How to Get Out of Recovery Mode Iphone?
377 viewsPhone
So, your iPhone’s stuck in Recovery Mode. Ugh, annoying, I know. Basically, this feature is there to help with system updates or fixes when your phone’s on the fritz. Usually, you’ll see a screen with a computer icon and a Lightning cable or USB cable when you’re in Recovery Mode. At this point, your computer should recognize the device, and you’ll get the option to either “Update” or “Restore.” “Update” tries to reinstall iOS without erasing your stuff, while “Restore” wipes everything and gives you a fresh start.
A bunch of things could have landed you here:
  • Software Glitches: Like a botched iOS update or some rogue app causing chaos.
  • Hardware Issues: Maybe the buttons are busted, or there’s damage somewhere inside.
  • Weird Stuff: Connecting to a funky computer, or maybe the battery ran out at the worst time.
Let’s start with some button magic:
  • iPhone 8 and Later (including iPhone SE 2nd and 3rd Gen): First, unplug your phone from the cable. Quick-press the volume up button, then quick-press the volume down button. Hold down the side button until you see the Apple logo.
  • iPhone 7, 7 Plus: Unplug the cable. Hold the volume down and side buttons together until the Apple logo shows up.
  • iPhone 6s and Earlier (including iPhone SE 1st Gen): Disconnect the cable. Hold the Home button and top (or side) button simultaneously until the Apple logo pops up.
You can also go the software route:
  • iPhone 8 and Later: Connect to your computer and open iTunes or Finder. Quick-press the volume up, quick-press volume down, then hold the side button until the Recovery Mode screen appears. In iTunes or Finder, choose “Update” to reinstall iOS without deleting your data.
  • iPhone 7, 7 Plus: Hook up your phone to the computer, open iTunes, then hold the volume down and side buttons until the Recovery Mode screen comes up. Select “Update” or “Restore” as needed.
  • iPhone 6s and Earlier: Connect your phone, open iTunes, hold the Home and top (or side) buttons until you’re in Recovery Mode. Follow the prompts to update or restore.
Sometimes, you need a little extra help. Here’s what you can try:
  • AnyFix: Download the app and install it. Open it up, hit the “Enter/Exit Recovery Mode” button, then “Exit Recovery Mode,” and wait a few minutes.
  • PhoneRescue for iOS: Install the app, open it, pick “Device Rescuer,” and “Repair iOS System.” Connect your iPhone and follow the steps to get out of Recovery Mode.
A Few Tips:
  • Back Up Your Data: Just in case, because exiting Recovery Mode can sometimes mean losing data.
  • Use Good Gear: Make sure your USB cable and computer are in good shape and compatible.
  • Don’t Interrupt: During the update or restore process, keep your phone connected and let it do its thing.
If all else fails and your iPhone is still refusing to cooperate, it might be a hardware issue. You should probably visit an Apple Store or an authorized service provider. And, word to the wise—don’t force your phone into Recovery Mode unless you have to. Keep your iOS up to date and steer clear of sketchy apps.
Hope this helps, and good luck getting your iPhone back to life!
Trying to wrangle your iPhone out of recovery mode can feel like you’re dealing with a stubborn mule. But fear not, here’s a play-by-play to get you back on track without pulling your hair out.
Steps to Shake Off Recovery Mode
  1. Know Your Device: First things first, you gotta know your iPhone model because each has a slightly different way of behaving.
  1. Give It a Good Restart:
    • iPhone 8 and Up (includes SE 2nd gen and newer models):
      • Tap, then let go of Volume Up.
      • Tap, then let go of Volume Down.
      • Hold onto the Side button until the Apple pops up.
    • iPhone 7 and 7 Plus:
      • Hold down both the Volume Down and the Side button together until you spot the Apple logo.
    • Older Models (iPhone 6s, SE 1st gen, etc.):
      • Press and hold the Home and Top (or Side) buttons till you see the Apple logo blink at you.
  1. Hook Up to Your Computer:
    • If the restart trick doesn’t budge it, grab a USB and connect it to your computer.
    • Fire up Finder on macOS Catalina (10.15 or later), or iTunes if that’s more your speed.
  1. Spot the Recovery Mode:
    • Your computer ought to sound off that your device is hanging out in recovery mode. You’ll see a pop-up nudging this fact.
  1. Pick Your Poison: Update or Restore:
    • Now you’re faced with a choice: “Update” or “Restore”.
      • Think Update: This sneaky little option tries to bring iOS back without nuking all your stuff. Keep an eye out as your computer scores downloads.
      • If it doesn’t fly, hug “Restore” instead, though it’ll clean out your data to sort out deeper mess-ups.
  1. Go With the Flow:
    • You’ll get prompts from Finder or iTunes. Trust the process and follow whatever pops up.
  1. Kickstart Your Device:
    • After breaking free of recovery mode, your iPhone will reboot. Dive into setup or bring back a backup if you have one.
Some Friendly Tips
  • Double-check that your macOS or iTunes is up-to-date before diving in.
  • If things aren’t lining up, don’t sweat it—give Apple Support a holler.
Follow these moves based on your model, and you should see your iPhone spring back to life in no time.
How to Exit Recovery Mode on iPhone: A Comprehensive Guide
Let’s face it, recovery mode on your iPhone is not where you want to be. When your iPhone gets stuck in recovery mode, it’s usually because there was a hiccup with a software update or some other issue that’s keeping it from working like it should. If you’re finding yourself in this frustrating state, don’t worry—I’ve got some solutions that can help you out. Sit tight as we get to the bottom of the problem and stop the headaches once and for all.
What’s the Deal with Recovery Mode Anyway? Recovery mode is supposed to be our knight in shining armor for fixing major screw-ups in your iPhone’s software. Here’s the lowdown on why you might find yourself stuck in this predicament:
  1. A botched iOS update or restore due to flaky Wi-Fi or unplugging the phone before it’s done.
  2. Hardware problems like busted buttons or a charge port on its last legs.
  3. Jailbreaking shenanigans that throw everything into chaos.
  4. A corrupted software situation, maybe from a beta version gone rogue or clashing apps.
So, How Do You Get Out of Recovery Mode?
1. Force Restart Your iPhone
Sometimes all it takes is a good ol’ reset to get things back on track. Don’t worry—doing this won’t wipe your data. Here’s what to do depending on your iPhone model:
  • On iPhone 8, iPhone SE (3rd gen) & newer: Hit the Volume Up button, then the Volume Down, and press the Side Button until you see the Apple logo. Takes about 15 seconds.
  • For iPhone 7/7 Plus: Hold both the Side and Volume Down buttons until the logo shows up.
  • iPhone 6s and the older crew (including SE 1st gen): Press and hold the Home and Side/Top buttons together until the Apple logo graces your screen.
If everything works out, your phone will start up normally. But if it’s stubbornly returning to recovery mode, there are more tricks up our sleeve.
2. Try Updating or Restoring with Finder or iTunes
If your iPhone is ignoring the restart trick, it’s time to get the big guns—Finder or iTunes on a computer—to reload iOS:
Here’s what you need:
  • A computer (Mac with macOS Catalina or newer using Finder, or PC/Mac using iTunes).
  • A trusty USB cable (the official Apple one will be your best bet).
Here’s how you make it happen:
  1. Hook up your iPhone to your computer.
  2. Open Finder (on Mac) or iTunes (on Windows/older Mac).
  3. When given the choice, pick either Update or Restore:
  • Choose Update if you want to reload iOS without wiping your data.
  • Go for Restore if you’re ready to erase everything in exchange for a clean iOS start.
  1. Just follow whatever instructions pop up on the screen.
Here’s the kicker:
  • If updating doesn’t work, you’ll have to go the restore route.
  • Your computer needs to be online and have enough space.
  • Don’t forget to back up your stuff using iCloud or a local backup before you restore.
3. Consider Third-Party Tools If You’re Desperate
When traditional methods don’t cut it, tools like iMazing, Dr.Fone, or Tenorshare ReiBoot might be your saving grace. These bad boys offer stuff like:
  • Recovering from recovery mode with all your data intact.
  • Fixing those annoying boot loops caused by software glitching.
Try this example with Tenorshare ReiBoot:
  1. Get the tool downloaded and set up.
  2. Plug in your iPhone and click on Exit Recovery Mode.
  3. If it doesn’t work, switch to Standard Repair (keeping data) or Deep Repair (data gets wiped).
Reminder: Make sure these tools aren’t dodgy to avoid downloading malware.
4. Could It Be Hardware Trouble?
If your iPhone is persistent in recovery mode, you might be dealing with a hardware issue:
  • Give your charging port a once-over: Clear out gunk with a brush or some compressed air to make sure it’s clean.
  • Check out the buttons: Sometimes jammed or unresponsive ones can cause chaos.
  • Peek at battery health: If it’s below 80% capacity, it might be time for a new battery to avoid quirks.
Is a DFU Mode Restoration the Last Stop?
DFU Mode might be your last resort—it’s like your iPhone’s deep system refresh option. This method erases everything so brace yourself for that.
Here’s how you do it with an iPhone 8 or newer:
  1. Connect the iPhone to the computer and have Finder/iTunes ready.
  2. Quickly press Volume UpVolume Down, then hold the Side Button for 10 seconds.
  3. Let go of the Side Button but keep holding Volume Down + Side for 5 seconds.
  4. Release only the Side Button, keeping Volume Down pressed until Finder/iTunes detects the DFU state.
  5. Just follow the restoration prompts.
A Few Tips to Avoid Recovery Mode Snags
  • Quit interrupting iOS updates/restores.
  • Stick to stable Wi-Fi and use original cables.
  • Back up your data often, either on iCloud or your computer.
  • Think twice before diving into jailbreaking.
Calling in the Pros
If after all these hacks your iPhone still refuses to cooperate, it’s time to visit an Apple Store or a certified service provider. It might require a serious overhaul and some new parts to get it back on track.
Honestly, by following these steps without skipping a beat, you can usually fix this recovery mode mess on your own. But remember—having data backups at all times is like having a safety net when troubleshooting things like this.
So, your iPhone is acting up and stuck in recovery mode? No worries, here’s what you can do to get it back on track:
First up, if you’ve got a computer handy, hook your iPhone up to it. Depending on your setup, fire up iTunes (if you’re on Windows or macOS Mojave and earlier) or Finder (if you’re rocking macOS Catalina and later). Once your trusty iPhone pops up there, you’re gonna want to hit the ‘Update’ button. This little trick might reinstall iOS without wiping your stuff. Not having much luck with that? Hit ‘Restore’ to give your device a fresh start—it’ll burn everything back to default, though, so mind you.
Feeling a bit more hands-on? Try a force restart! Give the Volume Up a quick press, then the Volume Down. Hold onto the Side button, keep at it until you see the Apple logo—magic! If you’ve got an iPhone 7 or 7 Plus, you’ll wanna press both the Volume Down and Sleep/Wake buttons together. Or, if your iPhone is a tad older, go for the Home button and Sleep/Wake combo until you see that logo.
Now, if none of that’s working for you, there are loads of third-party tools out there—iMyFone Fixppo, Tenorshare ReiBoot, or Dr.Fone can be your best buds in scrapes like this. Just download whichever catches your eye, follow the instructions, and use their nifty ‘Exit Recovery Mode’ feature.
Still pulling your hair out? If you suspect it’s not a software thing, it could be hardware-related—Apple Support’s your next stop or pop into an Apple Store for the real experts to take a look.
There you have it! You’re armed with all the know-how to wrestle your iPhone out of recovery mode. Good luck!
