How Can I Keep My Laptop On When the Lid Is Closed?
437 viewsLaptops
Alright, let’s dive into how you can keep your laptop running even when it’s closed. Whether you’re using Windows or macOS, I’ve got you covered with some straightforward steps:
Windows (Windows 10 and Windows 11)
  1. Get into Power Options:
    • Hit Windows + X and pick Power Options. Simple as that.
    • Once you’re in, go for Additional power settings on the right panel. Easy peasy!
  2. Tweak Lid Settings:
    • Here’s the deal: Click Choose what closing the lid does on the left side.
    • Change those drop-downs next to When I close the lid to Do nothing. Do this for both On battery and Plugged in.
  3. Lock It In:
    • Click Save changes. Boom, you’re done!
macOS
  1. Hook Up an External Display:
    • Make sure your MacBook is plugged in so it doesn’t conk out.
    • Connect up a keyboard and mouse.
    • Here’s the magic trick: Close the lid once the monitor is connected, and voilà, your Mac is still humming along.
  2. Terminal Tip:
    • Fire up Terminal.
    • Type in sudo pmset -a lidwake 0. Hit enter and punch in your password if asked. You’re in control now!
One last thing—don’t forget to give your laptop some breathing room even when it’s closed. Nobody wants their device to overheat!
Wanna keep your laptop going when you shut the lid? Here’s how you can do it for different systems, without all the tech jargon.
Why Would You Even Want To?
Usually, when you close your laptop’s lid, it takes a snooze to save battery and prevent overheating. But sometimes, you want it to keep working to, say, hook it up to an external monitor, keep downloads running, or stay accessible remotely. I’ve been there too. Let\’s dive into what you can do across various operating systems.
Different Strokes for Different Systems
Windows
So, here’s the deal with Windows laptops. By default, they chill out (sleep or hibernate) when you shut them. Here’s how you can fix that:
  • Pull up your Control Panel and head over to Power Options.
  • Hit Choose what closing the lid does in the sidebar.
  • Where it says When I close the lid, switch both On battery and Plugged in to Do nothing.
  • Don’t forget to Save changes.
If you find those options grayed out, just go for Change settings that are currently unavailable (pretty straightforward but needs admin rights).
If things still aren’t behaving, out-of-date drivers could be the culprit. Check the Display and Power Management drivers in Device Manager. Oh, and keep an eye out for conflict by disabling any antivirus or third-party power management software.
macOS
With Macs, they’re set to sleep by default, just like your cat on a sunny afternoon. But you can keep it awake:
  • Terminal Magic: Fire up Terminal and type in sudo pmset -a disablesleep 1. You’ll need the admin password. To switch it back, use sudo pmset -a disablesleep 0.
  • Apps to the Rescue: If Terminal isn’t your thing, go for apps like Amphetamine or InsomniaX. They’re super handy.
Heads-up: If your macbook isn’t plugged in, macOS might override these settings. No one likes unexpected shut-downs, right? And do try not to leave the laptop closed for too long — overheating isn\’t fun.
Linux (Ubuntu/Debian-based)
For those running Linux, the system’s power settings or kernel parameters need a bit of tweaking:
  • Edit the Config: Open the file /etc/systemd/logind.conf and change these lines to ignore:
  •     HandleLidSwitch=ignore  HandleLidSwitchExternalPower=ignore
  • Then restart the service with sudo systemctl restart systemd-logind.
  • Turn Off DPMS: With X11 sessions, just run xset -dpms to keep the display alive.
A little FYI, some laptops need a BIOS tweak — brands like Dell or Lenovo might have some extra steps.
Keep These in Mind
  • Watch the Heat: Make sure there’s good ventilation. It’s like when you get too snug under that winter blanket — things heat up!
  • Battery Care: Constantly leaving it plugged while closed can mess with battery health. Use something like BatteryBar for Windows to keep tabs on charging.
  • Old Models: If your laptop is more ‘vintage’, the BIOS might not support some of these settings. Check what the manufacturer says.
When Things Don’t Go to Plan
  • Persistent Sleepiness: Your system still nodding off despite settings? Consider resetting the System Management Controller (SMC) on Macs or an EC reset for others. It varies by brand.
  • Monitor Issues: Noticed your external display isn’t showing anything? Connect it before closing the lid and tweak display settings like Win + P for Windows.
A Few Last Tips
  • Sharing your device? Label it something like “DO NOT POWER OFF” to avoid accidental shutdowns by others.
  • Using it as a server? Consider going battery-free and run on AC power to dodge any mishaps.
So, there you have it. With a few tweaks, you can keep your laptop up and running even with the lid closed. Just find what works best for you and remember to balance between convenience and device health.
So, you\’re looking to keep your laptop alive even when it\’s closed? Sounds like you\’re aiming to turn your portable computer into a sleek desktop setup—cool idea! Let’s dive into how you can make that happen on both Windows and macOS.
Windows Laptops
First things first, hit the Start menu and type “lid.” This nifty shortcut will help you find the “Choose what closing the lid does” option in the Control Panel easier than chasing down a stray sock! Once you’re there:
  1. You’ll spot settings for “When I close the lid”—check it out for both when you’ve got battery power and when you’re plugged in.
  2. Set it to “Do Nothing” for when it\’s plugged in. It’s a good way to keep the machine running without a hitch. (On battery, though, “Sleep” might be your best friend to save power.)
  3. Don’t forget to save those changes!
Voilà! Now your laptop stays awake when you shut the lid. It’s a handy trick borrowed from some solid recommendations out there and trusty Windows guidelines.
macOS Laptops
Moving on to our Apple folks:
  • For macOS Ventura and the latest gang:
    1. Open up System Settings and swing by the Battery section.
    2. Scroll a bit until you can click “Options.” There, tick “Prevent automatic sleeping on power adapter when the display is off.” That way, your MacBook keeps trucking when it’s closed and hooked to an external display.
  • On older versions:
    1. Head to System Preferences and tap on Battery. Then find the Power Adapter tab.
    2. Make sure “Prevent computer from sleeping automatically when the display is off” is checked.
Hook up an external keyboard, mouse, and monitor, and boom—clamshell mode engaged! Your MacBook’s still got all its bells and whistles, no open lid required. This is straight from the user manual, and it’s backed up by loads of tech support chats.
Quick Tips to Keep in Mind
  • Proper ventilation matters! Laptops can heat up when closed, so let them breathe.
  • Double-check all your gadgets are plugged in before shutting your laptop lid.
  • Tweak those power settings mindfully so you’re not dealing with a battery that drains like a sieve.
Once you’ve tweaked these settings, you’re all set to enjoy a streamlined laptop-to-desktop experience. No more fussing with an open lid, just smooth sailing with all your fave peripherals.
