What’s the Best Way to Fix a Glitching Phone Screen?
305 viewsPhone
If your phone screen is acting up, it’s totally understandable to feel frustrated. Here’s the lowdown on what you can do to fix it.
First things first, figure out how serious the issue is. Is your screen just flickering occasionally, or is it constantly unresponsive? If the problem seems minor and only happens with a particular app, it might not be too serious. But if your screen is giving you trouble all the time, even when you’re not touching your phone, that’s a bigger deal.
Next, take a good look at your phone for any physical damage. Cracks or scratches could be the culprit.
So what can cause these screen glitches? Let’s break it down:
  • Software Issues
    • System Glitches: Sometimes an outdated or buggy operating system is to blame. Make sure your phone’s software is up to date. If it started after an update, maybe it’s worth rolling back.
    • App Conflicts: Some apps just don’t play nice. Try restarting your phone and see if it helps. If not, boot your phone in Safe Mode to figure out if a specific app is the problem.
    • Settings Gone Awry: Features like adaptive brightness can mess with your screen. Turn it off in your settings and see if that stops the flickering.
  • Hardware Problems
    • Water Damage: If your phone took an unexpected dip, turn it off immediately and dry it off. It might need a few days in a bag of rice or with some silica gel.
    • Physical Impact: Dropping your phone can damage internal components, so you might need professional help here.
    • Aging Hardware: Sometimes screens just wear out. If your phone’s old, a screen replacement might be your best bet.
For more advanced troubleshooting:
  • Clear Cache: Cached data can cause issues, so clear your phone’s cache regularly.
  • Reset Settings: If the problem persists, try resetting your settings to default. It won’t delete your data but can fix various issues.
  • Factory Reset: This is the last resort. Back up everything, then do a factory reset to wipe your phone clean.
After you’ve hopefully fixed the glitch, keep an eye on your phone to make sure everything’s working fine. Test it out thoroughly. And remember, to prevent future issues, keep your phone updated, avoid water and drops, and treat it with care.
Good luck!
Alright, so your phone screen is acting up, and it’s super annoying, right? Let’s see if we can sort that out. I’ve got some steps you can try to get your screen back to being as good as new, whether you’re rocking an iPhone or Android.
Okay, first thing’s first—this might sound obvious, but have you tried turning it off and on again? It’s amazing how many tech troubles a simple restart can fix. For Android, hold down the power button and pick “Restart.” On an iPhone, press and hold the power button along with a volume button till you see the slider, then bam, off it goes. Switch it back on by holding the power button again.
Next up, get your software up to speed. Old software can play all sorts of tricks with your screen, including flickering. Head into settings and update both your operating system and apps.
Now, if your phone’s acting up when using specific apps, they could be the culprits. Check if there’s an update waiting for those apps. Still having issues? Try uninstalling the troublesome app for a bit and see if that sorts it.
Here’s the kicker—adaptive brightness. It sounds fancy, but it can cause flickering because it keeps trying to adjust to the light around you. Adjust your settings by turning off adaptive brightness on Android or auto-brightness on iPhone, and see if that calms things down.
Another tip: blue light filters or night mode settings might screw with your display sometimes. If nothing else is working, give turning these off a try.
For you Android folks, booting into Safe Mode helps figure out if a third-party app is messing with your screen. Hold the power button, press “Power Off,” and select Safe Mode. If the problem vanishes, those new apps might be your problem.
Here’s one more trick for Android users—try disabling hardware overlays. It’s a tweak within Developer Options (which you’ll need to activate by tapping “Build number” under About phone seven times).
Feeling brave? If none of these tricks work, a factory reset might be what you need—but remember, this nukes all your data, so back up anything you can’t live without first.
If your screen still glitches like crazy, it might be time to call in the pros. It could be a hardware issue, so mosey on down to your nearest authorized service center for a check-up.
Honestly, sometimes these tech hiccups just need a little bit of detective work and a tad of patience. Hang in there!
If your phone screen is acting up, it can be quite annoying. The reasons behind it could range from software glitches to real hardware issues. Let’s dive into a bunch of causes and see what you can do about them.
Fix It Up!
Software Hiccups
  • What’s Going On: Sometimes, your phone’s software might be having a bad day due to outdated versions or some app on a mission to annoy you.
  • How to Sort It Out:
    • Give It a Good Restart:
      • iPhones: Quick hit on Volume Up → Quick hit on Volume Down → Hold that Side button till the Apple logo gives you a wink.
      • Androids: Hold onto the Power + Volume Down combo for about 10 to 20 seconds.
      • Works wonders without wiping your stuff out.
    • Get Your Software Up to Date:
      • Hop into Settings > General > Software Update (for iOS folks) or Settings > System > Advanced > System Update (Android users). Go on, hit that update button for some bug-busting action.
    • Back to Basics with a Factory Reset:
      • Save your valuable stuff first (Settings > [Your Name] > iCloud Backup or the trusty Google Drive).
      • Restore via Settings > General > Reset > Erase All Content and Settings (iPhone) or Settings > System > Reset Options (Android).
Hardware Headaches
  • What’s Going On: You might be dealing with some physical damage or components that’s crying for an update, especially in older buddies.
    • Take a Closer Look:
      • Look for cracks or weird spots on your screen. If you find any, you might need to call in the pros.
    • Time for a Screen Swap or Fix:
      • For iPhones/iPads, swapping out the Touch IC could save your touch from the evil flicker.
      • Go for certified repair shops so they don’t make things worse.
Outside Forces
  • What’s Going On: Crazy temperatures, magnetic accessories, or electromagnetic interference might be throwing your phone off track.
    • Keep your phone away from super cold or blazing hot places.
    • Steer clear of magnetic cases, chargers, or speakers around your device.
App Troubles
  • What’s Going On: Dodgy apps might mess with your screen while you’re using them.
    • Kick it into Safe Mode (Android: hit Power → long-press Power Off → tap Safe Mode; iOS: needs third-party tools).
    • Dump the app you just downloaded or clean out the cache (Settings > Apps > [App Name] > Storage > Clear Cache).
Keep Things Running Smoothly
  • Stay Updated: Keep your OS fresh and always opt for pro repair shops.
  • Protector Power: Tempered glass and rugged cases help fend off the mean physical damages.
  • Free Up Some Memory: Close those apps you ain’t using and cut down on what’s running in the background.
If you’re still dealing with the glitch monster after all this, it might be time to get serious help from an expert.
How to Fix a Glitching Phone Screen: Step-by-Step Solutions for iPhone and Android Users
A flickering or glitching phone screen can drive you up a wall, right? Here’s what you can do to tackle this issue on your iPhone or Android:
1. Restart Your Phone
Ever tried turning it off and on again? A good ol’ restart can kick those minor glitches to the curb. Power down your device, chill for a minute or two, and fire it up again.
2. Check for Software Updates
Sometimes, your phone just needs a quick software upgrade, you know? Updates pack in those bug fixes that might smooth things over.
For iPhone: Swing by Settings, tap General, then Software Update to see what’s new.
For Android: Head to Settings, then System, and look for System updates.
3. Adjust Brightness Settings
Screen flickering could be linked to how bright your screen is. Mess with those settings a bit.
Manual adjustment: Pop into Settings, go to Display, and find the Brightness setting.
Turn off auto-brightness: While you’re at it, try disabling auto-brightness.
4. Boot in Safe Mode
Your apps might be causing some trouble. Boot your phone in Safe Mode to sniff out the guilty ones.
For iPhone: Sadly, no direct Safe Mode here, but do give app isolation a shot.
For Android: Press and hold the power button, then hold down ‘Power off’ ’til Safe Mode pops up.
5. Clear Cache Partition (Android)
Clearing out the cache might fix things if corrupt data’s the culprit. Dive into recovery mode, choose ‘Wipe Cache Partition,’ and restart.
6. Perform a Factory Reset
If you’re desperate, a factory reset could be the answer. Just remember, it’ll wipe your device squeaky clean! Make sure to back up your stuff first.
For iPhone: Settings > General > Reset > Erase All Content and Settings.
For Android: Settings > System > Reset options > Erase all data (factory reset).
7. Check for Hardware Damage
Take a peek to see if your phone’s taken a hit. If problems hang around, hardware might be the villain. It could be time for an authorized service center visit where the pros can diagnose and repair.
Follow these steps and you’ll likely figure out what’s nagging your phone screen. But don’t hesitate to hit up a pro if things go south.
Sources:
Lifewire: How to Fix a Flickering Phone Screen
MakeUseOf: Is Your Phone Display Flickering? Try These 7 Fixes
