How Can I Fix My AirPod Pro If It’s Not Working on My PC?
427 viewsHeadphones
Alright, if your AirPods Pro are acting stubborn and won’t sync with your PC, it can be a real head-scratcher. But, don’t sweat it—I’ve got some tricks up my sleeve to get them purring along smoothly.
First things first: let’s make sure your PC’s Bluetooth is switched on. Half the time, it’s something simple that trips us up. Just hit the Windows key and ‘I’ at the same time to dive into Settings. From there, navigate to ‘Devices’ or ‘Bluetooth & devices’ depending on which version you’re rocking, and flick that Bluetooth switch if it isn’t already. If your PC is one of those that leaves you high and dry without built-in Bluetooth, grab yourself a USB Bluetooth adapter.
Now, another no-brainer: check if your AirPods Pro are well-fed with juice—like any gadget, they’re useless when dead as a doornail. Pop them into the charging case and let them sip on some power if needed. Keep that lid open while they’re snuggled inside.
For the next part, let’s get your AirPods into pairing mode. Open up the case and push that setup button at the back until the LED starts to do the disco with a white flash.
Right, now we’re cooking. Head back to your PC, open up Settings, yank on ‘Add Bluetooth or other device’, and select ‘Bluetooth’. Your AirPods should present themselves like eager party guests—might be seen as “AirPods” or “AirPods Pro.” Just click ‘Connect’ and you’ll get a little happy notification confirming the pairing.
Once your AirPods are connected, crank up some tunes or a podcast to verify that sweet audio’s making its way through. If you’re faced with fuzziness or other hiccups, don’t worry—the cavalry of extra troubleshooting steps is on the way:
  • If the plot thickens and your AirPods stay moody, let’s try to rekindle the link by forgetting them from your Bluetooth settings and going through the whole setup dance again.
  • A little tech TLC comes in the form of updating your Bluetooth drivers. Swing by the Device Manager from the Start menu, expand the Bluetooth section, and right-click your adapter to give it a driver-update makeover.
  • And hey, sometimes all the gears just need a fresh start. A quick reboot of your computer can work wonders, so hit that restart button.
  • For the brave souls out there, a little tweak under the hood in the Registry might patch things up. Type ‘regedit’ after hitting the Windows key + R and follow a breadcrumb trail down to the path: Computer\HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class{e0cbf06c-cd8b-4647-bb8a263b43f0f974}. Here, you can set up a new String Value named ‘PnPCapabilities’ and set the value to 24. A reboot will set this change in stone.
When all else fails, a reset might be the magic ticket. Place the buds back in their case, close the lid for a half-minute catnap, reopen them, and hold down the setup button until you spot an amber light followed by a white flash. Then, like before, go through the pairing steps.
Follow these steps like they’re an old map to buried treasure, and your AirPods Pro shouldn’t give you any more grief with your PC. With any luck, you’re back to enjoying your favorite tracks or podcasts without a hitch. Good luck!
If your AirPods Pro aren’t playing nice with your Windows PC, we’ve got a bunch of tricks that could help sort things out. You know how tech can be finicky sometimes, right? Here’s what you might try if it feels like your AirPods are having a bad day:
Alright, here’s the deal: Sometimes, outdated drivers or interference from other gadgets can mess things up when pairing. Let’s troubleshoot this:
  • Redo the Pairing Dance:
    1. Get those AirPods ready by opening the case lid and pressing the setup button till you see that white LED flashing.
    2. Head over to your PC’s settings:
    3. Go to ‘Settings > Bluetooth & devices > Add device > Bluetooth’. Pick out your AirPods from that list.
    In case they don’t show, make sure Bluetooth’s switched on your PC, and your AirPods are flashing white.
  • Clear Out Old Connections:
    1. Go to ‘Settings > Bluetooth & devices > Devices’.
    2. Find your AirPods Pro, hit that ‘⋮’ menu, and click on ‘Remove device’. Do the pairing jig again.
  • Are We Compatible?
    • If your Bluetooth adapter is a bit of a dinosaur (like version 4.0), it might struggle with AirPods. Try using a Bluetooth 5.0+ for smoother sailing.
Outdated drivers or your Windows version could be the sneaky culprits here:
  • Update Your Bluetooth Drivers:
    1. Open up the ‘Device Manager’ via the Start menu.
    2. Expand to ‘Bluetooth’, right-click your adapter, and select ‘Update driver’. Don’t forget to restart after.
  • Install Windows Updates:
    • Go dance through ‘Settings > Windows Update’ and grab those updates waiting to clear up any OS-level bugs.
If your audio setup isn’t working or the mic isn’t cooperating, here’s what you do:
  • Set AirPods as Your Main Device:
    1. Right-click the speaker icon in the taskbar and head into ‘Sound settings’.
    2. Pick ‘AirPods Pro’ under ‘Output’. You want them to be in charge of sound.
  • Mic Not Functioning? Let’s Check Permissions:
    1. Go snoop around ‘Settings > Privacy & security > Microphone’. Make sure your apps know you’re cool with them using the microphone.
If your AirPods’ fancy audio modes aren’t quite right, there might be some firmware gremlins at work:
  • Updating AirPods Firmware:
    1. Connect them to an iPhone or iPad.
    2. Check ‘Settings > Bluetooth > AirPods Pro > Info’ for the firmware situation.
    3. If they’re behind the times, hang out near your iOS device while they charge. They’ll catch up automatically.
  • Tweak the Audio Mode:
    • Jump into ‘Settings > Bluetooth > AirPods Pro > Noise Control’ on iOS and pick ‘Noise Cancellation’ instead of adaptive nonsense.
Your AirPods might need a power-up or the case itself could be causing headaches:
  • Charge Them Up:
    • Make sure both your AirPods and the case have juice. A dead case means no pairing fun.
  • Back to Square One:
    1. Pop the AirPods in the case, close for a spell (like 30 seconds), then open back up.
    2. Hold the setup button down for 15 seconds until you see amber, then white. Ready to re-pair!
If you’ve been messing with other devices or think there’s some funky software stuff happening, try this:
  • Reinstall Bluetooth Drivers:
    1. In ‘Device Manager’, uninstall the Bluetooth driver.
    2. Restart the PC, and see if it fixes things by automatically reinstalling it.
  • Windows Troubleshooter:
    • Stroll on over to ‘Settings > System > Troubleshoot > Other troubleshooters > Bluetooth’ for some automated fixing.
Quick Tips:
  • Avoid connecting AirPods to multiple devices at the same time — they like to stick with what they last connected to.
  • Try them on another device (say a phone) to see if the PC’s the problem.
When all else fails, Apple Support might be your lifeline. They could offer hardware servicing if needed.
Having trouble getting your AirPods Pro to play nice with your PC? Don’t sweat it—I’ve been there, and here’s what I’ve learned to fix the mess:
First things first, let’s talk about your Bluetooth settings. You gotta make sure the Bluetooth is switched on—head over to Settings > Devices > Bluetooth & other devices, and flip that switch to ‘On.’ If your AirPods are already listed, try a reconnection.
Then there’s the whole deal with Bluetooth drivers. I can’t count the times something’s gone haywire because of my old drivers. So, pop open Device Manager, find the Bluetooth section, right-click your adapter, and hit ‘Update driver.’ Let your PC do the heavy-lifting and find those automatically updated drivers for you.
Now, if resetting your AirPods sounds like a hassle, trust me, it’s worth the shot and takes barely a minute. Throw them in the case, close the lid, wait a tick, then press and hold the setup button on the back of the case for about 15 seconds until the LED does its amber-to-white flashlight dance. Fingers crossed, they’ll reconnect with your PC.
Another thing that could be the culprit—your sound settings. Make sure your PC knows the AirPods are the star of the show here. Right-click that sound icon in your taskbar, hit ‘Sound settings,’ and click AirPods Pro for sound output.
Sometimes removing and re-adding is the magic trick. Head to Settings > Devices > Bluetooth & other devices, chop the AirPods out of the list, cross your fingers, and try pairing them again.
It might seem like a no-brainer, but running Windows’ Bluetooth troubleshooter can be like waving a magic wand at tech problems. Find it under Settings > Update & Security > Troubleshoot > Bluetooth, and let it hunt down what’s messing with your vibes.
And don’t forget about firmware updates for your AirPods Pro. Pair the buds with your iPhone or iPad and give a quick scroll through Settings under Bluetooth to see if an update’s in the cards.
Adding a couple extra tips here—check other Bluetooth devices aren’t causing a party line jam, and if all else fails, give your PC a quick restart to clean the slate.
With these tips, you should be on your way to getting your AirPods Pro back on track. If you’re still stuck, swinging by the Apple Support website or digging into the manual could be just what you need!
