How Can I Connect a PS4 Controller to My Xbox One?
421 viewsGame Console
While the Xbox One doesn’t natively support PS4 DualShock controllers, you have two effective workaround solutions:
Using a Brook X One SE Adapter (Wired Connection)
Update the Adapter:‌ Connect the Brook X One SE adapter to a PC using its USB cable. Install and run the Brook-provided software to update the adapter’s firmware to the latest version. This step is crucial for proper functionality.
Connect the Dongle:‌ Plug the adapter’s USB dongle into an available USB port on your Xbox One console. The adapter will power on.
Connect the Controller:‌ Using a standard USB cable, connect your PS4 DualShock 4 controller ‌directly to the USB port on the Brook adapter dongle itself‌. ‌Do not‌ plug the controller into the Xbox One console’s USB ports.
Automatic Pairing:‌ The controller should automatically pair with the adapter. Visual indicators (like solid lights on both the adapter and the controller) will signify a successful connection. Your PS4 controller can now be used to navigate the Xbox dashboard and play games.
 Streaming via the Xbox App (Wireless, Requires Smartphone & Streaming)
Install the App:‌ Download and install the official Xbox app on your smartphone (iOS or Android).
Pair Controller to Phone:‌ Put your PS4 controller into Bluetooth pairing mode by holding the ‌PS button‌ and the ‌Share button‌ simultaneously until the light bar flashes rapidly. Find and select the controller (“Wireless Controller”) in your phone’s Bluetooth settings to pair them.
Connect Phone & Xbox:‌ Ensure both your smartphone and your Xbox One console are connected to the ‌same Wi-Fi network‌.
Start Remote Play:‌ Open the Xbox app on your phone. Navigate to the “Remote Play” section (icon usually looks like a console with phone waves) and initiate a connection to your Xbox One.
Control via Controller:‌ Once connected, your Xbox interface and games will be mirrored on both your TV and your phone screen. Crucially, ‌your PS4 controller, now paired to your phone, will function as the input device‌ for this streamed session. You can choose to play viewing your TV or your phone’s screen.
Connecting a PS4 controller to an Xbox One can really shake up your gaming routine, especially if you’ve already got that PS4 controller and don’t want to bother buying an Xbox One controller. Here’s a straightforward guide to get you going:
Why Connect a PS4 Controller to Xbox One
  • Multi-Console Gaming Convenience: If your household has both PS4 and Xbox One consoles, this allows you to switch between systems without needing a pile of controllers.
  • Comfort and Preference: Maybe you just love the feel of the PS4 controller. It has that touchpad and great battery life, right?
Methods to Connect
Wireless Connection
  • Bluetooth Pairing:
    • First, make sure your Xbox One has the Fall 2020 update or later. Then, go to “Settings” > “Devices & Connections” > “Bluetooth” and switch it on.
    • On the PS4 controller, hold down the “Share” button and the PS button until the light bar blinks.
    • On the Xbox One, choose “Add a Device” > “Controller.” Wait for it to find your PS4 controller and select it. Boom, you’re connected!
  • Using a Wireless Adapter:
    • Get an adapter that works with both consoles, like CronusMax Plus or Titan One.
    • Plug the adapter into your PC first to set it up. For example, install CronusPro software if you’re using CronusMax Plus.
    • Set up your PS4 controller on the software, mapping it to work with Xbox One.
    • Now, unplug the adapter from your PC and stick it into your Xbox One. Connect your PS4 controller via USB to the adapter first, then go wireless by pressing the PS button.
Wired Connection
  • Using a USB Cable:
    • Connect the PS4 controller with a Micro USB cable to a USB port on the Xbox One.
    • The Xbox One should detect it automatically. If not, just follow the on-screen steps. Easy peasy. This method gives a solid connection but you’ll be tethered by the cable.
  • Using a Third-Party Adapter:
    • Plug the adapter into the Xbox One.
    • Follow the adapter’s directions to connect the PS4 controller, either by USB or wireless setup.
Optimizing Xbox One Controller Settings
  • Hop into your Xbox One “Settings” app.
  • Go to “Game & Apps” > “Devices & Accessories.”
  • Tweak the options like game chat, volume levels, etc., to your liking.
Post-Connection Considerations
  • Controller Charging: Keep a charging hub handy to keep your PS4 controller juiced up.
  • Game Compatibility: Most games should work fine, but you might run into some hiccups with button mapping or special features. You may need to tweak in-game settings or remap buttons.
  • Firmware Updates: Ensure both your PS4 controller and any adapters are up to date for best performance.
Troubleshooting Common Issues
  • Wireless Disconnections: Make sure everything’s within range. Try reconnecting it closer or faster intervals.
  • Pairing Failures: Restart the controller, update your Xbox One, or check the adapter’s troubleshooting tips.
  • Input Lag: For less lag, stick with wired or use a different low latency adapter. Plus, keep the adapter’s firmware updated.
Just follow these tips, and you’ll be set for a seamless gaming session with your PS4 controller on Xbox One.
Trying to play with a PS4 controller on your Xbox One? Yeah, I know—the struggle is real! Luckily, there’s a nifty little device called the CronusMAX PLUS that’ll help get you sorted. Let’s dive into how it’s done.
First things first, grab yourself a CronusMAX PLUS adapter. If it doesn’t come with built-in Bluetooth, snag a Bluetooth 4.0 USB adapter too. Once you’ve got that gear, you’re ready to roll.
Next up, plug your CronusMAX PLUS into a PC that’s hooked up to the internet to let those drivers do their thing. This step is like the appetizer—you need it, but it’s not the main course. So hang in there a bit until it’s done.
After that, fire up the Cronus PRO software on your computer. Go snooping around the menus—hit up Tools, then Options, then Device. You’ll want to switch the output protocol to Xbox One, or XB1 as they call it.
Now, let’s get Bluetooth searching on board. Make sure you tick that box next to ‘Enable Dualshock 4/Wiimote Bluetooth searching.’ It’s what gets your PS4 controller ready to link up.
Okay, now unplug the CronusMAX PLUS from your PC and shove it into one of the Xbox One’s USB ports. When you see ‘AU’ on the adapter, you’ll know you’re in business—which means it’s in authentication mode, for those who love the lingo.
Before we rush into things, go ahead and yank the batteries from your Xbox One controllers. Trust me, they love to mess with the pairing process.
Now for the fun part: Wait until a number pops up on the CronusMAX PLUS LED display—that means it’s ready for action. Ditch any connected Xbox controllers and look for an animation on the adapter (kinda like two halves of a circle dancing around).
Grab a USB cable, connect that Xbox One controller to the CronusMAX PLUS, and watch it switch from ‘AU’ to ‘0.’ You’re almost there!
Here’s the kicker: Connect your Bluetooth USB adapter to the CronusMAX PLUS if needed. Then hold down the SHARE button and the PS button on your PS4 controller until it starts flashing. A couple of seconds later, your controller should be paired—it’s official when the light bar gets a solid color.
You’ll know you’ve nailed it when ‘0’ pops back up on the CronusMAX PLUS. Voila, your PS4 controller is now good to go on your Xbox One!
Oh, and just a little tip: If this becomes a regular setup for you, consider switching off Bluetooth searching. To do that, reconnect your CronusMAX PLUS to your PC and untick ‘Enable Dualshock 4/Wiimote Bluetooth searching.’ Then, repeat the steps and just press the PS button on your PS4 controller to reconnect.
By walking through these steps, you can rock a PlayStation 4 controller on an Xbox One—talk about gaming hybrid!
So, you’re trying to use a PS4 controller with your Xbox One, huh? That’s a tough nut to crack since they don’t exactly get along. Their hardware and software speak totally different languages. But hey, don’t lose hope, there are a few workarounds to try out.
The Main Stumbling Blocks
  1. Different Tech Talk
    Xbox One controllers use their own wireless tricks, while PS4 controllers stick with Bluetooth. It’s like trying to fit a square peg in a round hole.
  2. Not Quite the Same Buttons
    Did you know that the PS4 controller doesn’t have some Xbox features? Those impulse triggers aren’t gonna work and good luck figuring out what △ even does compared to Y on Xbox.
What Can You Do?
Option 1: Sneaky Adapters
You’ve got some crafty devices like Brook X One SE Converter and Cronus Zen that act like translators between these gadgets.
Here’s What You Do:
  1. Plug the adapter into the Xbox One via USB.
  2. Pair that PS4 controller with the adapter either by Bluetooth or a wire.
  3. If needed, fiddle around with the button setup through the adapter’s software.
But Heads Up:
  • Some adapters might cause a little lag. Maybe like 5–10 milliseconds.
  • Don’t bank on the headphone jack working.
Option 2: Get Clever with Remote Play
You can stream your Xbox One games to your PC and use the PS4 controller for gaming.
How To:
  1. Fire up the Xbox app on your Windows PC and set up remote play for Xbox One.
  2. Connect the PS4 controller to your PC using either Bluetooth or USB.
  3. Download something like DS4Windows to turn that PlayStation input into Xbox ones.
  4. Start the Xbox remote play session and you’re ready to game.
The Catch:
  • Don’t even think about doing this without solid Wi-Fi; 5GHz is a safe bet.
  • You’re going to have more lag than if you were playing directly.
Option 3: If You’re Feeling Daring, Firmware Hacks
You can tweak Xbox One’s software to let you use unofficial controllers.
Here’s the Risk:
  • You’ll void your warranties and could get kicked off Xbox Live.
  • Involves deep tech stuff—messing with drivers and core software. Might not be worth the hassle if you’re just looking to play.
Common Problems & Fixes
  • Controller Not Found: Double-check your adapter is made for Xbox One and update its firmware.
  • Laggy Controls: Definitely consider wired connections.
  • Button Confusion: Tweak those mappings using adapter tools or try out reWASD.
Looking for Easier Options?
If it’s smooth sailing you want, maybe spring for an Xbox Wireless Controller—it just works, no messing about. If you’re all about flexibility, the Xbox Elite Series 2 controller works across Xbox, PC and mobile without a hitch.
Final Thoughts
So yeah, while these tricks might get you through in a pinch, they ain’t perfect. It’s best to test those setups before diving into any serious gaming sessions.
So, you’re trying to get your PS4 controller to work with your Xbox One? While it’s not officially supported, the good news is there are a couple of ways to make it happen.
Kicking Things Off: Third-Party Adapter
Nab a Compatible Adapter: You’ll need something like the Brook Super Converter or CronusMax Plus. They’re pretty nifty for getting your gadgets to play nice across platforms.
Plug It In: Stick the adapter into one of the USB ports on your Xbox One.
Get Pairing: Check out the adapter’s pairing instructions. Usually, it’s about pressing certain buttons both on the controller and the adapter.
Tweak the Settings: Some adapters come with software for fine-tuning button mapping and sensitivity. Give the manual a look to see what’s what.
Another Trick: Use the Xbox App on Your PC
Grab the Xbox App: Download it on your Windows 10 PC, and make sure your PC is on the same network as your Xbox One.
Link Your PS4 Controller to the PC: You can connect it through Bluetooth or USB. If you’re going for Bluetooth, hold down the Share and PS buttons until the light starts flashing, then pair it via Windows settings.
Stream Xbox One to Your PC: Open the Xbox app and click on the Connection icon. Pick your Xbox One console, sit back, and enjoy the streaming.
Game On with the PS4 Controller: Once you’re streaming Xbox One to your PC, you can use the PS4 controller to dive right into your games.
A Few Things to Keep in Mind:
  • Performance and functionality might vary depending on the setup or the game you’re playing.
  • Make sure you’re buying adapters from known brands to dodge any compatibility headaches.
By doing all this, you’re pretty much set to tackle Xbox games with your PS4 controller. Sure, you might need some extra gear or apps, but it’s a pretty solid workaround to make everything gel together.
