How Can I Keep My Mac On Without It Sleeping?
437 viewsLaptops
Keeping Your Mac Awake the Easy Way
You ever find yourself in the middle of something important, only for your Mac to decide it needs a nap? We’ve all been there, so let’s dive into some ways to keep your Mac up and at \’em without drifting off.
System Settings: The Straightforward Fix
If you’re rocking macOS Ventura or Sonoma, head over to the Apple menu and hit System Settings. From there, go to “Lock Screen” on the sidebar. You’ll want to scroll through the options on the right and tweak “Turn display off on battery when inactive” to “Never” or whatever fits your schedule. This keeps your Mac’s display alive even if you’re not actively tapping away.
For friends using Big Sur, Monterey, or earlier, pop open System Preferences, then “Battery” or “Energy Saver.” Slide that display sleep setting to “Never” and make sure to tick the box that says, “Prevent your Mac from automatically sleeping when the display is off.”
Terminal Trickery: When You’re Feeling Bold
Got a thing for typing commands? Open up Terminal (that’s sitting in Applications > Utilities) and type this in:
caffeinate -d
Boom! Your Mac stays awake as long as that Terminal window is open. Want it awake for just a certain timeframe? No problem, try this:
caffeinate -t X
Plug in however many seconds you need for “X.” Pretty nifty, huh?
Handy Apps: Third-Party Helpers
Sometimes, an app’s just what the doctor ordered:
  • Lungo: It’s fuss-free and lives in your menu bar. Choose how long you want your Mac lively, from a handful of minutes to, well, forever.
  • Amphetamine: The name says it all. Not only does it keep your Mac awake, but it also lets you set sessions based on what apps you’re using or for a fixed period. It’s free and full of features.
  • KeepingYouAwake: This one’s perfect for longer tasks and super user-friendly. It’s sort of like caffeinate’s little sibling, with options galore.
Lid Closed? No Problem!
MacBooks tend to nod off when you close the lid, but if you’re hooked up to an external monitor, there’s a workaround. On macOS Sonoma, hop into Apple menu > System Settings > Battery. Hit Options, and check the box to “Prevent automatic sleeping on power adapter when the display is off.” Ventura folks, head to System Settings > Displays > Advanced and do the same.
Setting a Sleep Schedule
Older macOS versions let you schedule sleep and wake times through Energy Saver. Even if newer versions ditched this in the settings menu, you can still play around with Terminal commands like this one:
sudo pmset repeat sleep MTWRFSU 22:00:00
Stay in Control
Whether you’re downloading heaps of data, giving a presentation, or slugging away on a long project, these options help you keep your Mac where it belongs—right in the game. From built-in settings to nifty little apps, running your Mac’s sleep schedule feels more like a personalized service.
So, you’re trying to keep your Mac from dozing off, huh? No worries—there are several ways to tackle this:
Tweak the Energy Settings:
  • Hop into your System Preferences from the Apple menu.
  • Find Battery on a laptop or Energy Saver on a desktop.
  • Under Power Adapter, slide that Turn display off after setting all the way to Never.
  • Tick the box that says Prevent computer from sleeping automatically when the display is off. Simple as that!
Go the Terminal Route:
  • Fire up Terminal from the Utilities folder in Applications.
  • Type in: caffeinate -di and hit Enter.
  • This nifty command will keep your Mac wide awake until you close Terminal.
Try Some Handy Apps:
  • Check out apps like KeepingYouAwake or Caffeine. They’re super easy to use for keeping your Mac lively.
  • Just grab and install one from a trustworthy source, then set it up to fit what you need.
These tricks should keep your Mac up and running while you’re busy with your stuff. Just a heads-up: make sure your Mac isn’t overheating when it’s awake for long. Nobody wants a hot computer, right?
If you\’ve ever struggled with keeping your Mac awake, don’t worry—you\’re not alone! Let’s dive into some ways to keep that Mac from drifting off when you need it to work continuously.
Here’s the deal: Macs love to save energy. While that\’s great for the planet, it can interrupt tasks like downloads or rendering if your Mac goes to sleep too soon.
What can you do?
  • Tweak Energy Settings: Head to System Preferences > Battery > Power Adapter. Slide \”Turn display off\” to \”Never\” and ensure \”Prevent automatic sleeping when the display is off\” remains unchecked.
  • Go Terminal with caffeinate: Open Terminal and type caffeinate -dims & to keep it awake. This command is like a shot of espresso for your system.
  • Third-Party Apps: There are handy tools like Amphetamine on the App Store that give you control over your Mac’s sleeping habits. They’re super user-friendly!
Sometimes, it’s not just the sleep settings. Random shutdowns can be a pain!
What’s happening?
  • Your Mac might get grumpy if there are incompatible drivers or if an app misbehaves.
How to fix it?
  • Dive into Console Logs: Check Console.app for any \”Error\” or \”Fault\” messages. These logs can be a goldmine for finding repeated issues.
  • Try Safe Mode: Reboot while holding the Shift key to disable extras that might be causing problems.
  • Reset the SMC/NVRAM: If you’ve got an Intel Mac, do the reset dance with Control + Option + Shift and the power button.
Here’s where things get practical. Check those cables!
  • Look for frayed cables or dodgy connections. Still using that old charger? Maybe it\’s time for an upgrade.
  • Head to Apple Menu > About This Mac > System Report > Power to check battery health. If it says \”Service Recommended,\” listen to it.
Keeping your system healthy isn’t too hard with a bit of TLC.
  • Repair Disk Permissions: Boot into Recovery Mode by holding Command + R, then use Disk Utility to run First Aid.
  • Update Regularly: Always keep your macOS up-to-date to squash any pesky bugs that might put your Mac to sleep.
For the tech-savvy, hop into Terminal and use sudo pmset -a displaysleep 30 to customize your sleep settings. Just be careful—keeping your Mac running too long might not be the best for its lifespan.
In a nutshell, whether you’re working through big projects or simply want peace of mind with continuous operation, these tips should keep your Mac running smoothly. If issues keep cropping up, running the Apple Diagnostics (hold the D key during boot) or visiting a repair guru could be the next steps. Happy computing!
