How to Make Icons Smaller on Samsung?
297 viewsPhone
How to Make Icons Smaller on Samsung: A Comprehensive Guide
Samsung devices are everywhere these days, but not everyone vibes with the default icon size. Whether it’s for a cleaner home screen, fitting more apps in, or just personal taste, tweaking icon sizes is totally doable. Here’s how to make them smaller.
Why Would You Want to Make Icons Smaller?
  • Enhance Aesthetics: Smaller icons can make your home screen look more organized and less cluttered, giving it a sleek appearance.
  • Improve Practicality: More apps on one screen mean you can navigate quicker and easier.
  • Increase Accessibility: For some folks, smaller icons might actually be easier to see and use.
Methods to Make Icons Smaller on Samsung
Let’s get into the nitty-gritty, shall we?
Method 1: Adjust Icon Size via Home Screen Settings
  1. Access Home Screen Settings: Long press on an empty space on your home screen to bring up settings, then tap “Home screen settings.”
  2. Find Icon Size Option: Look for “Icon size” or “Grid size.”
  3. Adjust Icon Size: Use the slider or options to make icons smaller.
  4. Apply Changes: Head back to your home screen to check out your new icon size.
Method 2: Change Icon Size through the Settings App
  1. Open Settings: Swipe down and tap the gear icon.
  2. Navigate to Display: Scroll and select “Display.”
  3. Adjust Screen Resolution or Display Size: Sliding left on “Screen zoom” will shrink icons and everything else.
Method 3: Use Samsung’s Theme Store
  1. Open Theme Store: Find this in your app drawer.
  2. Browse Themes: Pick one with smaller icons.
  3. Download and Apply: Your icons will shrink to fit the theme.
Method 4: Use Third-Party Launcher Apps
  1. Download and Install a Launcher: Nova Launcher or Apex Launcher from the Play Store should do the trick.
  2. Access Launcher Settings: Depending on your launcher, find “Icon size” in its settings.
  3. Adjust Icon Size: Pick a size that works for you.
Method 5: Use Icon Packs
  1. Download an Icon Pack: Find one with smaller icons on the Google Play Store.
  2. Apply the Icon Pack: Use a compatible launcher and set your new icons in its settings.
Method 6: Adjust Grid Size in Home Screen Settings
  1. Access Home Screen Settings: Long press on home screen, tap “Settings.”
  2. Select Home Screen Grid: Choose a bigger grid size.
  3. Change Apps Screen Grid (Optional): Do the same for your apps screen if you like.
Tips for Making the Most of Smaller Icons
  • Rearrange Icons: Move things around to make the best use of space.
  • Create Folders: Grouping similar apps can help manage any clutter.
  • Use Widgets Wisely: Widgets can be a great way to save space and enhance functionality.
So, there you go! With these tips and tricks, you’ll be a pro at resizing icons on your Samsung device, making it fit exactly the way you like. Happy customizing!
Alright, if you’re looking to shrink those app icons on your Samsung phone, you’re in luck because it’s super straightforward. This involves tweaking the home screen grid settings. Here’s how you get it done:
Let’s Dive In
  1. Start from the Home Screen: First things first, go to your home screen where all the app icons chill.
  2. Find an Empty Spot and Hold: Tap and hold an empty area on the home screen. This little trick will pop up a menu with options to customize the appearance of your home screen.
  3. Hit Up Home Screen Settings: Once you’re there, search for the “Home screen settings” and tap it. Now you’re looking at a menu for all sorts of layout tweaks.
  4. Grid Size Options Available: This menu has goodies labeled “Home Screen Grid” and “Apps Screen Grid.” Basically, this lets you fiddle with how many icons can squeeze into each row and column on your home screen or app drawer.
  5. Play Around With the Grid Size:
    • For the Home Screen Grid, choices might be like 4×5, 4×6, 5×5, or 5×6. For Apps Screen Grid, think along the lines of 4×4, 4×6, 5×5, or 5×6.
    • Picking a bigger grid size (switching from 4×5 to 5×6, for instance) will shrink down each icon since you can fit more in the same space.
  6. See How It Looks: As you make your choice, there’s usually a preview window that gives you a sneak peek of the new icon sizes.
  7. Lock In Your Settings: Once you’ve settled on the grid size and smaller icons that suit you best, confirm or save those changes.
  8. Check Out the Home Screen: Jump back to your home screen to take a gander at your newly resized icons.
Bonus Tip
If you can’t seem to find these options because of software quirks or your phone model, try out third-party launchers like Nova Launcher or Microsoft Launcher. These apps are great for further customization, including tweaking icon sizes.
Follow these steps and you’ll have smaller icons in no time on your Samsung device.
Making Icons Smaller on Samsung Devices
Got a cluttered screen with huge icons? Let’s tidy things up! Shrinking your Samsung smartphone’s icons can make your screen look neater, boost visibility, and give you more room to play with. Here’s how to get those icons down to size, plus a bit on why they may seem huge in the first place.
Why Do Icons Look Huge Sometimes?
  1. Grid Settings Got You Stuck: Samsung defaults to a grid layout, like 4×5 or 5×5, which can make icons look chunky.
  2. Tinker with Display Options: Sometimes the “Screen Zoom” or “Font Size” settings have side-effects on how big your icons appear.
  3. Third-Party Launchers: Downloaded something like Nova Launcher? These can take control and mess with the usual icon sizes.
Shrinking Those Icons
1. Tweak Your Home Screen Grid
If your icons feel like they’re hogging the space, try a bigger grid.
  • How to Do It:
    • Head over to Settings → Home Screen → Grid Size.
    • Pick a dense grid, like 5×6 or even 6×7.
    • Save your choice—your icons should look smaller in a jiffy!
2. Fiddle with Screen Zoom and Font Size
Going minimal on screen zoom will shrink those icons down.
  • Steps:
    • Pop open Settings → Display → Screen Zoom and Font.
    • Slide to decrease “Screen Zoom” and/or “Font Size”.
3. Dive into Samsung’s Theme Park
Want to customize down to the nitty-gritty? Samsung’s Theme Park via Good Lock is your playground.
  • Follow These Steps:
    • Download Good Lock from the Galaxy Store.
    • Open Theme Park → Icons, and play around with size, shape, and spacing.
4. Give a Third-Party Launcher a Shot
Swing by apps like Nova Launcher or Lawnchair for advanced tweaking.
  • Get Started with Nova:
    • Download Nova Launcher and make it your go-to choice.
    • Jump into Nova Settings → Home Screen → Icon Layout → Try downsizing the icon and ramping up grid density.
5. Get Sneaky with Developer Options
Feeling like an expert? Dive into Developer Options for some secret settings.
  • Unlock the Magic:
    • Find Settings → About Phone → Tap “Build Number” 7 times to unlock Developer Options.
    • Then hit Developer Options → Tweak Smallest Width (higher numbers make for tidier UI pieces).
Doing a Little Troubleshooting
  • Icons Stubbornly Stay Big: Make sure your launcher or theme lets you resize. If not, give your device a swift restart.
  • Sizing all Over the Place: Check for any pesky accessibility settings like Magnification and turn them off.
  • Fixed App Icons: Some apps just refuse to shrink or grow, like certain games. Those might not budge.
Extra Tips to Keep Things Fresh
  • Declutter with Widgets and Folders: Bundle apps into folders or keep widgets minimal to avoid a mess.
  • Spice Things Up with Icon Packs: Use Samsung Themes to swap out icons for a more even look.
If you mess around with grid sizes, adjust display scale, or try out third-party apps, you can give your home screen a snazzier look. If your device is vintage, consider hopping on a newer One UI for better customizations!
How to Tweak Icon Sizes on Your Samsung Phone
Feeling like your Samsung smartphone icons are dominating your screen? Let’s shrink those puppies and get them under control. Organize your home screen just how you like it without feeling like the apps are taking over. Here’s how to do it:
Method 1: Fiddling with Home Screen Settings
  • If You Rock a Samsung Galaxy S24 Ultra:
  • Hold some empty space on the Home screen like a champ.
  • Hit up the ‘Settings’ or that gear icon.
  • Go for ‘Home screen layout.’
  • Choose ‘App screen grid’ or ‘Home screen grid’ to play with the size.
  • Crank up the grid size, maybe 4×5, or 5×5, to shrink those icons.
  • Smash ‘Apply’ to lock in the changes.
  • If Your Samsung Device Packs One UI 3.0 or Higher:
  • Chill by pressing an empty area on the Home screen.
  • Tap ‘Home screen settings.’
  • Pick ‘Home screen grid’ or ‘Apps screen grid.’
  • Mess with the grid settings like 4×4 or 5×5 to make icons smaller.
  • Hit ‘Save’ to keep your edits.
Method 2: Dive Deep with Third-Party Launchers
  • Not digging the built-in options? Get yourself a third-party launcher for more tweaking:
  • Nova Launcher:
  • Grab Nova Launcher from Google Play and install it.
  • Dive into Nova Launcher Settings and touch ‘Home screen.’
  • Adjust the ‘Icon Size’ slider in ‘Icon Layout.’
  • Microsoft Launcher:
  • Download Microsoft Launcher from Google Play Store and set it up.
  • Cruise through Microsoft Launcher Settings to ‘Home Screen.’
  • Get all hands-on with ‘Custom Font & Icon Size’ to change things up.
Method 3: Accessibility Settings to the Rescue
  • For broad adjustments that hit icon size:
  • Mosey over to ‘Settings’ on your Samsung device.
  • Head to ‘Accessibility.’
  • Tap on ‘Visibility enhancements.’
  • Use ‘Magnification’ and ‘Font size’ options for more changes.
With these tricks, you’ll have those icon sizes just right, letting you rock a customized Samsung experience. A little change can do wonders, wouldn’t you agree?
