What’s the Best Way to Connect My Ring Doorbell to Google Home?
354 viewssmart home devices
Hooking Up Your Ring Doorbell to Google Home
Trying to get your Ring Video Doorbell to play nice with Google Home? You’re in the right place. This guide will walk you through the setup so you can keep an eye on your doorstep without breaking a sweat.
First things first, check if your Ring device gets along with Google Home. They can work together using the Google Assistant, but don’t expect all the bells and whistles you’d get with Alexa.
Buckle up with:
  • A Ring account (make sure you can log in).
  • A Google account (the same one hooked to your Google Home).
  • The Google Home app on your phone or tablet.
  • The Ring app on your phone or tablet.
Open the Google Home app on your gadget.
  1. Hit that little + icon in the top corner.
  2. Pick Set up device from the list.
  3. Go with Works with Google.
  1. Type in “Ring” in the search and pick it from the options.
  2. Log into your Ring account when prompted. Pop in your details.
  3. Give Google Home the thumbs up to get access to your Ring gear by following any on-screen instructions.
Once you’re logged in, you’ll see a lineup of Ring devices linked to your account. Select the ones you want Google Home to manage and lock in those choices.
Now that you’re set up, try out some voice commands through Google Assistant. You might say:
  • “Hey Google, show me my front door.”
  • “Hey Google, ask Ring about my last visitor.”
Okay, here’s the kicker. While you can do some neat stuff like getting notifications and checking battery levels, there are a few hiccups:
  • You won’t be able to stream live video from your Ring directly on a Google Nest Hub or Chromecast-enabled TV.
  • No two-way talk through Google Assistant—that’s more of a thing with Alexa.
If you’re itching for full functionality with video streaming and chit-chat features, you might want to mull over getting a Google Nest Doorbell as they mesh perfectly with Google’s setup.
By following these steps, you’ll have your Ring Doorbell hooked up to Google Home, giving you slick control over your home security setup.
-1
So, you want to hook up your Ring Doorbell to Google Home, huh? Well, the road isn’t exactly smooth since these two don’t get along as well as you might hope. It’s mostly a one-sided relationship with Alexa getting all the love from Ring, but hey, we can work with what we’ve got. You’ll be able to use voice commands and get some notifications—better than nothing, right?
Stuff You Need to Know First
When it comes to pairing Ring with Google, the compatibility is, let’s say, not exactly where we’d like it to be. You’re not gonna see any live video feed on your Google Home Hub screen like how you do with Nest stuff. Instead, we’re talking audio alerts and using your voice to arm or disarm it. Let’s check out a few hiccups:
  • No native Google Home app support, only Google Assistant
  • Limited to audio alerts and voice commands
  • You’ll need to link your accounts through a third-party setup
Let’s Get Those Two Talking!
  1. Get Ready
    • First, make sure your Ring Doorbell is installed and already on the Ring app.
    • Update your Ring and Google Home apps because outdated apps can make things tricky.
    • Double-check that both your Google Home and Ring gadgets are chilling on the same Wi-Fi wavelength.
  2. Link Up the Accounts
    • Open up your trusty Google Home app → tap that big + sign → Set up deviceWorks with Google
    • Do a little search for “Ring” in services
    • Log in with your Ring account info when prompted
    • Hand over those permissions for device access and notifications
  3. Sort Out Your Voice Commands
    • Set up custom routines like:
      • “Hey Google, show front door” → Action: Ask Ring to show front door
      • “Hey Google, arm Ring” → Action: Ask Ring to arm security system
    • Turn on those doorbell notifications:
      Open Google Home app → SettingsNotificationsDoorbell Alerts → Toggle that on
Uh-oh, Here’s What Can Go Wrong
1. Can’t Find Ring in Google Home
  • Cause: Firmware outdated or maybe you’re stuck in regional red tape
  • Fix:
    a. Check for updates in the Ring app
    b. Ensure your Ring account region lines up with the country settings of your Google account
    c. Reinstall both apps if that’s not cutting it
2. Notifications Aren’t Coming Through Fast Enough
  • Cause: Network drag or your smart home setup’s a mess
  • Fix:
    a. Separate Wi-Fi bands—a little 2.4GHz love for your Ring
    b. Pause other security setups, like Alexa Guard
    c. Dig into a bit of Google Home notification settings action
3. Voice Commands Just Won’t Work
  • Cause: Bad phrasing or outage mess
  • Fix:
    a. Use exact phrasing: “Hey Google, ask Ring to…”
    b. Check what’s happening at the Google Cloud Status Dashboard
    c. Re-link in Google Home → Settings → Linked services
Trying Something Fancy?
For those nerding out over deeper tech connections:
  • Use Actions on Google for creative command making
  • Get into Home Graph API for more contextual control
  • Set up Stackdriver Logging to diagnose errors
Other Options
If Ring is giving you the business:
  • Switch to Alexa-enabled toys for the whole Ring enchilada
  • Look into Nest Hello for real video compatibility with Google Home
While these steps are a bit of a workaround, they still let you score some basic Ring and Google Home interaction despite the hurdles. Keeping your gadgets up-to-date and nailed in networking will go a long way to smooth things out.
Getting Your Ring Doorbell and Google Home to Play Nice Together
Got your new Ring Doorbell? Sweet! Pairing it up with Google Home to make your life easier is the way to go. You won’t have to jump through hoops to get this done—just follow these steps, and you’ll be all set:
Step-by-Step Instructions:
1. Compatibility Check: First things first, make sure your Ring Doorbell plays nice with Google Home. A quick check on Ring’s or Google’s support sites should give you the thumbs up.
2. Get the Right Apps: You’ll need the Ring app and Google Home app on your phone. If you haven’t registered yet, go ahead and do that too.
3. Hook Up Your Ring Doorbell: Use the Ring app to get your doorbell connected to your Wi-Fi. Once it’s all set and buzzing, you’re ready for the next step.
4. Add Ring to Google Home:
– Fire up the Google Home app.
– Hit that “+” button—time to add a new device!
– Go to “Set up device” > “Works with Google.”
– Pick “Ring” from the list.
5. Link Your Accounts: You’ll need to log into your Ring account. Just pop in your details and follow the instructions to tie everything together.
6. Group Devices: Assign your Ring Doorbell to a specific room in the Google Home app. This organizes things and makes voice commands snappy.
7. Use Those Voice Commands: Now it’s time for the magic. Say stuff like “Hey Google, show the front door” to see what’s happening outside on your Google Nest Hub.
Troubleshooting Tips:
  • Make sure all your devices are on the same Wi-Fi network. Sounds basic, but it’s critical.
  • If you hit a snag, try restarting both gadgets. It’s surprising how often this works.
  • Keep an eye out for app updates. An outdated app can throw a spanner in the works.
With these steps down, you’re all set to enjoy a smarter, connected home! It’s not rocket science, but it sure feels like magic when it’s working smoothly.
