How do I stop Steam from opening automatically on startup?
499 viewsGame Console
Stopping Steam from Automatically Launching at Startup
Alright, so you’re tired of Steam popping up every time you start your computer, hogging resources when you’re not even planning to game right away? No worries, you’re not alone! Steam likes to make things easy for gamers, but sometimes it gets a little too eager. Let’s tackle what’s causing this and how you can put a stop to it.
The Scoop: Why Does Steam Start on Its Own?
Steam is all about making sure you’re always ready to dive into your games—updates, friends, the whole shebang. It’s useful, but definitely not everyone’s cup of tea when it comes to conserving system resources. It usually starts up because of:
  1. Steam settings: Yup, they switch on auto-launch by default.
  2. System startup settings: Steam somehow ends up in your Windows Startup or macOS Login Items.
  3. Those sneaky launch parameters: Shortcuts or commands making Steam jump into action.
Shutting Down Steam Auto-Launch
1. Tweaking Steam’s Settings
So, if Steam’s settings are the culprit, here’s how you fix that:
  • Fire up the Steam client.
  • Go to the top-left corner: Steam → Settings → Interface.
  • Find the “Run Steam when my computer starts” option and uncheck it.
  • Save the changes with OK.
  • Restart your computer to see if Steam behaves.
Not doing the trick? Steam could still be tagged in your system’s startup apps (check Solution 2).
2. Boot Steam out from System Startup (Windows)
If Windows has added Steam to its startup list, here’s your game plan:
  • Use Ctrl + Shift + Esc to open Task Manager.
  • Look for the Startup tab.
  • Find Steam, right-click it, and select Disable.
  • Reboot to verify Steam’s gone.
Got Windows 10/11? Try this: Settings → Apps → Startup → Toggle off Steam.
3. Erase Steam from macOS Login Items
If Steam’s on macOS’s Login Items hit list, here’s what to do:
  • Click the Apple logo → System Settings → General → Login Items.
  • Spot Steam under “Open at Login” and select it.
  • Use the minus button to give it the boot.
4. Nix Duplicate Shortcuts or Commands
Maybe a shortcut or command line’s making Steam hyperactive. Here’s your fix:
  • Right-click any Steam shortcut on your desktop/taskbar → Properties.
  • Check the Target field for any launch parameters like -silent or -startup.
  • Clear them out.
  • Apply changes and restart your machine.
5. Getting into Advanced Territory (Registry/Shell Folders)
Now, for those rare cases where things get fishy:
For Windows:
  • Press Win + R → Type shell:startup → Press Enter.
  • Trash any Steam shortcuts in the Startup folder.
Registry Edit (Handle with Care):
  • Press Win + R → Type regedit → Navigate to:
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
  • Delete the Steam entry if it’s lurking there.
For macOS/Linux:
  • Peek into configuration files like ~/.config/autostart/ (Linux) or check out third-party tools for startup apps.
Troubleshooting Nuggets
  • Steam still appearing? Check for any third-party apps that might be causing this.
  • If all else fails, a Steam reinstall might be in order—backup your stuff first.
  • Make sure you’ve got the latest Steam version, just in case of bugs.
Want Steam to Auto-Start Again?
If you change your mind, just go back to that “Run Steam when my computer starts” checkbox in Steam’s settings or re-add it to your startup list. Easy-peasy!
There you go! Follow these steps to stop Steam’s surprise parties on your PC startup, and finally have control over when you want your gaming library accessible.
So, you’re tired of Steam booting up every time you kickstart your computer, huh? No worries, you’ve got options, whether you’re on Windows or macOS. Let’s dive into some practical fixes to keep Steam in check.
  1. Fire Up Steam: First things first, crack open the Steam app.
  2. Go to Settings: Hit up the ‘Steam’ menu in the top corner and choose ‘Settings.’
  3. Look for Interface: On the settings menu, make your way over to ‘Interface.’
  4. Turn Off Auto-Start: Here’s the kicker—uncheck the ‘Run Steam when my computer starts’ box. Steam will mind its own business during boot-up if you nix this option.
Got a Windows Machine? Use Task Manager
  1. Launch Task Manager: Pull up Task Manager by pressing Ctrl + Shift + Esc, or right-click your taskbar and select it.
  2. Check Out the Startup Tab: Switch to the ‘Startup’ tab up top.
  3. Locate Steam: Thumb through the list till you spot ‘Steam.’
  4. Disable It: Right-click ‘Steam’ and hit ‘Disable.’ This does the trick to stop it from popping up at startup.
Also on Windows? Head to Settings
  1. Open Settings: Punch in Windows key + I to jump to settings.
  2. Go to Apps: Navigate to ‘Apps,’ then hit up ‘Startup.’
  3. Switch Off Steam: Just flip the toggle for Steam to ‘Off.’ It’ll stop bugging you from there.
Mac Users, It’s Your Turn with System Preferences
  1. Call Up System Preferences: Click the Apple menu and hop over to ‘System Preferences.’
  2. Head to Users & Groups: Select ‘Users & Groups.’
  3. Highlight Your Account: Pick your username from the left-hand list.
  4. Find Login Items: Crack open the ‘Login Items’ tab.
  5. Boot Out Steam: Snag ‘Steam’ from the startup list and tap the minus (-) button to kick it out.
Still on Windows? Dive Into Task Scheduler
  1. Open Task Scheduler: Punch Windows key + R, jot down taskschd.msc, and press Enter.
  2. Hunt Down Steam Tasks: Expand ‘Task Scheduler Library’ and sleuth out any Steam-related tasks.
  3. Disable ‘Em: Right-click the task for Steam and hit ‘Disable.’ That should do it.
The scoop here is simple: trying out these fixes can ease up your computer’s startup routine. You might notice a quicker boot time without Steam chomping at the bit.
Alright, here’s the deal: if you’re tired of Steam popping open every time your computer starts, you’ve got a couple of quick fixes depending on whether you’re using Windows or Mac. Let’s dive into it.
For Windows folks:
  • Steam Settings:
    • Fire up Steam and chill a second.
    • Hit up the “Steam” option up top, then roll into “Settings.”
    • Under “Interface,” just uncheck that box that says “Run Steam when my computer starts.” Easy peasy.
  • Task Manager:
    • Hit Ctrl + Shift + Esc and bam, Task Manager is open.
    • Slide over to the “Startup” tab.
    • Find Steam, right-click on it, and hammer “Disable.” Done and done.
  • System Configuration (msconfig):
    • Tap Windows + R for the Run box to come up.
    • Type msconfig, press Enter, and you’re in.
    • Find the “Startup” tab and uncheck Steam. Hit “Apply,” then “OK.” Restart your computer—problem solved!
And for Mac users:
  • Steam Preferences:
    • Launch Steam and take it from the top-left menu.
    • Go to “Preferences.” Over in the “Interface” tab, uncheck “Run Steam on login.” That should do it.
  • Mac System Preferences:
    • Click that Apple logo and head into “System Preferences.”
    • Click “Users & Groups,” then your account.
    • Jump to “Login Items.” Select Steam and hit the “-” button. Adios, Steam.
Honestly, cutting Steam from startup isn’t just about speed; it’s a relief to have more control over what fires up when your machine boots. Now breathe easy and get that fresh-air feeling whenever you start your computer. Cheers!
