How to Get Water Out of Microphone Iphone?
334 viewsPhone
So, your iPhone took a little swim and now the microphone sounds all wonky? Don’t worry, you’re not alone. Here’s how you can deal with that pesky water problem without any stress.
First things first, let’s figure out if there’s really water inside. Try laying your iPhone facedown on a soft cloth and give it a gentle tap. If you see any droplets sneaking out, bingo! We’ve got water in the house.
Now, here’s the kicker: your iPhone’s got a little secret weapon called the Shortcuts app. Most of us have it, but if it’s missing from your arsenal, you can grab it for free from the App Store. Hunt down a nifty shortcut called “Water Eject.” You’ll find it with a bit of online digging, then just click “Add Shortcut” to have it in your kit.
Got the shortcut ready? Cool! Open it up in the app, and once you fire it off, choose a high intensity. This will vibrate your phone speakers, shaking out the unwanted water from the mic. It’s like giving your iPhone a gentle shake dance.
Rather not mess with Shortcuts? No prob. There’s this app called Sonic that lets you move sound frequencies around to bump out the water. Or, head to websites like Fix My Speakers and let some tones work their magic.
After all that, find a cool, dry corner for your iPhone to chill and air out. Avoid the temptation to warm it up with a hair dryer or bury it in rice—that could end up causing more harm than good.
Finally, once your phone’s had a break, test the mic by making a call or recording a quick voice memo. If it’s not back to normal, you might have a bigger issue on your hands, and a trip to an Apple store could be on the cards.
A quick tip before I sign off: even though newer iPhones are splash-resistant, they’re not invincible. So, keep them dry whenever you can to save some headache down the line!
Oh boy, we’ve all been there! One moment your iPhone’s perfectly fine, and the next, it’s taken an unexpected dip in the water or caught a splash—thinking it’s waterproof like those fancy commercials say. Unfortunately, when water finds its way into the microphone, it can cause all sorts of trouble like muffled sound, weird noises, or worst-case scenario, the mic calling it quits. It doesn’t take much either; a dunk in the pool, caught in a downpour, even just over-humid weather can let moisture sneak into the mic ports.
So, first things first, switch off your iPhone. Now’s not the time for charging sessions or any accessory hookups—gotta keep away from any chance of frying the thing.
Let’s Do Some Shake and Dab Give your phone a gentle shake. Just a bit to help water drip out from those nooks and crannies. Have a soft cloth handy? Good! Use it to wipe around the microphone’s outer areas, but hands off poking anything into the ports—don’t risk damaging them further.
Get Those Ports Dry Okay, here’s a nifty trick: toss your phone in a box with silica gel packs or uncooked rice for a day or two (while you impatiently wait). These little guys are amazing at sucking out moisture hiding inside. If you’ve got some compressed air, aim it toward the mic—angled is best—to chase out any droplets clinging inside.
If drying tactics seem to hit a dead end, it’s time to check those Liquid Contact Indicators—find one by the SIM tray to see if it’s turned red, warning about moisture invasion. If so, a trip down to your nearest Apple Store or an authorized service shop might be on your to-do list.
Got a drying tool? Even better. These work like magic to zap moisture using special desiccants and soft heat—think of it as spa treatment for your phone. Then fingers crossed—record something or make a call to see if your microphone’s back in action. If it’s still acting up, drill down with the Voice Memos app to figure out which mic part is giving you grief.
Trust me on this, steer clear of bringing your iPhone into splash-prone zones like the pool. Apple’s waterproof claims are cool, but over time, that courage might dwindle. Plus, a waterproof case might be your best buddy when you know you’re going to splashy places—just make sure those mic spots have enough breathing room.
Little care goes a long way: grab a dry toothbrush now and then to brush off any dust or moisture lingering around the mic grilles.
Stop! What You Shouldn’t Do
  • Avoid cranking up the heat with a hairdryer, oven, or anything else that might warp your precious phone’s inner stuff.
  • Charging a wet phone is a big no-no—just puts it at risk for worse damage.
  • And unless you’re secretly Steve Jobs in disguise, trying to fix it yourself could turn a small problem into a big ol’ mess.
If it’s been two days and the mic’s still acting strange, it’s time to call in the pros—just in case things like corrosion have started creeping in.
Okay, so your iPhone got a bit too close to water and now the microphone’s acting up? No worries—I’ve got some tricks up my sleeve to help you out!
First things first: put that iPhone to sleep by powering it down. We’d want to steer clear of any short circuits, right? Then, grab a soft cloth and give the outside a gentle dab, especially near the microphone. No scrubbing—you’re not cleaning floors here!
Now, here’s the kicker: let gravity do its thing. Hold the iPhone with the microphone pointing downwards and tap the back lightly. Sometimes a simple tap can get the droplets moving.
Next up, you’ve got two options: the rice trick or silica gel packets. Just chuck your phone in a bowl full of uncooked rice or toss in some silica packets, and let it chill there for a day or two. It’s like a mini-spa for your phone but without the cucumber slices.
If you really want to kick it up a notch, there are apps or websites that play sounds at special frequencies to get rid of water. Trust me, it’s cooler than it sounds! Or, if you’re feeling adventurous, blast a high-frequency sound around 165 Hz for several minutes—you might play DJ and banish the water at the same time.
Oh, and stay away from any hairdryers or heaters. You’re looking to dry your phone, not roast it.
Still stuck? Honestly, sometimes it’s best to let the pros handle it. Swing by Apple Support or an authorized service center—they’ve dealt with enough soaked devices to fix yours.
Just remember these steps and avoid water dance-offs with your iPhone. Better safe than sorry, right?
