How Can I Connect My PS5 to WiFi Using My Phone?
587 viewsGame Console
Trying to hook up your PS5 to Wi-Fi using your phone? Here’s how you can get it done:
Step 1: Get Your PS5 Ready
  1. First things first, turn on your PS5 and make sure you’re on the home screen.
  2. Then, head over to Settings. You’ll find the gear icon up there on the top right.
Step 2: Dive into Internet Setup
  1. Once in the Settings, go for Network.
  2. Select Settings again and then Set Up Internet Connection.
  3. Pick out your hotel’s Wi-Fi network from the list and give it a go.
Step 3: Connection Attempt
  1. Pop in the Wi-Fi password when asked. If it doesn’t connect right away, don’t panic—it’s normal, thanks to hotel’s captive portals.
Step 4: Use Your Phone for a Quick Fix
  1. If the connection fizzles out, go back to Network settings and hit up How to Authenticate.
  2. Follow what the screen tells you: you’ll see an option to connect your phone to a temporary PS5 network:
    • Look for a network that kicks off with “PS5-” followed by some numbers (like PS5-123).
    • Hop on your phone, then navigate through Settings > Wi-Fi to latch onto this PS5 network.
  3. Once you’ve snagged that connection, pop the eight-digit code displayed on your PS5 into your phone.
Step 5: Get Through the Hotel Login
  1. After you punch in the code, a nudge should show on your phone telling you to jump into a browser.
  2. Tap it and you’ll land on the hotel’s login page to enter some credentials, maybe room number or password, provided by the hotel.
Step 6: Seal the Deal
  1. Once the login’s wrapped up, swing back to your PS5.
  2. To ensure it’s all good, go to Settings > Network > Connection Status and hit up Test Internet Connection.
If you went through these steps properly, your PS5 should now be cruising along on Wi-Fi through your phone!
Quick Recap: To get your PS5 online using your phone, wander over to Settings, then Network, and Set Up Internet Connection on your PS5. Pick a network and try to connect (it might flake out), then hit ‘How to Authenticate.’ Connect your phone to that temporary PS5 network with an eight-digit code from the console, log in via your phone’s browser with hotel deets, and wrap it up by testing the connection on your PS5.
If you find yourself needing to connect your PS5 to Wi-Fi using your phone, no worries—it’s actually easier than you might think. You can use your phone’s mobile hotspot or tweak your router settings right from your phone browser. Let’s dive into this and see how it’s done.
Using Your Phone as a Mobile Hotspot
When to Do This: If your regular home Wi-Fi isn’t cooperating with the PS5, your phone’s hotspot can be your hero.
How to Set It Up:
  • Get Your Hotspot Going:
    • If you’ve got an Android: Head to Settings > Network & Internet > Hotspot & Tethering > Wi-Fi Hotspot. Set a solid password and flip the hotspot switch.
    • Rocking an iPhone?: Go to Settings > Personal Hotspot, switch it on, and set your password.
  • Hook Your PS5 to the Hotspot:
    • On your PS5, mosey over to Settings > Network > Settings > Set Up Internet Connection.
    • Pick your phone’s hotspot from the list and punch in that password.
A Couple of Tips to Keep in Mind:
  • 5GHz Details: Got a PS5 that’s picky about 5GHz connections? Double-check the hotspot channels on your phone.
  • Data Gobbler Alert: Gaming and downloads can burn through your data. Keep an eye on those usage stats.
Fixing Up Router Settings Using Your Phone Browser
When This Makes Sense: If your PS5 is giving your Wi-Fi the cold shoulder, adjusting router settings can help.
The How-Tos:
  • Getting into Router Settings:
    • Type in your router’s IP address (something like 192.168.1.1) into your phone’s browser and log in. You might find those details stuck on your router somewhere.
  • Switch Up the 5GHz Channel:
    • Dig into Wireless Settings > 5GHz Band and swap the channel to 36–48 (this is a lifesaver for some PS5 models).
  • Turn On IPv4:
    • Your PS5 isn’t too fond of IPv6-only networks. Check those settings and make sure IPv4 is in action.
  • Freshen Up DNS Settings:
    • On your PS5, toss in some new DNS like Google (8.8.8.8 / 8.8.4.4) or Cloudflare (1.1.1.1). It might just smooth things out.
Dealing with Common Hiccups
Can’t Find Wi-Fi on PS5
  • Why This Happens: Those sneaky 5GHz channels aren’t playing nice with your PS5.
  • Fix It Like This: Make sure your router’s 5GHz channel is set between 36–48.
The Signal’s a Bit Shaky
  • What Gives?: It could be too far from the router or just interference.
  • What You Can Do:
    • Move It Over: Think about shifting your router closer to your PS5.
    • Use 2.4GHz: Might be slower, but it has a better range the PS5 likes.
DNS or IP Errors
  • Possible Reason: DNS not set right or IPv6 causing issues.
  • How to Tackle It:
    • Manually dive into DNS settings on your PS5.
    • Switch off IPv6 in your router settings if needed.
A Couple More Tricks Up the Sleeve
  • Apps That Give A Boost: Check out UU Booster or 网易UU – they ramp up gaming traffic for a smoother ride.
  • Wired Connection from Your Phone: Grab a USB-C-to-Ethernet adapter if your phone’s up for it. Super handy with Android.
Getting the Hang of It
  • Why Some Models are Quirky: In Japan, PS5 models have specific 5GHz needs due to local rules.
  • IPv6 Not Fully in Play: PS5 doesn’t fully embrace IPv6, so sticking to IPv4 is key.
  • Hotspot Connection: Be mindful of the high latency that comes with hotspot use, especially when playing online.
Stick with these tips, and your PS5 should get along great with Wi-Fi using your phone. If things are still bumpy, a reset might do the trick, or reaching out to your ISP could help. Good luck!
If you want to hook up your PS5 to WiFi using your phone as a hotspot, here’s the lowdown:
Step 1: Fire Up Your Phone Hotspot
1. Get Your Hotspot Going:
  • With iOS: Dive into Settings > Cellular > Personal Hotspot or just Settings > Personal Hotspot. Flip the switch for Allow Others to Join.
  • Using Android: Head over to Settings > Network & Internet > Hotspot & Tethering > Wi-Fi Hotspot and turn on Wi-Fi Hotspot.
Step 2: Get Your Hotspot Settings Right
1. Make sure you’ve got Wi-Fi security set to WPA2.
2. Put a password on your hotspot to keep things safe.
Step 3: Connect Your PS5 to the Hotspot
1. Power Up Your PS5: Head to the Home Screen.
2. Swing into Network Settings: Pop into Settings > Network > Settings > Set Up Internet Connection.
3. Pick Your Wi-Fi Method: Go for Use Wi-Fi.
4. Spot Your Phone’s Hotspot: Find your phone’s hotspot in the available networks list.
5. Pop in the Password: Type in the password you set earlier for your hotspot.
6. Wrap Up the Connection: Just follow the prompts, and your PS5 should hook up with the hotspot.
Got some pointers for a solid connection:
1. Keep Your Phone Close to the PS5: It helps keep the signal strong and steady.
2. Watch the Hotspot Data: Gaming munches through data big time, so stay on top of your data limits.
3. Crank Up the Performance: A strong 4G or 5G signal on your phone can make your gaming smoother.
Connecting your PS5 to WiFi using your phone hotspot is a nifty way to keep gaming, no matter where you end up. Follow the steps and you’ll be all set!
