How do you delete the ‘Shared with You’ feature on MacBook?
330 viewsLaptops
Trying to get rid of that pesky ‘Shared with You’ feature on your MacBook? Here’s how you can do it:
Switching it off in Messages:
  1. First, open up the Messages app.
  2. Head over to the menu bar and click on Messages, then tap Preferences.
  3. Find the Shared with You tab, and you’re almost there.
  4. Just uncheck the boxes for the apps where you don’t want that feature popping up. Easy as pie.
Turning it off in Safari:
  1. Fire up the Safari app.
  2. Navigate to the menu bar, choose Safari, and click on Preferences.
  3. Click on the General tab and scroll down a bit.
  4. There’s a section for ‘Tabs’—simply untick Show Shared with You. Problem solved!
A couple of things to keep in mind:
  • The feature is part of the newer macOS updates—Monterey and later. It lets stuff shared with you pop up in apps like Messages and Safari.
  • Turning it off helps keep things tidy and lets you focus only on what you want to see—no more digital clutter.
By tackling these steps, you can take back control and enjoy a more personalized vibe on your MacBook. It’s all about making technology work for you and not the other way around.
So you’ve got this “Shared with You” feature on your MacBook that\’s kind of cluttering things up, right? No worries, let’s tackle it head-on.
What’s the Deal with \”Shared with You\”?
Imagine your digital life spilling into all those native Apple apps—Photos, Safari, Music—through iMessage. This can be super handy but sometimes a bit too much to handle. Maybe it’s making your beautiful interface a bit of a dumpster fire? Or perhaps you\’re wrestling with privacy issues or just trying to save some space? I feel you.
Got Some Stuff to Clear Out?
Here’s the deal: If you want to chuck out the stuff you don\’t need anymore:
  • Photos App: Dive into Photos, hit up that “Shared with You” album, and zap anything you don’t need.
  • Safari: Swing open Safari, check out the Sidebar, and get rid of links in the “Shared with You” section.
  • Files App: Open up Files, head to iCloud Drive, find “Shared with You”, and toss those files into the Trash.
Quick tip: Keep in mind, what you delete doesn’t vanish from your iMessage threads and don’t forget to empty your Trash to reclaim that precious storage space!
Let\’s Talk About Stopping the Madness Altogether
Want to shut down this never-ending flow of shared stuff? You can manage that easily enough:
  • Pop open System Settings, hit up your Apple ID, head to iCloud, and find “Show All Apps Using iCloud”.
  • Turn off “Shared with You” for whichever apps you fancy. Be warned, this stops new stuff from appearing, old stuff isn’t going anywhere.
Overwhelmed? Time for Some Heavy Lifting
For those knee-deep in shared content, there’s a couple of ways to dig yourself out:
  • Third-Party Help: Apps like CleanMyMac or MacCleaner Pro work wonders for cleansing those redundant files.
  • Geekier Approach: Use Terminal commands if you’re up for some adventure or taking the scenic route.
Let\’s not forget about those pesky iMessage settings. Hop into Messages, find Settings, and uncheck apps where you\’d like to disable syncing altogether.
What if Things Go Sideways?
  • Things keep reappearing: Make sure you\’ve turned off syncing properly in both System Settings and Messages.
  • Storage acting stubborn: Check if the shared bits are hiding in your iCloud storage and manage it through “About This Mac”.
  • Permission Headaches: Double-check you’re logged in with the right Apple ID.
So there you go—a bunch of tips to take control of “Shared with You”. Just remember, the goal is to strike a balance between keeping what’s useful and ditching the rest. Happy decluttering!
Hey there! So, if you\’re trying to get rid of those shared files on your MacBook, here\’s a pretty straightforward way to do it. First things first, open up Finder. You know, the smiley face icon at the bottom of your screen? Click on that, and then look for iCloud Drive in the sidebar. Most shared stuff ends up there.
Now, once you\’ve got Finder open, hunt down the shared file or folder you want to ditch. They\’re usually hanging out in iCloud Drive or some shared folder.
When you find it, just drag it to the Trash – think of it like spring cleaning for your Mac. Or, if you\’re feeling fancy, highlight the item and hit Command + Delete. Confirm it when it asks if you\’re sure about tossing it in the Trash – it’s kind of like saying \’bye-bye\’ to unwanted clutter on your desk.
Here’s the kicker about who owns all this stuff: If you’re the one who actually owns the file and you dump it in the Trash, it’s game over for that file on everyone’s devices once you empty the Trash. But if you’re just a participant, tossing a file means it’s gone for everyone, though deleting the whole shared folder only makes it vanish from your own screen and not anyone else\’s.
Now, if you’re looking to permanently say goodbye to the file, take a peek inside your Trash. Click the Trash icon and choose \’Empty Trash\’ when you’re ready. But hey, if it’s something from iCloud Drive, the file might hang around for 30 days before disappearing, unless you’re quick to empty it.
And that’s basically it! You’re now uncluttering your shared folder on your MacBook like a pro. Just keep in mind what your role is with these files so you don’t accidentally turf them from everyone else’s views. See ya next time!
