How to Exit Book on Kindle Paperwhite?
458 viewsEbook
For many new Kindle Paperwhite users, figuring out how to exit a book can be tricky at first. Unlike other devices, the Kindle Paperwhite doesn’t show a visible close button once you’ve opened a book. But don’t worry! There are some simple ways to exit a book, which can really improve your reading experience.
Method 1: Using the “Home” Function
  • While Reading: If you’re currently in a book, tap the top of your screen to bring up the toolbar.
  • Select Home: Tap the Home icon (a small house) on the toolbar to go directly back to your Kindle’s home screen. Depending on where you opened the book from, you’ll see either a back arrow and Home or a back arrow and Library.
  • Confirm Exit: You’re now out of the book and can browse your library or get back to the book later. The Kindle will keep your place for when you return.
Method 2: Using the Back Button
  • Tap the Top of the Screen: This reveals the toolbar.
  • Find the Back Option: Tap the back arrow to move away from the current page. If your device has a physical back button, you can use that too.
  • Quit the Book: Keep tapping back until you reach the library or home screen. This is handy if you want to go back to a previous page or exit to the library.
Method 3: Using Sleep Mode
  • Set Sleep Mode: Briefly press the power button to put your Kindle into sleep mode while reading. The screen will turn off.
  • Confirm Screen Off: Note that this won’t fully exit the book but can be a quick way to pause your reading.
Method 4: Long-Tap for Menu Options
  • Long Press the Screen: While on any page in the book, long-press the screen.
  • Menu Access: A menu with several options will pop up, including a way to go back to the home screen.
  • Select Home: Choose the ‘Home’ option to exit the book.
Method 5: Restarting the Device
  • Restart the Device: You can also close a book by restarting your Kindle. Your book won’t reopen after the restart, making sure it’s closed completely.
So why can’t I close my book on Kindle Paperwhite the way I expect? Well, older Kindle models had options to rate or share the book or return to the home screen upon finishing. The Kindle Paperwhite has moved away from this, so you might need to get used to the new menu navigation. Also, watch out for the difference between tapping the top of the screen and swiping down. Tapping brings up the home option, while swiping down shows a different menu.
By getting the hang of these steps, you’ll find it a breeze to navigate away from your current read anytime.
Getting out of a book on your Kindle Paperwhite is a breeze. Here’s how you can do it:
First, make sure the book you want to leave is open—pretty straightforward, right?
Next, give the top of the screen a quick tap. This unlocks the Kindle’s menu, so you can fiddle around with different options.
Now, here’s where you want to pay attention: look for the back arrow icon in the top-left corner—your exit ticket.
Tap that arrow, and you’re off! Whether you started from the home screen or your library, this arrow will lead you back to where you came from. It’s like traveling back in time to your Kindle’s home base or library. The coolest part? Your progress in the book gets saved automatically! So don’t sweat it if you want to jump back in later; the Kindle makes it super easy.
If all else fails, you can reboot the Kindle, but that’s more like pulling the fire alarm for a minor inconvenience.
There you have it! With these tips, waving goodbye to any book on your Kindle Paperwhite is a no-brainer.
Hey there! So, you’re trying to jump out of a book on your Kindle Paperwhite? No worries, I’ve got you covered. Let’s get cracking with some super simple ways to do just that:
Jumping Out of a Book
  1. Getting Back to the Home Screen
    • Just tap the top bit of your screen until you see the toolbar pop up.
    • Find the little house icon on the top left—tap that guy, and boom, you’re back home!
  2. Take the Back Road
    • Again, tap the top side to bring up the toolbar.
    • Smash that back arrow (looks like it’s pointing left) and jump back to your last menu or the library view without saying goodbye to your book.
  3. Swipe It Out
    • Move your finger down from the top edge (above the screen) to open up the Quick Actions menu.
    • Hit “Home” to say “see ya” to the book!
If Things Go a Bit Haywire
Wonky Touchscreen
  • What’s Going On?
    • Could be software acting up.
    • Might be the screen’s lost its mojo.
  • Fixes I’ve Found Useful
    • Give It a Fresh Start: Hold the power button down for about 40 seconds—after the screen flashes, let go.
    • Force Refresh: Swipe down, go to “Settings,” then “Device Options,” “Advanced Options,” and hit “Force Restart.”
Toolbar’s Playing Hide and Seek
  • Why’s It Doing That?
    • You might have activated full-screen mode without even realizing it.
    • Could be your Kindle hasn’t gotten the latest update.
  • Quick Fixes
    • Turn Off Full-Screen Mode: Sometimes just keep tapping the top edge, or go through “Settings,” then “Reading Options,” and “Page Display” to switch it off.
    • Give Your Kindle a Makeover: Connect to Wi-Fi, go to “Settings,” then “Device Options,” “Advanced Options,” and click on “Update Your Kindle.”
Book Keeps Haunting the “Recent” List
  • Why’s It Stuck There?
    • The book file could be playing corrupt, or it’s just stubborn with indexing.
  • What You Can Do
    • Toss the Book: Just long-press the book cover from your home screen and choose “Remove from Device.”
    • Double-Check Indexing
      • Type &@?! in the search bar, hit enter—if it says “Text in Books (0),” you’re golden. If not, delete those pesky indexed books.
Handy Tips
  • Fast Track to Your Library: Swipe up from the bottom edge and look for the “Library” tab to jump in quickly.
  • Personalize Your Toolbar: Head to “Settings,” then “Reading Options,” and “Toolbar Location” to tweak things your way.
  • Library Books Got Your Back: If you’ve borrowed books via Libby or OverDrive, popping out of the book doesn’t mean you lose access—just look in the “Cloud” tab till the loan’s done.
Honestly, Kindle Paperwhite makes it easy for us, aiming to keep things distraction-free with its minimalist interface. Exiting a book doesn’t mean it’s gone for good—it hangs out in your library or the “Recent” list for quick access. And if tucked away issues keep bugging you, maybe go for a factory reset through “Settings,” then “Device Options,” and “Reset.”
Hopefully, this playful guide helps you navigate your Kindle like a pro, with a mix of cool tricks and known hiccups sorted. Happy reading!
If you’re trying to switch out of a book on your Kindle Paperwhite, here’s a quick rundown. First off, when you’re in the middle of reading, just give the top of your screen a little tap. That’ll pull up the reading toolbar.
At the top, you should spot a home icon — looks like a tiny house. Tap that and bingo, you’re back to your main menu.
Now, if the home icon is playing hide-and-seek, don’t sweat. Here’s plan B: Tap the top to bring back that toolbar, then hit the Menu button (those three dots). From the dropdown, pick ‘Home,’ and you’ll land right back on your Kindle’s main stage.
A couple of tricks in the back pocket: If your Kindle’s snoozing on that locked screen, a quick press of the power button wakes it up. Swipe to unlock, and you might pop straight back to home.
Also, keep your Kindle fresh with software updates. Just head over to Settings > Device Options > Advanced Options > Update Your Kindle. Updates can surprisingly smooth out navigation and toss in cool new features.
These tips should have you exiting any book like a pro and cruising back to your home screen in no time. For more help, check out the Amazon Help Center or dive into the Kindle User Guide. There you go, easy-peasy!
