What’s the Best Way to Fix a Scratch on My Computer Screen?
387 viewsComputer
So, you’ve got a scratch on your computer screen—bummer, right? Don’t panic! You might be able to fix it or at least make it less noticeable. Let’s dive into how you can tackle this common problem using good ol’ household items.
First things first, take a good look at the scratch. Is it just a surface thing, or are we talking about a major gouge here? If it’s the latter and affecting your screen’s performance, you might need a pro’s help. But if it’s just a minor scratch, there are a few tricks you can try on your own.
You probably have most of this stuff around your house:
  • Microfiber cloths: You’ll use these for cleaning and applying any fix-it materials.
  • Toothpaste (non-gel): The mild abrasives can help with shallow scratches.
  • Magic Eraser: A nifty cleaning tool that can work its magic on minor scratches.
  • Plastic polish: Good for screens and plastic surfaces.
  • Petroleum jelly: Can temporarily hide scratches.
Before you dive into repairs, make sure your screen is spotless:
  1. Power down the device and unplug it.
  2. Wipe the screen with a microfiber cloth dampened with a mix of distilled water and isopropyl alcohol (50/50). You want to get rid of any pesky dust or grease.
Toothpaste Magic
  1. Squeeze a dab of non-gel toothpaste onto a clean microfiber cloth.
  2. Rub it gently into the scratch using circular motions for about half a minute.
  3. Wipe off any extra toothpaste with a slightly damp cloth, then dry it with another clean cloth.
Magic Eraser Trick
  1. Slice off a small piece of Magic Eraser.
  2. Lightly dampen it (just a little, no need to soak it).
  3. Rub it gently over the scratch in circles until you notice improvement.
  4. Clear off any residue with a clean cloth.
Plastic Polish Portrayal
  1. Squeeze a bit of plastic polish directly onto the scratch.
  2. Use a soft cloth to gently buff it until things look better.
  3. Wipe away any excess polish with another clean cloth.
Petroleum Jelly Savvy
  1. Scoop a tiny bit of petroleum jelly onto your fingertip or a cotton swab.
  2. Rub it into the scratch until it looks filled and less obvious.
  3. Remove any extra jelly from around the scratch.
Once you’ve tried one or more of these methods, take a step back and assess:
  • Nice work if the scratch is less visible or seems to have vanished.
  • But, if things still aren’t looking great or if the scratch is messing with your screen’s clarity, it might be time to call in the repair experts.
These hacks might help you hide those pesky scratches on your computer screen. Just remember, they’re not foolproof solutions, especially for deeper scratches. If you’re hitting a wall, it might be worth bringing in a professional.
So, to recap: try out non-gel toothpaste, a Magic Eraser, plastic polish, or some petroleum jelly to manage those scratches and keep your screen looking its best.
Your Straightforward Solution to Fixing Computer Screen Scratches
Get the Scoop on Scratch Types
If you’ve ever found a scratch on your computer screen, you know it can totally ruin your day. These scratches usually fall into two types: those pesky surface-level marks (messing up the anti-glare coating) and deep-seated scratches (actually slicing into the screen itself). How do they get there? Well, here’s the deal:
  • You’ve accidentally jabbed your screen with keys, your favorite necklace, or even a stylus.
  • You thought you were cleaning it right, but you used a rough cloth or some gnarly chemicals.
  • Sometimes dust or debris lurking around during your cleaning spree can scratch it up something fierce.
Fixing Scratches: From Minor to Major
Tackling Minor Scratches
Got a light scratch? Here’s a couple of tricks up your sleeve:
Toothpaste Trick
  1. You’ll need: regular old toothpaste (no fancy whitening stuff), microfiber cloth.
  2. Here’s your plan of attack:
    • Squeeze out a pea-sized bit of toothpaste onto the cloth.
    • Circle around the scratch gently for a couple of minutes.
    • Wipe it all off with a damp cloth and dry it out. Side note: First try it on a small spot because some coatings can get a bit cranky.
Baking Soda Hack
  1. Mix up a paste using two parts baking soda and one part water.
  2. Rub it on lightly with a soft cloth, then wipe clean. Perfect for those annoying little scratches without detaching the oleophobic coatings.
Handling Medium Scratches
Time to bring out the big guns:
Commercial Kits to the Rescue
  • You might want to try Displex or Meguiar’s PlastX.
  • Follow the steps:
    • Get that screen clean with a microfiber cloth.
    • Use the solution and the tools that come with the kit.
    • Buff it till the scratch starts to fade. These kits often have UV blockers to make your screen look fresh.
Dealing with Deep Scratches
For the brutal ones:
Call in the Professionals!
  • Got an LCD/LED screen? You might need a new panel. Check in with your screen’s maker or a professional tech whiz for a price.
  • OLED screens are delicate creatures; DIY is a no-go here. Better let a pro handle it.
Steer Clear of Scratches
  • Screen Protectors: Slap on tempered glass or stick with anti-scratch films. Brands like 3M or Belkin have got your back.
  • Best cleaning practices? You bet:
    • Microfiber cloths are your screen’s best friend.
    • Say goodbye to ammonia-based cleaners; go for a gentle 70% isopropyl alcohol solution instead.
  • Storage tips: Close that laptop lid when you’re done and tuck it away in a padded case.
Time for a New Screen?
If your scratches are messing with what you can see or do (especially if you’re working with a touchscreen), it might be time to weigh fixing it versus just grabbing a replacement. Lots of budget-friendly options are out there if you need a new panel.
Busting Scratch Myths
  • Vinegar or Banana Peels: Forget about it. These old-fashioned go-tos can’t really get the job done and might even mess up your screen’s coating.
  • Magic Erasers: Definitely not magic when it comes to screens; they might make things even worse by peeling off protective layers.
Taking care of scratches now and then is key to keeping your screen looking great for years to come.
Dealing with a scratch on your computer screen can be a real headache. Thankfully, there are a few handy tricks you can try to sort it out:
First up, grab a trusty pencil eraser. Go ahead and gently rub it over the scratch, but make sure you’re moving in one direction to avoid making things worse. Once you’re done, just wipe away any eraser bits with a soft cloth.
Next, if you’ve got some petroleum jelly lying around, it might come in handy. Dab a little bit on a cotton swab and fill in the scratch with it. Be careful not to go overboard and wipe off any extra with a soft cloth.
For something more specialized, you can get yourself a screen repair kit. These are made for LCD or LED screens and can be found at your local electronics store. Just follow the instructions in the kit, and you should be good to go.
Now, if you’re into home remedies, mixing some baking soda with water to make a paste is another option. Rub it in gently over the scratch with a soft cloth, moving in circles, and then clean it all up with a damp cloth.
Here’s a heads-up: It’s a smart move to test any of these methods on a less noticeable part of your screen first. And if you’re ever in doubt or dealing with a big scratch, it might be time to call in a professional.
Hopefully, with these tricks up your sleeve, you’ll have your screen looking good as new!
