How Can I Fix the Camera on My Lenovo Laptop?
572 viewsLaptops
1 Answer
If your Lenovo laptop camera is acting up, here’s how you can sort it out:
First things first, dive into your camera settings. Hit Windows and I to jump into Settings, and then meander over to Privacy and hit Camera. Make sure Camera access for this device is turned up to On, and your apps aren’t being left out in the cold; they need to access your camera too.
Next up, let’s get those camera drivers fired up. Hit Windows and X to pull up Device Manager. Peek into Imaging devices or Cameras, right-click your camera, and do the whole Update driver dance. Choose to search automatically—easy peasy!
Oh, and there’s the BIOS check. Restart, press F1 or F2 (depending on your model), and enter BIOS. Find your way to the Config or Security tab. Make sure the Integrated Camera is all green-lit. Save your changes and bail out of BIOS.
If that doesn’t work, run the Windows troubleshooter, for a bit of extra support. Windows + I, then bop over to Update & Security, Troubleshoot, and scope out Additional troubleshooters. Pick Camera and let the troubleshooter do its thing.
Keep an eye on Windows updates. Windows + I again, then get into Update & Security and then Windows Update. Smack that Check for updates button and get your laptop on the latest and greatest updates.
Here’s another trick: reinstall the camera driver. Windows + X, then head back to Device Manager. Expand Imaging devices or Cameras, right-click, and uninstall your camera like a piece of junk mail. Restart your laptop and let Windows automatically reinstall the driver for you.
One more thing: just make sure no third-party stuff is blocking the camera, and see if the camera is playing nice with other apps. Sometimes it’s just the app being too finicky.
With these steps, you should see your camera snapping back to life on your Lenovo laptop.
