How Can You Freeze Your Phone Screen for Tracing?
1.08K viewsPhone
Ever want to freeze your phone screen so it doesn\’t respond to touch? Whether you’re handing your phone over to someone else or binge-watching videos without interruptions, your phone’s got you covered. Both iPhone and Android phones have cool tricks for this. Let\’s dive in.
For iPhone (using Guided Access):
Okay, so if you have an iPhone, there\’s this nifty feature called Guided Access. It’s kind of like putting your screen in a time-out. Super handy for times when you want to keep your video rolling without any accidental swipe messing things up. Here’s how you get that set up:
  1. Pop open your Settings app, then go to General > Accessibility > Guided Access.
  2. \n
  3. Flick that switch to turn it on, and set yourself a passcode for extra security.
  4. \n
  5. Next time you want to lock that screen, just triple-tap your Home button (or the Side button for newer models).
  6. \n
  7. You can even tweak the areas you want to shut off. The whole screen or just a part of it—it’s up to you!
  8. \n
For Android (using screen lock or screen pinning):
If you’re rocking an Android, you’ve got a couple of ways to lock it down. For starters, a good ol\’ screen lock will do wonders. Here’s how you put that to use:
  1. Hit up your Settings and head into Security (or some similar section—depends on your device).
  2. \n
  3. Pick “Screen lock,” and decide whether you want a PIN, pattern, or password to keep things secure.
  4. \n
But hold on, there\’s more—to just keep one app on the screen, Android’s got this feature called Screen Pinning (fancy name, right?). It’s been around since Android 5.0, and here’s how you use it:
  1. Go into Settings, click Security > Advanced > Screen Pinning. Different devices might name it a tad differently.
  2. \n
  3. Switch on screen pinning.
  4. \n
  5. Find the app you want to hang out on. Tap the Overview button, swipe up on your chosen app, and hit the pin icon. This little trick locks all attention on your pinned app until you decide you’re done.
  6. \n
Summary:
So what’s the takeaway? If you’re an iPhone user, Guided Access is your trusty sidekick to limit those touches. Android folks, go with a screen lock or pin your screens to keep things on ice. Both options are baked right into the system, so you don’t have to go hunting for anything extra. Give these features a whirl next time you need to keep your screen behavior in check—that’s all she wrote!
Want to keep your phone screen from reacting to touch while tracing? Here’s how you can do it for both iPhone and Android devices:
Guided Access is your friend: This feature’s great for locking the screen.
  1. Head to Settings > Accessibility > Guided Access.
  2. Switch it on and set a passcode.
  3. Open the tracing app you’ve been itching to use.
  4. Triple-click the Home button (side button for newer models) to activate it.
  5. Hit Options at the bottom left, then toggle off Touch.
  6. Now hit Start and voilà, the screen is frozen!
If you’re curious about more nitty-gritty details, Apple’s got you covered with their support page.
Screen Pinning Helper: While it doesn’t freeze it completely, it locks it down to one app.
  1. Go to Settings > Security > dive into Advanced stuff > Screen pinning.
  2. Get it rolling by activating Screen pinning.
  3. Bring up the app you want and jump over to the Overview or recent apps.
  4. Tap on the app icon and pin it!
Need more intel? Peek into the Google help center.
Try Apps: There are apps galore on the Google Play Store that effectively freeze your screen, like “Touch Lock” and “Touch Blocker.” They pack some cool features, too.
Whether you’re using built-in features or third-party apps, keeping the screen steady for tracing has never been easier. Happy tracing!
So you want to freeze your phone\’s screen, huh? Let\’s dive into the nitty-gritty of it, whether you\’re trying to keep it still for a specific reason or just dealing with a device that\’s not cooperating.
Freezing the Screen on Purpose
Sometimes you just want your phone screen to stay put, like when you\’re showing something to friends or need to keep an image still. Here\’s how you can do it:
  • For Android Users: You can use something called \”Screen Pinning.\” Head to Settings, tap on Security, and find Screen Pinning. You\’ll want to toggle it to On. Once it\’s set up, open the app you want to pin, tap the Overview button (looks like a square), and pin it. Done! To unpin, hold the Back and Overview buttons together, or swipe up the regular way. Oh, there\’s also third-party apps like Touch Protector or Screen Locker that can help you keep the screen static.
  • For iOS Users: You\’ve got \”Guided Access\” at your disposal. Go to Settings, then Accessibility, and turn on Guided Access. Now open the app, triple-click the Side button, and set up your options. To get out of this mode, triple-click again and pop in your passcode.
When Your Screen Just Freezes Up
If your phone decides to freeze for no reason, it could be due to a bunch of reasons—maybe it’s had one too many apps running or it’s time for an update. Let’s hash out some common culprits and fixes:
Cause 1: A Buggy App or Software Glitch
  • Screen not responding while you’re on an app? Try a good old force restart. If you\’re on Android, hold Power and Volume Down for a bit. For an iPhone with Face ID, it’s a quick Volume Up, Volume Down, then hold Power. Home button models just need a Power + Home button squeeze.
  • Close out those background apps that are hogging all the memory.
  • Android has a Safe Mode that can help you troubleshoot and fix apps causing issues. Just hold Power until you see the shutdown menu, then long-press Power Off.
Cause 2: Software Isn’t Up to Date
  • Regular freeze-ups might be due to outdated software. Check for updates! Android folks, hit Settings > System > Software Update. For iOS, it\’s Settings > General > Software Update.
  • If things are still haywire, a factory reset might be your last resort. Just don’t forget to back up your stuff first!
Cause 3: Overheating or Physical Damage
  • If your phone heats up or shows physical damage, give it a break to cool down. Check if there’s anything visibly wrong, and if needed, head to a repair shop.
Cause 4: Malware Got In
  • Scan your phone with antivirus apps like Malwarebytes if weird things pop up or your battery drains too fast.
  • On Android, clearing the cache partition might help. Restart in recovery mode with Power + Volume Up and select Wipe Cache Partition.
Handy Tips to Keep Freezes Away
Keep your phone running smooth by not overloading it with apps, keeping everything updated, using original chargers, downloading apps from safe places, and making sure there\’s some free storage space.
By tackling both types of screen freezing—intentional and those annoying tech glitches—you\’re set. And if things don\’t get better, maybe it\’s time to ask a pro for help!
