How Can I Get Call of Duty Out of Safe Mode on My PC?
568 viewsComputer
Alright, so you’ve got Call of Duty stuck in safe mode on your PC—what a headache! Don’t worry, we’ve got this. Here’s how to get it back to normal:
First up, give the game a kick in the pants with a restart: Close it down completely, then reboot your PC just to make sure everything’s fresh. Fire the game up again and see if it behaves.
Next, dig into the settings: Based on what your system can handle, tweak those graphics and display settings. After that, save and try restarting the game.
Now, if you haven’t yet, make sure your graphics drivers are all shiny and up-to-date: Head over to NVIDIA, AMD, or Intel’s website to grab the latest update. Once you’ve done that, restart your PC and cross your fingers.
Using Steam? Great! Hit Call of Duty in your library, go to Properties, and find Local Files. Tap on ‘Verify Integrity of Game Files’—it’s basically a game inspector for fixing any wonky bits. Once it’s done, try the game again.
You might want to clear out the game cache next: Poke around the Call of Duty installation directory—the ‘players’ folder is a good place to start. Wipe those configuration files, but make a backup in case you need them later.
If all else fails, you might have to bite the bullet and reinstall the game: Uninstall it from your control panel or game launcher, then download it fresh from where you originally got it.
By tackling these steps, you should be back to blasting with your buddies in no time. Still stuck? Your best bet might be to hit up the official support forums or customer service for more help.
  • Official Call of Duty Support
  • Steam Community Guides
Alright, so you’re stuck in Safe Mode in Call of Duty on your PC? No worries, it happens! Sometimes, when the game crashes or decides not to play nice, it jumps right to Safe Mode out of caution. Let’s get you back to the action.
First up, fire up the game and see if it’s stuck in Safe Mode. Assuming it is, wander over to your game settings once everything’s loaded. The graphics might be set to some default safe values; try tweaking them or resetting to see if it helps.
Next, if you’re on Steam, right-click on Call of Duty in your library, hit up “Properties,” then “General.” Take a look at those “Launch Options”—if you spot anything hinting at Safe Mode, like a “-safe” command, ditch it.
Now, let’s talk Windows. Hold down the Windows button and tap “R” to call up the Run dialog. Type “msconfig” and press Enter, and in the System Configuration window, snoop around the “Boot” tab. Make sure “Safe boot” isn’t inviting itself to the party. If it is, uncheck that bad boy, apply the changes, and restart your computer.
If none of these tricks help, it might be time to check your game files.
  • Go over to Steam, right-click Call of Duty again, and this time, head to “Local Files.”
  • Give “Verify Integrity of Game Files” a whirl—if there’s any funky business with corrupted files, Steam will sort them out.
Still stuck? Reinstall the game. It’s drastic, but sometimes a fresh start is just what you need.
Lastly, don’t forget to check for updates. Make sure your game and your graphics drivers are the latest versions. Sometimes an update is all it takes to shake things up.
Once you’ve got all that sorted, you should be good to go and back into the normal swing of gameplay. If Call of Duty keeps pulling this stunt after a crash or hiccup, give these steps another shot—a little adjustment in settings, launch options, or a fresh install might be the missing piece.
Happy gaming, and may your Call of Duty adventures go off without a hitch!
