonlight as printer hosts.
    • Here’s how to do it:
    • Newer routers with USB ports can connect to printers.
    • Plug your printer into the router’s USB.
    • Pop onto the router’s admin page and enable printer sharing.
    • Set up drivers on your devices and print via the router’s IP address.
    • Pros: No extra purchases if your router’s ready.
    • Cons: Not all routers play nicely with printers.
Troubleshooting Headaches and Hiccups
  • Printer Playing Hide and Seek:
    • Ensure both the printer and server are alive and well (powered on, connected).
    • Make sure every device sticks to the same Wi-Fi clan.
    • Dust off those printers drivers—updates might be needed.
  • Wi-Fi Won’t Behave?:
    • Move your printer closer to the Wi-Fi source if you can.
    • Consider a Wi-Fi extender or a mesh network for wider areas.
  • Failing Password Checkpoints:
    • Make sure your Wi-Fi password is on point during setup.
    • If all else fails, nuke the printer’s network settings and have another go at it.
  • Compatibility Conundrums:
    • Grab the newest drivers from the printer maker’s site.
    • Check that shared printers are working with compatible OS versions.
Figuring Out the Best Route for You
Method Who’s It Best For? Cost
Wireless Print Server Offices or several printers to manage $$
Computer Sharing Best for small or home networks Free
Wireless Adapter Only if your printer is compatible $-$$
Router Hosting Perfect if your router has a USB port Free
With these tricks up your sleeve, cutting the cord on printing should be a breeze. If you hit any snags, your printer’s manual or the manufacturer’s website is a great place to dig for info.
Turning your wired printer into a wireless one? Totally doable, and I’ve got some tips for you!
First up, grab yourself a wireless print server. Basically, it hooks up to your printer’s USB and plays nice with your WiFi network. Just make sure the print server is compatible with your printer, plug it in, follow the setup steps that come with it, and don’t forget to install those drivers so you can print wirelessly.
Got a printer with an Ethernet port? Perfect! You can connect it to a wireless router, easy peasy. Check if your printer has that port, plug an Ethernet cable connecting it to your router, and hop into the router’s settings to track down the printer’s IP address. Once you’ve got that, just add it to your computer’s network list and you’re golden.
Now, here’s a cool trick: use an Ethernet to WiFi adapter. It works kind of like magic, turning that Ethernet port into a wireless connection. You’ll need to buy one, connect it to the printer, and set it up so it gets cozy with your WiFi network. Then, tweak your computer’s network settings to connect it.
If you’ve heard of a wireless printer bridge, that’s another good option. Buy one and hook it up using a USB or Ethernet cable. Follow the bridge’s setup steps to merge your wired printer into your wireless network—your computer will get the hint!
Honestly, who knew turning your old wired printer into a wireless wonder was this straightforward? Pick the method that suits your setup and dive into hassle-free wireless printing. And hey, always check your printer and gadget manuals if you find yourself in a pinch.
