How to Connect A Ps3 Controller to A Phone?
523 viewsGame Console
The PlayStation 3 (PS3) controller, known as the DualShock 3, is a favorite among gamers for its comfortable grip and responsiveness. The rise of mobile gaming means you can now connect a PS3 controller to a phone, which really ups the gaming experience. Here’s how you can do it:
Can You Connect A PS3 Controller to A Phone?
  • Bluetooth Technology: The PS3 controller uses Bluetooth to connect to devices. Most modern smartphones have Bluetooth, so that’s a good start.
  • System Compatibility: Android devices tend to work better with PS3 controllers. From Android 3.0 (Honeycomb) and up, these devices support game controllers. The newer your device and Android version, the smoother the connection. iOS devices, however, have some restrictions. You might need extra software or hardware, and setting up can be a bit tricky.
What You’ll Need
  • PS3 Controller: Make sure it’s charged up. Plug it into a PS3 console or any USB power source if it’s low on juice.
  • Phone: An Android phone or tablet with Android 3.0 or higher, or an iOS device that meets certain criteria.
  • USB OTG Cable: You might need this depending on the connection method you choose. One end plugs into your phone, the other connects to the controller.
  • Sixaxis Controller App: This app helps link your PS3 controller to your phone. You can find it on the Google Play Store.
How to Connect
  • For Android Phones:
    • Bluetooth Connection:
      1. Turn Off Controller: Press the PS button to turn it off. Then press and hold the PS and Share buttons until the lights start flashing. Now it’s in pairing mode.
      2. Enable Bluetooth: On your phone, go to settings, find the Bluetooth section, and turn it on.
      3. Pair Devices: Look for “Wireless Controller” in the available devices list and tap it to pair. Once the lights on the controller stabilize, you’re good to go.
      4. Test It Out: Open a game that supports controllers and see if the PS3 controller works.
    • USB OTG Cable Connection:
      1. Connect the Cable: Plug the USB OTG cable into your phone and the PS3 controller.
      2. Install Drivers: Some phones do this automatically. If not, use the Sixaxis Controller app to install what’s needed.
      3. Check the Controller: Try it in a game to make sure it’s working right.
  • For iOS Devices:
    • Third-Party Apps: Apps like “PS3 Controller for iOS” or “Sixaxis Controller” can help. Install one of these from the App Store and follow the instructions to pair the controller with your device.
    • Bluetooth Adapter: Get a Bluetooth adapter that works with iOS, plug it into the Lightning port, and pair your PS3 controller with it.
    • Jailbreaking: Jailbreaking lets you bypass some of Apple’s restrictions. But be careful—it can void your warranty and mess with your device’s security. If you go this route, use the “Sixaxis Pairing Tool” after jailbreaking.
Common Problems and Fixes
  • Controller Not Showing Up:
    • Make sure it’s in pairing mode—check those PS and Share buttons.
    • Toggle Bluetooth off and on again.
    • Restart your phone if all else fails.
  • Controller Connected but Not Working:
    • Check if the game supports controllers.
    • Adjust the controller settings within the game if needed.
  • Connection Drops or Is Unstable:
    • Move away from other Bluetooth devices or sources of interference like Wi-Fi routers.
    • Make sure the controller’s battery isn’t low.
  • Sixaxis Controller App Issues:
    • Update the app if it’s out-of-date.
    • Grant the app any needed permissions.
Games That Work Well
  • Android: Emulators and many games like Asphalt 8, Real Racing 3, Dead Trigger 2, and Modern Combat 5 work great with the PS3 controller.
  • iOS: Games that support MFi controllers like Asphalt Overdrive, Real Racing 3, and GRID Autosport should also work once you’ve got the controller set up.
Extra Tips
  • Controller Settings: Once connected, tweak settings like vibration and light brightness to your liking.
  • Firmware Updates: Keep your controller’s firmware updated through the PS3 console for the best performance.
  • Community Help: If you’re stuck, gaming forums and online communities can be super helpful.
Alright, let’s dive into connecting your PS3 controller to your phone. Whether your Android gizmo is rooted or not, we’ve got you covered. Here’s what you need.
First off, grab these goodies: a bonafide PS3 controller from Sony, a trusty USB cable for the controller, and if your phone’s not rooted and doesn’t do Bluetooth straight-up, snag an OTG cable while you’re at it. Rooted devices also need the Sixaxis Controller app.
Now, if you’re dealing with a rooted phone, here’s the magic formula:
  1. Get your device rooted (it’s a bit of a gamble as it might nix your warranty, but hey, no adventure without a little risk, right?).
  2. Pop onto Google Play and nab the Sixaxis Compatibility Checker. Cross your fingers and check if your phone’s got the thumbs-up for controller compatibility.
  3. Shell out a couple of bucks for the Sixaxis Controller app—download, install, and let’s get going.
  4. Connect that PS3 controller to your phone via the USB cable (with the trusty OTG adapter). Those blinking lights on your controller mean you’re on the right path.
  5. Jump into Bluetooth settings: inside the app, tap “Pair Controller,” type in your phone’s Bluetooth address, smack “PAIR,” and give it an “OK”.
  6. Yank the USB cable once you’re paired and simp through the process.
  7. Press the “PS” button on your controller and voila, “Client 1 connected” should pop up.
  8. Finally, test things out by cruising through your phone’s menus or diving into some gamepad-friendly games.
Now, for the non-rooted phone folks, here’s the sweet and simple method:
  1. Make sure your phone’s cool with OTG—some models need a nudge to recognize controllers.
  2. Connect through that OTG cable and hook up the PS3 controller via its USB cable.
  3. Wait a sec. Your phone should flash a box around its icon, showing it’s all set to chat with the controller.
  4. Once that pops up, you should be ready for action—use your controller for anything that lets you ditch touchscreen woes.
And hey, if things get wonky, peek around to see if any rogue Bluetooth devices are messing with your connection, or check that all permissions and cables are playing nice.
Follow along and you should be gaming like nobody’s business with your PS3 controller hooked up to your Android phone. Cheers!
How to Connect a PS3 Controller to a Phone
Alright, so you want to hook up your PS3 controller to your phone? It’s actually simpler than you might think, although there are a few bumps you might hit along the way. Let’s dive right in.
What You Need
  1. Your Device
    • Android: If you’ve got an Android phone, you’re in luck—these devices generally play nice with PS3 controllers via Bluetooth. iPhones, however, can be a bit stubborn due to restrictions.
    • Bluetooth: The PS3 controller uses Bluetooth 2.0, which is a bit old school, so you might need an extra nudge from some apps if your phone rocks a newer version.
  2. Your Gear
    • Make sure that PS3 controller is charged up. You might need a USB cable for that first-time setup or if things go haywire.
Ways to Connect
Method 1: The Old-School Bluetooth Way
Perfect if your Android phone is Bluetooth-friendly:
  1. Get Your Controller Ready:
    • Press the PS button and the Options/SHARE button together for about 3-5 seconds until those little LED lights start dancing.
  2. Connect Using Your Phone:
    • Hop into your phone’s Bluetooth settings, scan for devices, and grab “Wireless Controller” or something similar from the list.
If Things Don’t Connect…
  • Not Pairing?
    • Why? Sometimes the Bluetooth on your phone doesn’t mesh well with the controller, especially if you’re sporting an old OS.
    • Fix It: Try using an app like Sixaxis Controller or Bluetooth Pairing Helper. They’ve got your back.
  • Connection Drops?
    • Seriously—turn your stuff off and on again. It works wonders.
Method 2: The Third-Party App Route
For phones that like to keep things complicated:
  1. Sixaxis Controller App:
    • Snag the Sixaxis Controller app for Android and SixaxisPairTool for PC or Mac.
    • Hook your PS3 controller up to your computer with a USB cable.
    • Pop your phone’s bluetooth MAC address (reversed) into SixaxisPairTool, save, disconnect, and pair through the app.
  2. Or Try MotioninJoy:
    • Install this one on a PC, plugin your controller with a USB, and change up the Bluetooth settings to make them a match.
Heads Up:
  • Make sure USB debugging is on if the app asks for it.
  • Stay away from macOS/Linux tools unless they’re a perfect match.
Troubles? No Sweat.
  1. Controls Going Haywire?
    • Why’s That? Could be your button mapping is all out of whack.
    • How to Fix: Dive into emulators like PPSSPP or RetroArch for some solid customizing options.
  2. Battery Draining Fast?
    • Turning off vibration can save a bit of juice.
  3. Signal Noise:
    • Keep your controller within about 10 meters from your phone, with no pesky obstacles in the way.
Why This Works
PS3 controllers are designed for PS3 consoles, so getting them to cooperate with other devices involves a bit of tech magic. Honestly, it’s all about using apps that emulate profiles or bend the pairing rules a bit.
If you’re still hanging, check out guides specific to your apps or join some discussions on community forums like XDA Developers. Good luck!
So you wanna hook up your PS3 controller to your phone and seriously level up your gaming? You’ve landed in the right spot. Whether your Android device is rooted or not, we’ve got you covered.
For Non-Rooted Phones:
  • First things first, grab the Sixaxis Compatibility Checker from the Google Play Store to see if your phone even plays nice with the controller.
  • Next up, you’ll need the Sixaxis Pair Tool. Head over to the Dancing Pixel Studios site, snag it, and install it on your computer.
  • Once that’s sorted, launch the Compatibility Checker app to snag your phone’s Bluetooth address. This little detail is key in the whole pairing dance.
  • Alright, plug your PS3 controller into your computer via USB. Fire up the Sixaxis Pair Tool, punch in your phone’s Bluetooth address, and boom! They’re a pair.
  • Back to your phone now–grab the Sixaxis Controller App from the Play Store.
  • Open it up, hit ‘Start,’ then press the PS button on your controller. If all goes to plan, you’re connected.
For Rooted Phones:
  • Now, if your device is rooted, things are a tad different. Make sure your phone is properly rooted before diving in.
  • You’ll need to get the Sixaxis Controller App from the Play Store, just like before.
  • Don’t forget to flip your Bluetooth on!
  • This time, connect your controller to your phone using a USB OTG cable for that initial handshake. Pop open the Sixaxis Controller app, hit ‘Start,’ then press the PS button. And just like that, your controller’s ready to wirelessly rock your gaming world.
And there you have it! Follow these steps to get your PS3 controller buzzing with your phone. For those who want more geeky details, a quick search on community forums or official support pages could be worthwhile.
