How to Lock Photos on Iphone with Face Id?
279 viewsPhone
Hey there! Locking your photos on your iPhone using Face ID is a breeze. Let me guide you through it step by step.
First thing’s first – check if your iPhone is running iOS 18 or later, because you’ll need that new feature to get started. Just head over to Settings, tap on General, and hit Software Update. You want your phone to be up-to-date.
Once you’re all updated, let’s find that Photos app. It should be chillin’ on your Home Screen – you know, the one with all your pictures and videos. Give it a good long press until this nifty quick actions menu pops up.
Now, here’s the kicker – tap on Require Face ID. It’s right there in the menu. You’ll get a prompt asking if you’re sure about using Face ID to lock your photos. Go ahead, hit that confirmation button.
Next up, it’s time to share your face. Hold up your phone, let it scan your mug, and Bam! It’s locked. You might need to tap Require Face ID once more just to seal the deal.
Feeling extra cautious? You can tweak which apps have photo access by jumping into Settings, then hitting Privacy & Security, and Photos. You get to pick and choose which apps can sneak a peek at your pics.
Now, wanna see if it works? Open the Photos app. You’ll have to show your face again, keeping nosy folks out of your digital album. Just remember, if you ever want to undo it, repeat the steps and pick Don’t Require Face ID.
There’s a heads-up for you: while Face ID keeps the Photos app locked tight, if someone knows your phone’s passcode, they might still find hidden albums. So, hide those suckers away for extra security.
Locking your photos like this adds a sweet layer of privacy. Hope this helps keep your snaps safe from unwelcome eyes. Cheers!
So, you’re looking to lock photos on your iPhone with Face ID? Read on for some handy ways to make sure your private snaps stay just that—private.
Simple Ways to Keep Your Photos Under Wraps with Face ID
  1. Hide Albums & Use Face ID
    • Head into Settings > Photos and flip on “Hidden Album” to keep your sensitive pics out of sight.
    • Next, pop back into Settings > Face ID & Passcode and make sure “Face ID” is turned on for the Photos app.
    • Want to peek at those hidden pics? You’ll have to pass the Face ID check.
  2. Lock Photos in Notes
    • Pick the photos you want to secure in the Photos app, tap Share > Save to Notes, and create a locked note.
    • Make it safer with a Face ID lock through Notes settings > Password & Face ID.
  3. Check Out Third-Party Apps
    • Apps like Private Photo Vault or PhotoGuard offer extra features, like Face ID options and fake modes.
Things You Need & Tips if Things Go South
A. What You’ll Need
  • Make sure your device is on iOS 16 or later to use Face ID with hidden albums natively. If your software’s older, third-party apps are a must.
B. Match Face ID with Your Face
  • Reconfigure Face ID if it’s tripping up:
    • Go into Settings > Face ID & Passcode > Reset Face ID.
    • Ensure you’re in good lighting and ditch the masks or chunky glasses.
C. Troubleshooting Common Problems
  • Face ID Doesn’t Work for Photos:
    • Double-check that Face ID’s switched on for Photos in Settings > Face ID & Passcode.
    • A restart or iOS update can clear up those pesky software issues.
  • Hidden Album Won’t Show Up:
    • Switch back on “Hidden Album” in Settings > Photos.
Tips to Keep Things Extra Secure
  • Avoid snapping screenshots of locked photos— they sidestep Face ID.
  • Regularly back up encrypted snaps to iCloud (make sure two-factor authentication is on!)
  • Pair up Face ID with a robust alphanumeric passcode for top-notch security.
By mixing these strategies, you can use Apple’s Face ID to keep your private photos truly private— and avoid any easy access by nosy folks.
Let’s dive into how you can keep your photos on your iPhone under wraps using Face ID. It’s super easy, and once you get the hang of it, you’ll wonder why you didn’t do it sooner.
First things first, pop open your Photos app. Find those pics you want securely tucked away from prying eyes and give them a tap. Here’s the kicker: you’ll want to add these to your Hidden Album. Just hit the ‘Share’ icon, then ‘Hide’, and confirm it. Easy peasy!
Now, to ensure your Hidden Album is locked up tight with Face ID, you’ll need to head over to Settings. Scroll your way down to Photos and flick on the “Use Face ID” switch for the Hidden Album. Voila, your pics are nice and secure!
So, how do you get back to those hidden photos? Just go into the Photos app, hit up the Albums tab, and scroll on down to Utilities. There’s your Hidden album, ready to be unlocked with your Face ID magic.
Here’s a pro tip for ya: make sure your phone is updated to iOS 18 and maybe throw on a strong passcode just for kicks. Honestly, that’s a whole lot of security packed into your pocket!
Anyway, that’s basically all you need to know about locking photos with Face ID. You can swing by Apple Support for more details if you’re curious or need extra help. Go on, try it out—I trust you’ll love the peace of mind!
