How to Connect Ps5 Controller to Ps4 with Usb?
305 viewsGame Console
The PS5 DualSense controller isn’t officially compatible with the PS4 console, but you can still get it to work through some clever workarounds. Here’s how you can do it:
The PS5 controller, designed with awesome features like improved haptic feedback and adaptive triggers, is mostly for PS5 games. The PS4, on the other hand, is set up to work with the DualShock 4. But hey, if you really want to use your PS5 controller on your PS4, maybe because you love the grip and feel or just need an extra controller for multiplayer, here’s what you can try.
Methods to Get Connected:
  • Using Third-Party Adapters:
    • Grab a Compatible Adapter: Look for adapters like the Mayflash Magic-S Pro 2, Titan Two Adapter, Brook Wingman XE, or Adapex R100 Pro that can connect your PS5 controller to the PS4.
    • Plug It In: Stick the adapter into one of the USB ports on your PS4.
    • Pair Them Up: With adapters like the Mayflash Magic-S Pro 2, press the pairing button on the adapter to get it ready (the lights will blink). Then, hold down the Create and PS buttons on your PS5 controller until its lights start flashing. Once both devices’ lights stop blinking, you’re good to go. Your PS5 controller should now work with your PS4.
  • Using the PS Remote Play App:
    • Connect the PS5 Controller to Another Device: Using a USB-C cable, hook up your PS5 controller to a computer, smartphone, or tablet.
    • Get the PS Remote Play App: Download the app from the official site or app store and get it installed on your connected device.
    • Sync with Your PS4: Fire up the Remote Play App, sign in to your PSN account, and punch in the code shown on your PS4. Once linked, you can play PS4 games using your PS5 controller through the app. Just a heads-up, this method might introduce some delay.
Things to Keep in Mind:
  • Feature Limitations: Unfortunately, the PS5 controller’s cool haptic feedback and adaptive triggers won’t work when playing on PS4. Also, simple functions like using the PS button to turn on the console might not work.
  • Compatibility Issues: Even though these adapters can let you use a PS5 controller on the PS4, they might not work perfectly. Performance can differ based on the adapter and the situation, and might not match the smooth experience of using a native controller.
  • Power Considerations: If you’re connecting the PS5 controller to the PS4 via a USB cable, make sure the USB port on the PS4 can supply enough power. Otherwise, you might run into charging issues or the controller might not work properly while playing.
So, while the PS5 controller isn’t natively supported on the PS4, you can use third-party adapters or the PS Remote Play App to get it connected via USB. Just think about the functional limitations and potential hiccups to see if these methods suit your gaming needs.
Alrighty, folks—if you’re wondering about connecting your PS5 DualSense controller to your trusty PS4 using a USB, brace yourself for a bit of a curveball. Officially, Sony hasn’t made them buddy-buddy straight out of the box, but don’t throw in the towel just yet. There are some creative workarounds that let you use the PS5 controller on the PS4. Let’s dig in, shall we?
Before anything else, round up your essentials:
  • A PS5 DualSense controller.
  • Your PS4 console.
  • And a USB Type-C cable for the DualSense controller.
Trying the USB connection:
  1. Get Plugged In: Now, take one end of that USB cable and pop it into your PS5 controller, then the other into a USB port on your PS4.
  2. The Lowdown on Charging: You’ll see the controller start charging—awesome, right? The catch is, it won’t work for playing games because Sony isn’t rolling that way with compatibility.
Here’s the kicker—direct USB hookup won’t land you home runs in gaming. But hey, there are some roundabout paths you can take:
  1. Remote Play to the Rescue:
    • If you have a PC or another device for Remote Play, that’s your ticket!
    • Hook your PS5 controller up to your computer.
    • Fire up the Remote Play app and sign into your PlayStation Network account.
    • Access your PS4 from there, and voila—you’re gaming with the PS5 controller!
  1. Bluetooth Adapter Magic:
    • For those who prefer wireless freedom, a Bluetooth adapter tailored for cross-console connections is your best bet.
    • The Mayflash Magic-S Pro is a solid choice—it lets you use your DualSense wirelessly on PS4.
    • Here’s how to set it up:
      1. Plug that adapter into your PS4’s USB slot.
      2. Get both the adapter and the controller in pairing mode (follow the adapter instructions carefully).
      3. Once paired, you’re all set for wireless gameplay!
Here’s the deal: using a PS5 controller on a PS4 isn’t all sunshine and rainbows. You’ll miss out on cool stuff like haptic feedback and adaptive triggers. Plus, every Bluetooth adapter has its quirks. But hey, if you’re willing to work with what’s available, it’s definitely doable!
To wrap things up, while you can’t just plug and play the PS5 controller on the PS4 with a USB, tricks like Remote Play and Bluetooth adapters are there to help—just know the ride might be a little bumpy.
Hooking Up a PS5 Controller to a PS4 with USB: Can It Be Done?
Alright, so you’ve got this shiny new PS5 controller, and you’re dying to see if it can work with your PS4, right? Well, here’s the deal.
1. Compatibility Check
The PS5 DualSense controller is a gem when it comes to tech for the PS5, but Sony pretty much threw a wrench into our plans by making it incompatible with the PS4. It’s all about those fancy features and communication differences you’ve got to deal with. While you can use your old PS4 controllers with the new PS5 for some games, don’t expect the PS5 controller to play nice with your PS4.
2. Why as a No-Go?
  • Tech Differences: We’re talking about a controller that’s packing some serious advancements—haptic feedback, adaptive triggers, the whole shebang—that your PS4 just can’t comprehend.
  • Firmware Lockdown: Sony hasn’t waved the magic wand to enable PS5 controllers on PS4 systems. It’s the kind of thing that makes you say, “Come on, Sony!”
3. Trying a USB Hookup
Seems like using a USB-C cable to link them up would be a walk in the park, but spoiler alert—it won’t cut it. Just for kicks, here’s what would need to happen:
  1. Plug ‘Em In: Connect that PS5 controller using a USB-C to USB-A cable to the PS4.
  2. Fire Up the PS4: Sad story; even if the controller lights up, the PS4 won’t notice it.
  3. Pairing Shenanigans: Dive into Settings > Devices > Bluetooth Devices on the PS4, but don’t hold your breath trying to find the PS5 controller there.
4. Other Ways Around It
So, if you’ve got your heart set on a PS5-like setup, here’s what you could try:
  • Stick to the PS4 Controller: Dust off the faithful DualShock 4—it’s your best buddy on PS4. Here’s how:
    1. Connect over USB or Bluetooth. Simple as.
    2. For a wired vibe, just plug it in and hit the PS button.
  • Get Creative with Third-Party Gadgets: There are converters like the Brook Wingman Converter, which might bridge the divide, but be prepared for some quirks and delays.
5. The Background Scoop
Sony’s keeping a tight grip on separating PS4 and PS5 gear, encouraging us to move on to their new toys. PS4 controllers might get a hall pass to the PS5 party, but PS5 controllers are stuck in their own sandbox to keep all those futuristic features intact.
6. Troubleshooting Tips
  • Check for Updates: You can try updating the PS4 and controller firmware, but don’t get your hopes up on a miracle fix.
  • Cable Drama: Make sure your cable’s not dead in the water by testing it with other gadgets, like your phone.
Alright, wrapping things up here, connecting a PS5 controller directly to a PS4 via USB—not happening. If you’re hunting for that next-gen feel, stick to the trusty DualShock 4 or cautiously explore third-party options. Keep an eye out for any Sony announcements about bridging the controller gap. Who knows? We might get lucky someday!
So, you might be wondering if you can hook up a PS5 controller to a PS4 with a USB cable. Unfortunately, you can’t just plug it in directly. But don’t worry, I’ve got a couple of tricks you can try.
Here’s the first option: PS Remote Play. It’s actually pretty neat for these sorts of situations. What you’ll need is the PS5 controller, a compatible USB cable, plus either a computer or a smartphone. Once you’ve got all that together, download the PS Remote Play app. Fire up the app on your device and sign in with your PlayStation account. Follow the on-screen directions to link your PS4 with the app.
Now, for the controller. Connect your PS5 controller to the device using the USB cable. The app takes it from there, letting you use your spanking new controller while playing on your old console through remote play.
Here’s the kicker, if Remote Play isn’t your cup of tea, you might look into third-party adapters. They’re out there and can make it happen. Just make sure you do your homework to find a reliable one that works well with both PS5 and PS4. They’re not all created equal, so choose wisely.
One more thing to watch out for: If your internet connection isn’t top-notch, you might experience some lag with remote play – it’s just part of the gig. As it stands, plugging your PS5 controller directly into the PS4 with USB isn’t an option, but with these workarounds, you’re all set to mix and match your gaming tools and have some fun.
