How to Hook Keyboard and Mouse to Ps4?
309 viewsMouse
PlayStation 4 (PS4) is mainly designed for gaming with its DualShock 4 controller, but let’s be honest, sometimes a keyboard and mouse are just more precise and faster, especially in FPS games, strategy games, or MMOs. If you’re looking to connect a keyboard and mouse to your PS4, here’s a detailed guide to get you started.
Why Bother?
When the PS4 first came out, keyboard and mouse support wasn’t even a thing. But as more PC gamers made the switch to consoles, the need for these peripherals grew. Sony caught on and, through firmware updates, started allowing external keyboards and mice. This is really helpful for those used to PC gaming who want to stick to what they know best.
Connecting Methods
Wired Connection
  1. Get Your Gear Ready: You’ll need a USB keyboard and mouse. Most USB keyboards and mice will do the trick, but taking a peek at the manufacturer’s specs just to be sure won’t hurt.
  2. Locate the USB Ports: USB ports are on the front and back of the PS4. Plugging into the front is usually more convenient.
  3. Plug-In: Plug your keyboard and mouse into the USB ports. The PS4 should recognize them right away and you’ll see a keyboard or mouse icon pop up on the screen.
  4. Enable: Head to the PS4’s “Settings” menu, go to “Devices,” and enable “External Keyboard” and “Mouse.” Easy, right?
Wireless Connection
  1. Check Compatibility: Make sure your wireless keyboard and mouse support Bluetooth and are good to go with the PS4.
  2. Pair Devices: Put your keyboard and mouse in pairing mode. Check the user manual if you need to, as it often requires a specific button press.
  3. Pairing Time: On the PS4 home screen, navigate to “Settings,” then “Devices,” and finally “Bluetooth Devices.”
  4. Connect: The PS4 will scan for nearby Bluetooth devices. When your keyboard and mouse show up, select them and follow any necessary prompts like entering a pairing code.
Using a USB Hub
Running out of USB ports? No problem. Plug a USB hub into one of the PS4’s USB ports and then connect your keyboard and mouse through the hub. It should work just fine.
Special Cases
A small heads-up: Some wireless keyboard-mouse combos use a single USB transceiver. In cases like these, the PS4 might only recognize the keyboard.
Game Compatibility
Here’s the kicker: Not all PS4 games will support keyboard and mouse inputs. Do a bit of homework on game compatibility before investing in peripherals. Games like “Fortnite” or “World of Warcraft” are more likely to support these devices.
Fine-Tuning Your Setup
  1. Adjust Settings: After connecting, go to the “Settings” menu on the PS4, select “Devices,” then tweak settings like pointer speed and button mapping to your liking.
  2. Game Specific Settings: Some games let you customize key bindings and sensitivities within their own settings menus. Utilize these for an even better experience.
Troubleshooting
  1. Not Recognized: If your PS4 doesn’t recognize the keyboard or mouse, unplug them and plug them back in. If wireless, check the pairing mode and battery status.
  2. Input Lag: This could be a firmware issue. Check the manufacturer’s site for any updates. For wireless devices, ensure the USB receiver is firmly connected.
  3. Game Not Fully Supporting Input: If a game doesn’t fully support keyboard and mouse, try adjusting the game’s settings, or look for community-created configuration files.
Recommendations
When in doubt, go for peripherals that are known to be compatible and offer good performance. Some solid picks include the Logitech Bluetooth Illuminated Keyboard K810, Logitech G19 Gaming Keyboard, and HORI Tactical Assault Commander Pro.
Hooking up a keyboard and mouse to your PS4 is pretty straightforward, though compatibility checks and a bit of tweaking can go a long way. Once set up, these peripherals can make your PS4 experience a lot more enjoyable and smooth.
Plugging a keyboard and mouse into your PS4 is super easy, whether you’re using wired or wireless options. Let’s break it down.
Wired Connection
First thing’s first, find the USB ports on your PS4, usually tucked right at the front. You should see two or three of them like eyes staring back at you. Now, grab your keyboard and mouse and plug those bad boys in. Each one needs its own little spot.
If your PS4 isn’t already humming, switch it on. Your new gadgets should get a nod of approval from the system, usually with a little pop-up on your screen saying they’re hooked up. Sweet! Pick your gaming profile (or whichever you use), and you’re ready to rock.
Now, here’s the kicker—when it comes to playing games, not all titles will let you use a keyboard and mouse. Weird, I know. Best to check the game’s compatibility first before diving in.
Wireless Connection
Alright, wireless folks, let’s get this show on the road. Make sure your keyboard and mouse are juiced up with either fresh batteries or fully charged. Next up, put ’em in pairing mode—check your gear’s manual for how that goes.
On your PS4, navigate to the toolbox icon and hit up ‘Settings.’ Swing by ‘Devices,’ then ‘Bluetooth Devices.’ The PS4 will scour the room looking for nearby connections. Once your devices pop up, pick each from the list and connect ’em. You might need to slap in a code like ‘0000’ if asked. Classic Bluetooth move.
After they’re locked in, they should show up in your list of registered gizmos. And just like wired devices, you’ll want to know which games are besties with your keyboard and mouse.
So there you have it—whether you’re wired or wireless, it’s a pretty straightforward affair, right? One way or another, connecting a keyboard and mouse to your PS4 can really smooth out your gaming sessions or make scrolling through apps a lot less hassle.
Hooking Up Your Keyboard and Mouse to a PS4
So, you’re looking to pair your keyboard and mouse with your PS4, huh? Well, you might be in luck—some games actually support it! Here’s how you can get it done, along with a few bumps you might hit along the way.
Going the USB or Bluetooth Route
Yep, the PS4 gets along with most USB and Bluetooth keyboards and mice. Most games might just shrug them off, but don’t lose hope—games like Call of Duty: Warzone and Final Fantasy XIV do let them play ball.
Here’s the lowdown:
  • USB Connection
    1. Pop that keyboard/mouse into the PS4’s USB port.
    2. Swing by Settings > Devices > External Keyboard or Mouse to tweak your settings.
    3. Give it a whirl in apps or games that are on board with this setup.
  • Bluetooth Connection
    1. Set your keyboard/mouse to pairing mode (usually a button somewhere).
    2. Head to Settings > Devices > Bluetooth Devices on your PS4.
    3. Pick your device off the list to pair it up!
Heads up:
  • Games not on the supported list? Yeah, they won’t do much with your keyboard/mouse combo.
  • Got a Bluetooth setup? You might feel a bit of lag.
Rolling with a Third-Party Adapter
Why even bother with an adapter? Well, gizmos like the XIM Apex or HORI Tac Pro are game changers—all your keyboard/mouse moves get translated into controller signals. Nice trick, but some folks might call foul for competitive games.
Getting set up:
  1. Jam the adapter into your PS4’s USB port.
  2. Link a trusty controller to the adapter (no entry without it).
  3. Hook your keyboard/mouse to the adapter.
  4. Follow any setup instructions for the adapter, like using a companion app to customize stuff.
Hits and misses:
  • ✅ Works with most games.
  • ❌ Could hit your wallet hard ($100+), might lag a bit, and could get you banned in competitive circles.
Running into Snags?
– Not catching a break with your gear? Could be incompatible hardware, a wonky USB port, or outdated PS4 firmware.
  • Try a new USB port or cable.
  • Let your PS4 get the latest software update (Settings > System Software Update).
  • If it’s Bluetooth, try wired instead.
– Lagging or just sluggish? Interference could be messing with Bluetooth, adapters might act up, or polling rates are getting overzealous.
  • Move closer—it might get rid of interference.
  • Dial down the mouse’s polling rate (check with your manufacturer’s software).
  • Try a USB hub with extra power for more gadgets.
– Certain games got you stuck? Developers might have blocked adapters or keyboard/mouse buddy-up.
  • Look for input settings in your game.
  • Hit up community forums for configuration hacks (Reddit or XIM forums could be handy).
Some Things to Mull Over
  • Gear Fairness: Rolling with keyboards/mice can give you a leg up in multiplayer games. Some games even split players up by device type.
  • Warranty and Risks: Using adapters can stir up trouble with Sony’s terms of service and might put your account at risk.
Here’s the Scoop
  • Just Browsing Around?: Stick with those USB/Bluetooth links for menus and games that play nice.
  • Got Serious Game Time?: Maybe shell out for adapters like the XIM Apex, but check the rules for your fave games to dodge the hammer.
  • Feeling Adventurous?: Peek at PS4-ready hybrids like the Logitech G502 Mouse or Razer Turret for console play.
Getting your PS4 to play nice with your keyboard and mouse isn’t all that tricky once you know the ropes—and now you’re all set to make it happen without running into any hiccups!
So, you want to hook up a keyboard and mouse to your PS4? No worries, I’ve got you covered. Whether you’re looking to improve your gaming setup or just typing up a storm in-game chat, here’s how to do it.
First off, let’s tackle the wired option. It’s as simple as pie, honestly. Start by firing up your PS4 and logging into your user profile. Then, hunt down those USB ports on the front of the console—usually at least two of them waving to you. Plug the keyboard and mouse in and bingo! Your PS4 should recognize them on its own—you might even try zooming around the menu to see if all is working just fine. And if you’re feeling fancy, head over to ‘Settings’ > ‘Devices’ > ‘External Keyboard’ to mix up your key repeat options.
Now, if you’re rolling with a wireless setup, it’s just as breezy. First, place your Bluetooth keyboard and mouse into pairing mode. You might need to check out your device’s manual if you’re scratching your head over that one. Then, slide over to ‘Settings’ on the PS4 home screen, and jump into ‘Devices’ > ‘Bluetooth Devices’. Your PS4 should hunt down available Bluetooth devices, and once your gear shows up, select ’em and they’re off to the races. A quick test by navigating the menu should confirm everything’s in tip-top shape.
Here’s a couple of tips if things start going sideways: Make sure your PS4 is updated—older models can be a bit picky with new gadgets. Restarting could be your saving grace too; reboot both the PS4 and your keyboard/mouse if connections seem to flounder. And hey, don’t forget to peek into your device manuals for extra help. Lastly, remember some games give keyboard and mouse inputs the cold shoulder. It’s worth checking the game documentation for compatibility.
By whipping through these steps, you’re all set to up your game on the PS4 with a keyboard and mouse setup. Happy gaming!
