How to Create A Desktop Shortcut on Mac?
771 viewsLaptops
On a Mac, “desktop shortcuts” are called “aliases.” It may seem a bit more complicated than on Windows, but it’s pretty simple once you get the hang of it. Here’s your go-to guide:
Creating an Alias for Applications
  1. Open Finder: Click on the Finder icon in the Dock to open it up.
  2. Navigate to Applications: In the Finder sidebar, pick the “Applications” folder.
  3. Find the App You Want: Browse through to locate the application you want a shortcut for.
  4. Create the Alias:
    • Right-click (or hold “Control” and click) on the app icon.
    • Choose “Make Alias” from the menu.
  5. Drag it: You’ll see a new alias in the Applications folder; just drag it to your Desktop.
  6. Rename It (If You Want): Click on the alias name and type a new one if it helps you stay organized.
Creating Aliases for Folders or Files
  1. Open Finder: Launch Finder from your Dock.
  2. Find What You Need: Navigate to the folder or file you’re after.
  3. Create the Alias:
    • Right-click (or “Control”+click) on the item.
    • Select “Make Alias” from the menu.
  4. Move It to Your Desktop: Drag the newly created alias to your Desktop.
  5. Rename It if Needed: Change the alias name if that makes things clearer.
Keyboard Shortcuts for Creating Aliases
  1. Using Command+L for Folders:
    • Go to your folder in Finder.
    • Press Command+L to create an alias in the same directory.
    • Then, just drag it to your Desktop.
  2. Using Command+Option for Files:
    • Hold down the Command and Option keys while dragging the file or folder to the Desktop. This action creates an alias right there without needing the context menu.
Drag and Drop Method
  1. For Applications: Open Finder and head to the “Applications” folder. Drag the app to the desktop; a small arrow will appear on the app icon, showing it’s a shortcut.
  2. For Files: Locate the file in Finder, right-click, select “Make Alias,” and drag the alias to the desktop.
  3. For Folders: Do the same as above for folders.
Using Terminal for Shortcuts
  1. Open Terminal.
  2. Type the command: ln -s /path/to/original/file/or/folder /path/to/symbolic/link.
  3. Replace /path/to/original/file/or/folder with the actual path of the item you want the shortcut for.
  4. Replace /path/to/symbolic/link with where you want the shortcut to go.
  5. Press Enter—that’s it!
Making Aliases from the Dock
Some apps can be aliased directly from the Dock. For instance, with Chrome, you can open Finder, go to “Applications,” select Chrome, hold the Option + Command keys, and drag Chrome to the desktop for an alias.
Creating Website Shortcuts
  1. Open your web browser.
  2. Go to the website you want.
  3. Resize the browser so you can see your desktop.
  4. Drag the URL from the address bar to the desktop. This will create a WEbloc file named after the site.
Notes
  • Every shortcut has a little arrow on the bottom left corner.
  • They still work even if you move the original item. Right-click on the shortcut and select “Show Original” to find it.
  • To delete a shortcut, either drag it to the Trash or right-click and select “Move to Trash.”
And that’s it! Creating shortcuts on your Mac is a breeze once you know the ropes. Hope this helps!
Ever find yourself digging through folders just to open that one file or app you always use on your Mac? It can be a bit of a hassle, right? Well, lucky for us, creating shortcuts (or aliases as they call them on Macs) is a breeze. So, let’s jump into how you can set this up and keep things nice and tidy on your desktop.
Getting Started: First thing’s first, crack open your Finder. You know, that smiley face icon hanging out in your Dock? Just give it a click—easy peasy.
Track it Down: Next up, hunt for the file or app you want easy access to. You’ve probably got it stashed away somewhere in your folders, so have a dig around.
Make That Alias: Now, here’s the part where you actually whip up the shortcut. There are a few ways to go about it:
  • Menu Method: Highlight your item, head up to the menu bar, click on ‘File,’ then hit ‘Make Alias.’ Boom—instant duplicate.
  • Right-Click Route: Prefer using that trusty mouse? Right-click or Control-click on your item and choose ‘Make Alias’ from the options.
  • Keyboard Ninja: Feeling techy? Just highlight and slam down Command + L. Done like dinner.
Whisk it to the Desktop: Here’s where you get to move the alias to your desktop. Just drag and drop it over there—or if dragging isn’t your style, copy with Command + C and paste with Command + V. No sweat.
Name it Your Way: Want to rename the alias? Sure thing! Click on it, hit Enter, type away, and hit Enter again. Make it yours.
Give it a Go: Alright, moment of truth—double-click that alias and see if it leads you back to the original file or folder. You got this, and remember, the little arrow means it’s an alias, like a little loyal puppy dog leading the way.
Some Extras: Got web shortcuts in mind? Drag that URL from your browser right to your desktop. And hey, no worries—aliases stay linked even if you move the original item around.
What matters most is having those shortcuts right where you need them. By following these steps, you should be set up to glide through your work without the constant file hunt. Cheers to making life a bit easier!
Hey there! If you’ve switched over to using a Mac and you need to whip up a desktop shortcut (Mac folks call it an “alias”), you’re in luck! Macs do handle shortcuts differently compared to Windows, but once you get the hang of it, it’s pretty straightforward. Here’s the skinny on it.
Time to Get Acquainted with macOS Shortcuts
  • Aliases vs. Windows shortcuts: Just a heads up, Mac uses “aliases,” which are nifty little pointers to your files or apps. Unlike Windows shortcuts, losing an alias won’t decimate your original file. Pretty sweet, right?
  • No clutter rules: Macs aren’t big fans of desktop chaos, so they suggest using the Dock or Finder sidebar for shortcuts instead. But if you’re a rebel, desktop aliases are totally doable.
How to Make Desktop Shortcuts
Create a Shortcut for Apps
Method 1: Drag-and-Drop from Finder
  1. Hit up Finder and find the Applications folder.
  2. Scout out your app (like Safari).
  3. Hold ⌘ (Command) + Option while dragging that app to your desktop.
    • Why it works: The ⌘+Option combo? That’s the magic spell for making an alias, not moving the app.
Method 2: Use the Right-Click Menu
  1. Right-click or Ctrl-click the app in Applications.
  2. Pick Make Alias (it’ll show up in the same folder).
  3. Just drag that alias over to the desktop.
Method 3: Dock It, Baby
If you want quick access, just pull the app over to the Dock’s right side (right by the trash can).
Shortcut for Files or Folders
Method 1: Quick Alias
  1. Give a good ol’ right-click on the file/folder.
  2. Choose Make Alias (it’ll create an alias where it is).
  3. Scoot the alias over to your desktop.
Method 2: Keyboard Shortcut
  1. Select your file/folder.
  2. Hit ⌘ + L, presto, alias made.
  3. Move that alias to the desktop.
Method 3: Drag and Drop with Keys
Hold ⌘ + Option while dragging your file/folder to the desktop to get an alias.
Create Shortcuts for Websites
Using Safari:
  1. Open the website in Safari.
  2. Take the tiny website icon left of the URL and pull it onto the desktop.
    • Heads up: This makes a “.webloc” file that, when double-clicked, opens the site in Safari.
Using Chrome:
  1. Hit the three-dot menu > More tools > Create shortcut.
  2. Tick Open as window (if you fancy) and tap Create.
    • Limitation: Chrome puts these shortcuts in the Applications folder. You’ll have to pull them onto your desktop.
Sorting Out Common Problems
Issue: “Alias Not Working”
  • Why it happens: Maybe the original file/app has been shifted or got renamed or deleted.
  • How to fix:
    1. Right-click the alias > Get Info.
    2. Under General, smash the Select New Original button to relink it.
Issue: “Can’t Drag Apps to Desktop”
  • Why it happens: macOS is picky, it won’t let you drag from Launchpad.
  • How to fix: Go to the Applications folder via Finder, not Launchpad.
Issue: “No ‘Make Alias’ Option”
  • Why it happens: System-protected file? Yeah, you might be hitting a wall.
  • How to fix: Pop the file into a folder you own, then make an alias.
Extra Tips for Shortcut Buffs
  • Manage Your Aliases: Use Stacks to keep your desktop organized (right-click > Use Stacks), keeps those aliases in line.
  • Get Techy: For advanced users, create a symbolic link through Terminal:
-s /path/to/original /path/to/desktop/shortcutname
The Mac Philosophy on Shortcuts
macOS likes to keep it clean and intuitive. Aliases skip the whole data duplication dance, while letting you keep everything flexible. For stuff you use often, Dock shortcuts or Finder Favorites are where it’s at.
Follow these steps and you’ll be styling with Windows-like shortcuts while grooving with macOS vibes.
Want to whip up a desktop shortcut on your Mac? It’s super handy for quick access to your go-to apps, files, or folders. Let’s dive in:
First up, if you’re all about shortcuts for your apps, do this:
  • Pop open Finder by clicking its icon on the Dock.
  • Cruise over to ‘Applications’ on the sidebar.
  • Spot the app you can’t live without.
  • Grab its icon and drag it to your desktop to make a shortcut—it’s literally that easy!
Now, onto shortcuts for files or folders:
  • Track down your file or folder in Finder.
  • Right-click (or Control-click) the item and pick ‘Make Alias’.
  • Just drag this alias to your desktop. Feel free to rename it so you won’t have to scratch your head later.
What about keyboard shortcuts? Here’s the lowdown:
  • Locate your item in Finder.
  • Hold down Option and Command as you drag it to the desktop—shortcut made in a snap!
Here’s the kicker, if you’re not into cluttering your desktop:
  • Instead, drag apps onto the Dock for easy access.
  • And for those who love a good challenge, try Automator for making some cool custom shortcuts.
Stick with these steps, and you’ll have your faves ready to roll on your desktop. Need in-depth details? Swing by the official Apple Support page and they’ll have you covered.
