How Can I Connect My Switch to a PC Monitor Without a Dock?
407 viewsGame Console
So you’ve got a Nintendo Switch and want to hook it up to your PC monitor, but don’t have the dock? No worries, you can make it work with a few handy gadgets.
First up, let’s talk about your monitor. Check what kind of inputs it has. If there\’s only an HDMI port, you’ll need a trusty USB-C to HDMI adapter. Tons of gamers have had success with adapters like the RREAKA USB Type C to HDMI Digital AV Multiport Hub. This can give you the ports you miss from the dock.
Now, if you happen to have one of those swanky new monitors with a USB-C port that does DisplayPort Alt mode, you\’re in luck. A good USB-C cable can handle both charging and video output with this setup.
Next on the agenda, grab yourself a compatible adapter or cable. Make sure the adapter includes a USB-C input for power, so your Switch doesn’t go flat in the middle of an intense gaming session. If you’re sticking with a USB-C connection, double-check that the cable and monitor can handle video output and provide enough juice—usually somewhere between 7.5W and 39W.
Here\’s the fun part: setting up the connection. If you’re using HDMI, you’ll need to:
  • Plug the USB-C to HDMI adapter into your Switch.
  • Connect the HDMI cable to your PC monitor.
  • Hook up the power to the adapter’s USB-C input.
  • Turn on your monitor and flick it over to HDMI input.
For those with a USB-C setup, just connect your Switch directly to the monitor with a USB-C cable that handles both video and power. Make sure your monitor’s USB-C port is set up to give a video signal.
Now, let’s move on to sprucing up your Switch setup. Get a stand or something to keep it from overheating since it\’s sort of in a half-undocked state. Fire up the Switch, and you should see the magic happen on your monitor. No compromises on your gaming controllers—Joy-Cons or a Pro Controller work just fine.
A couple of parting thoughts: If your screen stays stubbornly blank, double-check your monitor specs to make sure it supports everything it\’s supposed to. Also, make sure all your cables are willing to play ball with audio and video signals.
So, that’s the lowdown on getting your Switch chatting with a PC monitor sans dock. Whether your dock’s MIA or you just want to travel light, this setup\’s got you covered. Happy gaming!
Wondering how to hook up your Nintendo Switch to a PC monitor without its dock? Don’t worry, it’s easier than you might think. Here’s how you can pull it off:
Go-to Method: USB-C to HDMI Adapter
Sometimes, the simplest solutions are the best ones. Grab yourself a solid USB-C to HDMI adapter that won’t let you down, like the trusty Anker USB-C to HDMI Adapter. Here’s what you do:
  • Get the Right Gear: First up, snag a USB-C to HDMI adapter that’s up to the task.
  • Plug It In: Pop the adapter into the USB-C port at the bottom of your Switch.
  • Connect the Cables: Use a quality HDMI cable to link your adapter to the PC monitor.
  • Power It Up: Keep your Switch juiced up by attaching it to its charger.
  • Switch the Input: Flip your PC monitor over to the correct HDMI channel, and you’re golden!
Another Cool Option: Portable Monitors
If you’re more of a travel-light kind of person, portable monitors may be your jam. Some of these nifty devices come with USB-C ports, making life a whole lot easier.
  • Find the Right Fit: Look for a portable monitor that plays nice with USB-C video—Gechic has some good ones.
  • Connect Directly: Use a USB-C cable to marry the Switch and the monitor directly.
  • Juice Them Up: Make sure both gadgets have enough power. You might need to plug the monitor in, too.
  • Tweak Your Setup: If needed, switch the monitor to its USB-C input mode.
Both options let you ditch the dock and keep gaming. Just make sure your gear is top-notch so you avoid any hiccups. If you’re curious about which adapters work best, checking out some tech reviews can be super helpful.
So, you want to connect your Nintendo Switch to a PC monitor without using its official dock, huh? I get it, sometimes you just want to keep things light and simple. Let\’s dive into the nitty-gritty of getting your setup going.
The Hiccups and Hang-Ups
First off, we\’ve got two main stumbling blocks to tackle. Number one: the Switch doesn’t play nice with HDMI straight out of the box. And number two: you need to keep the lights on while you\’re playing, meaning charging and display have to happen simultaneously.
Your Go-To Methods
USB-C to HDMI Adapter Magic
This is by far the easiest trick in the book. An adapter like the UGREEN or Baseus saves your day. Grab that adapter, plug it into the Switch’s USB-C port, connect an HDMI cable between the adapter and your monitor, and don’t forget to hook up some power to the adapter. Boom, you’re in business.
Going High-Tech with a Capture Card
If you’re the type who’s into streaming or if your monitor just hates HDMI, then a capture card\’s your bestie. Pick up a capture card like an Elgato, connect your Switch via an adapter to it, and plug it all into your PC. Then, open up some software like OBS, and you’re ready to show off your gaming chops.
Compact Docks to the Rescue
Tired of the bulky official dock? Try a portable one, something like the Genki Covert Dock. The setup is pretty much the same as with the USB-C adapter, but with the perk of a travel-friendly size. Just be cautious about going for really cheap ones—no one wants a fried Switch.
Common Bumps on the Road
  • If you’re facing a blank screen, check if everything’s HDMI 1.4 or above and double-check those cables.
  • No sound? Plug into the audio jack of your monitor or mess around with OBS settings.
  • If it’s not charging, make sure you’re using a power source that’s up to snuff.
Wrapping Up with a Personal Touch
To keep it real, the USB-C adapter is your simple solution if you’re just looking to play. Streamers might lean towards capture cards, while portable dock fans will appreciate the travel ease. Just make sure whatever you buy works with your setup.
And there you have it—a down-to-earth guide to get your Switch on a monitor without the official dock, tackling the tech challenges with some easy solutions. Let me know if there’s anything else you’re curious about!
