How to Connect Airpods to Ps4 Without Dongle?
286 viewsHeadphones
The PS4 doesn’t support Bluetooth audio devices like Apple AirPods out of the box because it only works with certain Bluetooth profiles—AirPods use a different one, the A2DP. But don’t worry, there are some workaround methods to get your AirPods connected without spending extra on a dongle. Here’s how you can do it:
Using the PS Remote Play App
First off, if you’ve got a smartphone, you can use the PS Remote Play App to connect your AirPods. Essentially, your phone will act as a go-between. Here’s what you need to do:
  1. Enable Remote Play on your PS4: Head to Settings > Remote Play Connection Settings on your PS4 and make sure the Enable Remote Play option is checked.
  2. Download the Remote Play App on your mobile device: You can find this app on your device’s app store.
  3. Sign into the app: Use your PSN account credentials. If it can’t detect your PS4, make sure both devices are on the same network or try a manual link with the code found under Settings > Remote Play Connection Settings > Add Device on your PS4.
  4. Pair your AirPods and DualShock 4 with your phone via Bluetooth: Now, you can game away using your AirPods.
Using a Computer
Another hack involves using your computer with an AUX and 3.5mm audio cable. Here’s the scoop:
  1. Connect your PS4 to the TV with an HDMI cable.
  2. Use an AUX cable to connect the TV and your computer: Plug one end into your TV’s 3.5mm port and the other into your computer’s microphone jack.
  3. Open your computer’s Sound Settings and dive into More Sound Settings.
  4. Navigate through Recording > External Microphone > Properties. It might show up as Line In instead.
  5. Under the Listen tab, check the Listen to this device box and link your AirPods to your computer via Bluetooth.
  6. Once it’s all set, fire up a game. Your TV will display video, and your AirPods will handle the audio.
Using a Smart TV with Built-in Bluetooth
Got a smart TV with Bluetooth? This method’s for you:
  1. Link your PS4 to your smart TV with an HDMI cable.
  2. On your TV, go to Settings > Sound Settings > Bluetooth.
  3. Put your AirPods in pairing mode: Open the case, press and hold the back button until the light flashes.
  4. Scan for Bluetooth devices on your TV and connect to your AirPods.
  5. On your PS4, go to Settings > Audio Settings and set your TV as the Output Device.
Just a few things to keep in mind:
  • Latency: You might experience some audio lag, which could be a bummer during fast-paced games.
  • Limited features: Some cool AirPods functionalities like “Hey Siri” might not work.
  • Battery drain: Your AirPods might run out of juice faster than usual.
  • Sound quality: It might not be as top-notch as you’re used to.
If you’re using AirPods with your PS4 regularly, a Bluetooth dongle might save you some hassle. Here’s a quick rundown on that:
  1. Plug the Bluetooth dongle into a PS4 USB port.
  2. Pair your AirPods by opening the case and holding the back button until the light blinks.
  3. On your PS4, go to Settings > Devices > Bluetooth Devices, find your AirPods, and connect.
  4. In Settings > Devices > Audio Devices, set the output device to your AirPods and select All Audio if prompted.
People often ask:
  • Can AirPods be connected to a PS4? Yes, but not directly. You need a workaround or a Bluetooth dongle.
  • What Bluetooth profiles does the PS4 support? It supports HSP and HFP, but not A2DP.
  • Why won’t my wireless headphones connect? The PS4 doesn’t support headphones using the A2DP profile.
  • Does the PS4 have audio output? Yep, it has HDMI and Digital Optical ports for audio and video.
So, while it’s a bit of a process, you can definitely connect AirPods to your PS4 with a few clever tricks. But if you find yourself doing this often, maybe get a Bluetooth dongle for smoother sailing.
So, you’re looking to connect your AirPods to a PS4 without forking out for a dongle, huh? You’re in luck because there are a few workarounds. Let’s dive into these creative solutions!
First up, let’s chat about the PS Remote Play app. This neat little trick involves using your smartphone to hook up your AirPods wirelessly. Here’s how you do it:
Get Your PS4 and Remote Play on the Same Page: Head over to your PS4 settings and flick the switch on Remote Play Connection. It’s as simple as checking a box.
Grab the App: Snag the PS Remote Play app from either Google Play or the Apple Store and get it on your phone.
Let the Magic Happen: Open the app, log in to your PlayStation Network account, and make sure your phone and PS4 are chilling under the same Wi-Fi.
Link Up the AirPods: Time to pair those AirPods with your smartphone. Bluetooth is your buddy here.
Game On: Fire up a game through the app, and boom, the sound should flow through your AirPods.
Now, here’s a curveball: if you’ve got a smart TV with Bluetooth, you’re sitting pretty. Connect your PS4 to the TV, pairing your AirPods directly. Here’s the lowdown:
HDMI Magic: Get your PS4 talking to your smart TV using an HDMI cable.
AirPods Meet TV: Pop your AirPods into pairing mode, then hop into your TV’s Bluetooth settings to connect them.
TV Takes Over Audio Duties: Adjust your PS4’s audio output settings to send sound through HDMI to your TV.
When you play games now, the TV will sing to your AirPods. Pretty slick, right?
And here’s one more for the road: using a computer to get that sound flowing. It’s a bit more fiddly, but it works. Here’s how:
Get Connected: Ensure your PS4 is plugged into the TV.
AUX Time: Run an AUX cable from your TV’s headphone jack to the microphone input on your computer.
Computer Sound Wizardry: Dive into your computer’s sound settings, find that mic input, and tell it to listen in.
AirPods, Assemble: Connect your AirPods to the computer via Bluetooth.
Ready to Roll: Start gaming and listen to the sounds as they travel this quirky path.
There you have it! Who knew there were so many ways to dodge that dongle? Enjoy your wireless gaming sesh!
Hope that all sounds like a plan. Enjoy gaming without that pesky cable tying you down!
Getting Your AirPods Hooked Up to PS4 Without a Dongle: Tips and Tricks
Alright, here’s the deal. AirPods sync effortlessly with Apple stuff, but if you’re trying to hook them up to your PS4, you might hit a snag. It’s all down to the PS4’s Bluetooth functions that are mostly set up for things like controllers, which means your AirPods can’t just jump in there.
The Main Hurdles
  1. Bluetooth Limitations
    • PS4 likes to keep its Bluetooth busy with controllers, making it hard to sneak a pair of AirPods into the mix.
    • It doesn’t have that special audio Bluetooth setup you’d find on Apple gadgets.
  2. No Pairing Magic
    • AirPods have Apple’s fancy H1/W1 chip for easy connect, but the PS4’s just not speaking the same language.
Workarounds Without a Dongle
If you don’t want to mess around with a Bluetooth adapter, there are a few tricks up your sleeve:
Remote Play through Your Phone or Computer
How This Rolls: You’ve got to stream the PS4 action to something else you own that can talk to AirPods.
Here’s the Rundown:
  • Step 1: Snag the PS Remote Play app for your phone or computer.
  • Step 2: Pair your AirPods with this new gadget via Bluetooth.
  • Step 3: Fire up Remote Play and sync it to the PS4, making sure both are chillin’ on the same Wi-Fi.
  • Step 4: Kick back and stream some gameplay, with sound coming through your AirPods.
Heads Up:
  • Audio might lag a bit thanks to network stuff.
  • You need solid Wi-Fi all the way.
Using a PS Vita as Your Go-Between
If a PS Vita is hanging out at your place:
  • Step 1: Pair AirPods with your PS Vita.
  • Step 2: Fire up Remote Play on the Vita and connect it to the PS4.
  • Step 3: Enjoy PS4 sound through the Vita, straight to your AirPods.
Nota Bene: You gotta have a Vita and a separate PSN account for this to fly.
Plugging in via Your Controller
If you don’t mind cables, here’s an idea: hook those AirPods up using a 3.5mm cable (and maybe a Lightning-to-3.5mm adapter).
  • Step 1: Plug that adapter into your AirPods case (if you’ve got wired ones) or use a fitting cable.
  • Step 2: Switch the PS4 audio to your controller in Settings > Devices > Audio Devices > Output to Headphones: All Audio.
Drawbacks:
  • Kind of kills the wireless vibe.
  • Needs extra cables and adapters.
Why Direct Connect Doesn’t Cut It
  • Bluetooth Priorities: PS4 keeps Bluetooth busy with controllers, leaving AirPods out of the loop.
  • Software Clash: Your AirPods and PS4 system don’t have those buddy protocols.
Other Routes You Might Consider
If the methods above don’t mesh with your setup, here’s a couple more ideas:
  • Bluetooth Transmitters: Think USB-C/Lightning transmitter—something that turns PS4 audio into Bluetooth magic.
  • Straight-Up Wired Headsets: For tight sound sync, grab a gaming headset that’s wired and ready with a 3.5mm jack.
Little Fixes to Try
  • Reset Your AirPods: Hold the button on the case till the light goes blink.
  • Scan Bluetooth Settings: Double-check no other gadgets are hogging the PS4 Bluetooth.
  • Keep Everything Up-to-Date: Make sure your PS4 and AirPods have the freshest updates.
While these hacks might not be silky smooth, they should help you jam with your AirPods on PS4 without needing a dongle. Focus on what keeps lag and sound issues down to make the best of it.
If you’re scratching your head trying to hook up your AirPods to a PS4 without some fancy dongle, you’re definitely not alone. Guess what? The PS4 is notoriously picky when it comes to Bluetooth audio. But don’t worry—there are a couple of ways to work around it!
First up, the PS4 Remote Play app could save the day. Now, I know it sounds a bit techy, but bear with me—it’s pretty straightforward. You’ll want to grab the PS4 Remote Play app for your smartphone, whether you’re riding with iOS or Android. Once you’ve got it installed, sign in with your PlayStation Network account and follow the steps to sync it up with your PS4. It’s kind of like a little handshake between your phone and the console. After that, connect your AirPods to your phone through Bluetooth. When you fire up a Remote Play session, voilà—your PS4’s audio streams through your phone straight to your AirPods, no fuss!
Now, if your TV’s one of those with built-in Bluetooth, or you’ve got a Bluetooth transmitter lying around, you can use that to link your AirPods. Here’s how it goes: Check if your TV supports Bluetooth. If not, grab a transmitter that hooks up to your TV’s audio output. Pair your AirPods with the TV or transmitter, set the TV’s audio output to use the Bluetooth connection, and boom—your PS4 audio zips through the HDMI to your TV and onto your AirPods.
These tips aren’t just some wild idea; they’ve been the go-to for many who crave PS4 gaming audio without the extra gear. So, without a dongle, you’re still pretty much all set to game away with your AirPods!
