How to Get Minecraft on Oculus Quest 2?
337 viewsVR headset
Minecraft has become a global phenomenon, and with the increase in VR gaming, lots of players want to dive into it on their Oculus Quest 2. Here’s your step-by-step guide to making that happen:
Methods to Get Minecraft on Oculus Quest 2
1. Purchasing and Installing from the Oculus Store
  • Grab your Quest 2 headset or hop onto your computer and open the Oculus Store.
  • Type “Minecraft” into the search bar. You’ll spot two versions: Minecraft VR and Minecraft VR – Windows 10 Edition. Pick the one you like; the Windows 10 Edition comes with added perks like cross-platform play.
  • Hit the “Buy” button and after that, the game will be added to your library. Click on it and hit “Install” to get it onto your Quest 2.
  • Once it’s done installing, you can find the game in your Quest home menu and jump right in.
2. Playing Minecraft Java Edition in VR via Vivecraft
  • First, buy and install Minecraft Java Edition from minecraft.net.
  • Make sure your PC has Java installed. Open Windows Command Prompt and type in “java -version.” If it’s not recognized, download and install Java.
  • Head over to vivecraft.org and grab the latest stable version. Download the file labeled something like “vivecraft-x.xx.x-jrbudda-VR-x-x-installer.jar.”
  • Open the installer, bump up the “Profile RAM Allocation” to 4GB, close the Minecraft Launcher if it’s open, and then install Vivecraft.
  • Set up an Oculus Link/Air Link or Virtual Desktop connection. Keep your Quest 2 on and start “Minecraft Launcher” from your PC.
  • Make sure the “Vivecraft x.xx” version is selected and click “Play.” Soon, you’ll have Minecraft Java Edition running in your VR headset.
3. Sideload Minecraft Java Edition (2D) using PojavLauncher
  • First, enable developer mode on your Quest 2.
  • Download the PojavLauncher APK to your phone from its GitHub or the Google Play Store.
  • Install Bugjaeger from the Google Play Store on your phone.
  • Connect your Quest 2 to your phone using a USB cable and approve any connection dialogs.
  • In the Bugjaeger app, click the “+” icon, locate, and sideload PojavLauncher on your phone.
  • Unplug the cable, go to your Quest 2 apps, select “Unknown sources” and launch PojavLauncher.
  • Sign in to your account, hit “Play” to download and install your preferred Minecraft version. Keep in mind that not all versions work smoothly on Quest 2. Try different ones until you find a good fit, such as 1.12.2.
4. Using SideQuest to Install QuestCraft
  • Download and install SideQuest on your Windows PC from its official website.
  • Make sure your Oculus Quest 2 is connected to the internet.
  • Open SideQuest, log in with your Facebook or Instagram account, and create an organization. Use a 2FA authenticator to verify.
  • On your Quest 2, go to Settings > Device > Developer Mode and enable it. Restart your headset.
  • Connect the Quest 2 to your PC via USB, allowing any necessary USB debugging messages.
  • Click “Install SideQuest” from the SideQuest program on your computer.
  • After installing SideQuest on your Quest 2, go to your app library, select “Unknown sources” and open SideQuest.
  • Search for QuestCraft in SideQuest, hit the sideload button, and accept the permissions.
  • Once done, launch the app, log in with your Microsoft account linked to Minecraft Bedrock Edition.
  • Tweak the game settings to your liking and start playing!
Precautions and Tips
  • For a smooth wireless connection like Air Link, ensure both your PC and headset are on the same network. It helps to have your PC connected via Ethernet.
  • Be careful about the apps you sideload to avoid security risks.
  • Your Minecraft performance on Oculus Quest 2 can depend on your PC’s specs and network conditions. If you notice lagging, adjust the video settings in Minecraft or consider upgrading your Wi-Fi hardware.
Troubleshooting Common Issues
  • If your Quest 2 won’t connect to your PC, make sure both devices are on the same Wi-Fi network.
  • VR Minecraft controls can be a bit different, so give yourself some time to get used to them.
  • If the game crashes or has errors, try reinstalling it or checking for updates to both Minecraft and your Oculus Quest 2 firmware.
Minecraft on Oculus Quest 2 offers an incredible and immersive experience. Whether you go for the official Oculus Store versions or try alternative methods like Vivecraft or QuestCraft, you’re in for a fun ride into a whole new level of creativity and adventure.
Alright, so you’re itching to dive into Minecraft on your Oculus Quest 2? Let’s break it down step by step, no fuss. It all comes down to whether you’re into the Java Edition or Bedrock Edition of Minecraft. Ready? Let’s jump in.
For those vibing with the Minecraft Bedrock Edition, here’s what you need to get going:
1. Get Your PC VR-Ready: First things first, your PC’s gotta be up to the task because Bedrock Edition doesn’t roll solo on the Oculus Quest 2 just yet.
2. Load Up the Necessary Apps:
  • Download the Minecraft app from the Microsoft Store. Gotta have it!
  • Grab the Meta Quest app if it’s not already chilling on your PC.
3. Hook Up Your Headset:
  • Link your Oculus Quest 2 to your PC with a trusty link cable.
  • Fire up the Meta Quest app and make those links happen.
4. Fire Up Minecraft:
  • Look for Minecraft in your apps or give it a quick search, then just hit play. It should automatically switch into VR mode—easy peasy!
Enjoy Minecraft in glorious VR using Bedrock Edition, tailor-made for trips into virtual reality-land.
Now, if you’re more of a Java Edition kind of person, here’s the scoop:
1. Get Your Gear Sorted:
  • Make sure your computer can handle VR. You don’t want to miss a beat!
  • Install Java. Can’t run Java Minecraft without it, right?
  • Grab Steam and Steam VR—essential kit for this setup.
2. Snag Vivecraft:
  • Head over to the site and download Vivecraft. Simple.
  • Once you’ve downloaded, run the installer. Just be sure Java’s in place or it’ll be a no-go.
3. Connect That Headset:
  • Use a link cable to connect your Oculus Quest 2 to the PC.
  • Open up the Meta Quest app and enable that link magic.
4. Fire Up Steam VR:
  • Open Steam and chuck a launch to Steam VR while decked out in your headset.
5. Dive into Minecraft:
  • In Steam VR, hit up the monitor icon to check out your desktop. Then, load Minecraft. Choose Vivecraft from the version menu before launching it.
After these steps, you’re cruising through Minecraft in VR with some seriously cool immersive gameplay that lets you lose yourself mining and building.
Whether you’re groovin’ to the beats of the Bedrock or Java Edition, the key thing is to make sure everything’s set up and linked so you can enjoy a super smooth experience in Minecraft on your Oculus Quest 2. Happy crafting!
Getting Your Minecraft Fix on Oculus Quest 2
Alright, so you’ve got yourself an Oculus Quest 2 and you’re itching to play Minecraft in VR, but wait! The game isn’t officially supported on the headset. No worries, there are a couple of tricks to make it happen. Let’s dive in!
Official Ways to Get Going
Minecraft VR via Oculus Link/Air Link
Yes, Minecraft does have a VR version for PCs, and you can stream it to your Quest 2 using Oculus Link or Air Link. Think of it like borrowing your PC’s power for VR.
  • What You’ll Need:
    • A solid PC with Windows 10 or 11.
    • Either Minecraft Bedrock Edition for Windows or the Java Edition with Vivecraft mod.
    • The Oculus app on your PC, all set up with your Quest 2.
  • Steps to Follow:
    1. Get Minecraft installed on the PC.
    2. If you’re going Java: grab the Vivecraft mod for some VR magic.
    3. Hook the Quest 2 up to the PC with USB (Link) or go wireless with Air Link.
    4. Fire up Minecraft from the PC and it’ll creep into VR mode on your headset.
The Catch?:
  • You’ll need a pretty beefy PC.
  • Air Link might give you slight lag or hiccups.
Going Rogue: Unofficial Methods
QuestCraft: The Community’s Pet Project
Meet QuestCraft, a fan-built VR version of Minecraft Java, made just for the Quest 2 so you can go standalone.
  • Here’s How:
    1. Developer Mode Time!:
      • Sign up as a developer on Meta/Oculus site.
      • Flip the switch for Developer Mode in Quest 2 settings.
    2. Get SideQuest:
      • Download SideQuest, a nifty third-party app store, on your PC or phone.
    3. Bring on QuestCraft:
      • Sideload the QuestCraft APK using SideQuest.
      • Set it up with the required stuff like Java runtime.
    4. Fire It Up:
      • Open QuestCraft from Quest 2’s “Unknown Sources” menu.
      • Sign in with your Minecraft or Microsoft account.
Got Problems? Fixes Here!:
  • Lagging Like Crazy?: Tone down the render distance or use some lighter texture packs.
  • Games Crashing?: Ensure you’ve got the latest QuestCraft version and steady Wi-Fi.
App Lab Adventures
If you’re up for something less official, App Lab’s got you covered with games similar to Minecraft, like Voxel Works VR.
  • Step by Step:
    1. Head into the Oculus app or your browser.
    2. Search for your pick on App Lab DB (www.applabdb.com works wonders).
    3. Click “Download,” and voila, it’s on your Quest 2.
What Could Go Wrong? Troubleshooting
Network or Activation Snags
  • If sideloading gets stuck with network barriers, ensure your router can do UDP forwarding or get yourself a rooted phone/router for reliable use.
Hardware Drama
  • Your Quest 2’s XR2 chip and 6GB RAM should handle most games like a pro, but some ports might trip over themselves a bit. Close pesky background apps to free up muscle.
So, Why the No-show for Minecraft on Quest 2?
  • Licensing Fuzziness: Microsoft or Mojang hasn’t gone all out with a Quest 2 version.
  • Tech Challenges: Making Java Edition run on Android VR takes work, and it seems it’s low on their to-do list.
Wrapping It Up
  • PC Owners: Go for Oculus Link and Vivecraft for the prime experience.
  • Standalone Enthusiasts: QuestCraft’s your best bet, but get ready for the tech setup.
  • Casual Builders: Try App Lab finds like Voxel Works VR for straightforward block fun.
So, there you have it! Grab your headset, dive into those blocks, and enjoy Minecraft in VR without sweating the official stuff.
Hey there! If you’re itching to dive into Minecraft on your Oculus Quest 2, I’ve got the skinny for you. There are a few ways to get this rolling, so let’s dig right in.
First up: Oculus Link
  • Get Ready with Oculus Link: Before you start, make sure your PC’s got the horsepower to handle both Oculus Link and Minecraft. You gotta download the Oculus app on your PC too. Don’t skimp on the quality of your USB cable when connecting your headset.
  • Activating the Link: Pop on your headset and find the ‘Quest 2’ option from the Oculus Home. That’s where you’ll hit that link button.
  • Minecraft VR Setup: With the Oculus app open on your computer, go ahead and grab Minecraft for Windows 10. Fire it up from your Oculus library, and you’re good to go!
Now, let’s talk about SideQuest (if you’re feeling adventurous):
  • Kick Off with SideQuest: Head over to SideQuest’s website and nab the app. You’ll need to flip your Quest 2 into developer mode via the Oculus mobile app.
  • Plug and Play Minecraft: Use a USB cable to connect your Quest 2 to your PC, then let SideQuest do its thing to get Minecraft installed.
And for the wireless warriors: Virtual Desktop
  • Grab Virtual Desktop: You’ll need to snag Virtual Desktop from the Oculus Store. Make sure your PC’s got the Virtual Desktop Streamer app loaded.
  • Playing Minecraft VR: Once you’ve got Virtual Desktop open on your Quest 2, link up with your PC and launch Minecraft from there.
Honestly, the choice comes down to what flexes best with your setup and what jives with your style. So, pick the method that suits you and get ready to craft some epic adventures in VR!
