How Can I Easily Find the Model Number on My Dell Laptop?
503 viewsLaptops
Finding your Dell laptop model number might seem like a hassle, but it’s actually pretty easy once you know where to look. Here are some handy tips to help you out:
Checking the Physical Label on the Laptop
  • Bottom Cover: Flip your Dell laptop over and check the label on the bottom cover. This label usually has the model number, service tag, and express service code. You’ll often see the model number under something like “Model” or “Product.”
  • Keyboard Area: On some Dell laptops, especially those meant for regular consumers, you might find the model number near or above the keyboard.
  • Battery Compartment: If your laptop’s battery is removable, take it out and look inside the battery compartment for the model number.
Checking the Packaging and Documentation
  • Original Packaging: If you’ve still got the box your Dell laptop came in, check the label on it. The model number should be there with other specs.
  • Quick Start Guide: The Quick Start Guide that comes with your laptop also usually lists the model number.
Using Windows Settings and System Information Tools
  • Windows Settings: For those using Windows 10 or 11, click on the Start menu, type “Settings,” and hit the icon. Navigate to “System” and then to “About” on the left sidebar. Under “Device specifications,” you’ll see your laptop’s name and model number.
  • System Information Utility: Press the Windows key + R to open the Run dialog box, type “msinfo32,” and hit OK. Check the “System Model” entry in the System section for your model number.
Using Command Prompt
Press the Windows key, type “cmd,” and hit Enter to open the Command Prompt. Alternatively, you can right-click on the Start button and select “Command Prompt” or “Windows Terminal.” Then type wmic csproduct get name and press Enter. You’ll get your Dell laptop model in a simplified format. For more details, use wmic csproduct get name, identifyingnumber to get both the model name and the identifying number.
Accessing BIOS/UEFI
  • Restart Your Laptop: Turn off your Dell laptop and turn it back on.
  • Enter BIOS/UEFI: Quickly press F2 or F12 when the Dell logo shows up. This takes you to the BIOS setup utility.
  • Locate Model Information: In the BIOS menu, search for the model number, typically under the Main tab alongside the service tag.
  • Exit BIOS: After you note the info, select “Exit” to restart your laptop.
Using Dell SupportAssist for Home PCs Application
This Dell app comes pre-installed and helps with updates and trouble resolution. Open the application, and your product model will be displayed. If it’s not installed, you can download it from the SupportAssist for Home PCs page.
  • Type “SupportAssist” in the Search Box.
  • Select “SupportAssist” from the search results.
  • Your model number will be shown on the main screen of the application.
Using Device Manager
Press the Windows key + X and select Device Manager. Expand the “Computer” or “System” section to find your Dell laptop’s make and model.
Using Dell Command Update Utility
Download and install the Dell Command Update Utility. Run it, and it’ll automatically scan your computer’s details. Click on the system information icon in the top toolbar to see your model number and other hardware specifications. Easy peasy, right? Now you’re all set to find your Dell laptop model number no matter where it’s hiding!
Trying to figure out the model number for your Dell laptop? You’ve got several tricks up your sleeve! Dive into the device itself, explore some software options, or snoop around the settings of your system. Here’s how you can do this:
First off, take a gander at the laptop’s identification label. It’s probably hiding somewhere you wouldn’t expect, like under the bottom cover, inside the battery compartment (if you can remove the battery), or even around the screen or keyboard. If you spot something labeled ‘Reg Model’ or ‘Service Tag,’ you’re on the right track.
Now, if flipping your laptop upside down sounds like too much of a hassle, you can always give Windows settings a whirl. Just right-click on that Start button, and hit up System from the menu. For Windows 10, scan through the “Device specifications” section, and in Windows 11, it’s lurking nearby.
And here’s a nifty trick: Dell laptops often come with a built-in sidekick known as SupportAssist. Pull up your search bar, type in “SupportAssist,” and let it do its thing. Right on the home screen, you’ll find all sorts of info including the elusive model number.
If you’re in the mood to nerd out, get into the nitty-gritty with the System Information utility in Windows. Simply type “System Information” into the search bar, or have a go with Win + R, chuck in msinfo32, and hit Enter. Peep under “System Model” for what you need.
And look, if software’s not your game, jump into the BIOS for a direct approach. Give your laptop a restart and jam on the F2 key when the Dell logo pops up. If F2 doesn’t work, the Del or Fn + Esc might just be the hero you need. Navigate to General in the BIOS, where System Information will spill the beans on your hardware and model number.
Bottom line? Whether you’re flipping the device over or getting cozy with software tools, finding your Dell laptop model isn’t rocket science. Just follow these pointers, and before you know it, you’ll know every detail about your device like the back of your hand!
Alright, if you need to dig up the model number for your Dell laptop, there are a few handy ways to go about it. Trust me, it’s not rocket science.
1. Check it Out Physically
  • Bottom of the Laptop: Flip that baby over and take a peek at the label underneath. It’s usually lurking there with words like “Model” or “Model Number.” You might spot the service tag or express service code hanging around too.
  • Battery Compartment: If you’re dealing with one of those old-school laptops with a removable battery, power it down, pop the battery out, and have a look inside. There’s often a label hiding in there.
  • Original Box: Yep, that box you tossed in the attic might come in handy. It often flaunts the model number on a label next to the barcodes.
  • Documentation: Your purchase invoice, warranty card, or setup guide might have the model number printed too, just waiting for you to find it.
2. Get Techy with System Tools
  • Windows System Information:
    • Hit Windows + R, punch in msinfo32, and peek at the “System Model” field.
    • Or, you can open Command Prompt and give wmic csproduct get name a whirl. It’ll spill the beans on the model.
3. Dell Support Website
  1. Go to their site and punch in the service tag or express service code you grabbed from the label.
  2. Check out “Product Specifications” for the model number and the full scoop on your hardware.
4. Peek into BIOS/UEFI
  • Give your laptop a restart and slap F2 when it’s booting up to unlock BIOS. The model number is often sitting pretty on the main screen there.
Common Gremlins & Band-Aids
Scenario Solution
Worn/illegible label Switch to other tricks like checking the box, using system tools, or poking around in BIOS.
Device won’t power on Check out the original box or ferret around your warranty documents.
Invalid service tag Hit up Dell Support with the receipt if you need a hand verifying.
Extra Tidbits
  • Model vs. Service Tag: The model number is like saying “XPS 13 9315”—it tells you what product line you’re dealing with. The service tag, on the other hand, is your device’s one-of-a-kind ID for when you’re hollering at support.
  • Regional Nods: Some models have suffixes that change depending on the region, like “XPS 15 9520-xxxx”—it’s all about the variations.
Give these steps a whirl and you’ll be tracking down that model number in no time, whether you’re updating drivers, sorting out warranty stuff, or even planning some hardware tinkering. And if you’re stuck, those folks at Dell support have got your back.
Here’s the deal: finding your Dell laptop model number can be pretty straightforward if you know where to look. Let me walk you through some options.
First up, the trusty System Information tool. Just bop the “Windows” key and type in “System Information.” Crack open the app, and there should be a “System Model” listed right under the “System Summary.” Easy peasy.
Next, let’s talk about the BIOS/UEFI menu. When you restart your laptop, keep an eye out for the “F2” key—give it a tap during startup to slip into the setup menu. Most times, the model number shows its face on the main screen. Just like magic!
If you’re more of a hands-on person, flip the laptop over when it’s powered down and unplugged. Hunt for a label or sticker on the bottom, especially around the Dell logo or barcode. You’ll usually find the model number hanging out there.
Now, if online sleuthing is more your style, hit up the Dell support website. Type in your Service Tag—it’s on a label at the laptop’s bottom—and you’ll get a bunch of details about your model.
Don’t forget about the Dell Command | Update application. You can grab it from the Dell site, install it, and boom—it’ll toss out all sorts of system info, including your model number.
So, whether you’re troubleshooting, checking warranty info, or gearing up for upgrades, these methods should have you covered without breaking a sweat.
