How Can I Check My SSD Speed on Windows 10?
346 viewsComputer
Want to see how snappy your SSD really is on Windows 10? You’ve got a few great options to check those speeds!
  • Hit Up the Command Prompt:
    1. Do the Windows + X shuffle and pop open Command Prompt (Admin) or Windows PowerShell (Admin).
    2. Type winsat disk -drive c and hit Enter. If your SSD isn’t on the C: drive, just change the letter to the right one.
    3. Sit tight and watch as it spits out your read and write speeds.
  • Third-Party Software to the Rescue:
    • CrystalDiskMark: This trusty tool is a favorite for a reason. Download it, fire it up, pick your SSD, and click Start to get your results.
    • AS SSD Benchmark: This one’s built for SSD fanatics. Just like CrystalDiskMark, install it, select your drive, and get testing!
  • Old Reliable Task Manager:
    1. Smash that Ctrl + Shift + Esc combo to open the Task Manager.
    2. Check out the Performance tab and find your SSD on the side panel.
    3. It’s great for a quick look, though it’s more about live data than hardcore numbers.
You’ve got options, whether you’re just curious or diving deep into those numbers. Command Prompt gives you the basics fast, third-party tools get into the nitty-gritty, and Task Manager is all about that real-time action. Just make sure any tool you snag is from a legit spot—safety first!
To get to the bottom of checking your SSD speed on Windows 10, here’s a no-nonsense guide with some tips and tricks that’ll get you sorted:
First up, let’s talk built-in tools. You can use Windows\’ own gadgets if you’re not keen on downloading extra stuff. Pop open PowerShell or Command Prompt with admin rights and type in:
winsat disk -drive [letter]
This command spills the beans on how your disk\’s holding up in both the read and write speed areas. It’s straightforward and gives you the numbers in MB/s – pretty handy if you ask me. Plus, if you’re on those Windows 10 Insider builds (20226 and up), you can hop into the Storage settings. Head to Settings > System > Storage > Manage Disks and Volumes, and you’ll find health metrics that’ll shed more light on your SSD’s status.
Now, if you like a bit more jazz, check out third-party software like CrystalDiskMark or AS SSD Benchmark. These guys are great for seeing how your drive matches up to the numbers the manufacturer promised. You can even go for something like Disk Speed Test for a simple, click-and-see result.
Here’s the kicker, though: SSD speed can give you the runaround sometimes. Interface limitations (think SATA III versus NVMe), write cache policies, misaligned partitions, and full drives can all cramp your SSD’s style. It’s like having a fast car stuck in traffic – not fun!
If you’ve got the speed blues, you might want to tweak some settings. Enable write caching through Device Manager (but be careful; don’t switch off the write-cache buffer flushing unless you’re cool with potential data loss). Check your 4K alignment through Command Prompt to make sure things are running as they should. And for goodness\’ sake, update those firmware/drivers! Go snag the latest version from your SSD maker’s site and make sure your BIOS is set to AHCI mode.
Temps matter too – if your SSD gets too hot, it’ll slow down. Use a tool like CrystalDiskInfo to keep an eye on the heat. Toss on a heat sink or slap in an extra fan if you’re seeing red.
All in all, have some fun with it. Looking at sequential speeds? They’re your buddy for moving big files around fast. 4K random speeds, on the other hand, are like your behind-the-scenes crew making sure your OS is snappy. When in doubt, double-check with more than one tool; it’s not a bad idea to run a few tests after a big update, just to keep an eye on trends.
Honestly, it might seem like a lot, but once you dive in, it’s pretty straightforward. With a bit of tweaking and the right tools, you\’ll get the speed you\’re shooting for.
Ever wondered how fast your SSD really is on Windows 10? It\’s pretty straightforward to find out, and you’ve got a few solid methods to choose from. Let’s walk through some options—you might even feel like a tech guru by the end!
First up, there’s the Command Prompt. It\’s like a hidden gem right in your system toolbox. Here’s how to unleash its magic:
  1. Hit the Windows key, type “cmd,” and when Command Prompt pops up, right-click and run it as an administrator. Trust me, you’ll need those privileges.
  2. \n
  3. In the black-and-white world of Command Prompt, type: winsat disk -drive C (or swap “C” for the letter of your SSD if it hangs out elsewhere).
  4. \n
  5. Hit Enter and let it do its thing. Soon, you\’ll see figures that tell you your SSD’s sequential and random read/write speeds.
  6. \n
Now, what if you’re more of a “I want it now” person? Task Manager is here to save the day:
  1. Give your Taskbar a right-click, then select “Task Manager.”
  2. \n
  3. Pop over to the “Performance” tab.
  4. \n
  5. Click on your SSD or just “Disk” in general, and voilà! You get a live display of its read and write speeds.
  6. \n
This isn’t about deep dives into tech specs, but hey, it gives you a sense of how your SSD’s behaving in real-time.
For those with a craving for details, third-party benchmarking tools are your go-to option. You’ve got some neat choices:
  • CrystalDiskMark: Super popular and free! Pick your SSD and hit “All” to see both sequential and random speeds broken down clearly.
  • Novabench or EaseUS Partition Master: These tools not only test your SSD speeds but also give your CPU and memory a performance check-up.
  • Blackmagic Disk Speed Test: Perfect if you’re dealing with big file swaps and available for both Windows and macOS users.
These tools serve up a smorgasbord of info about your SSD, measuring things like throughput and latency that could be bogging down your system.
Honestly, if you’re like me, a quick peek via Command Prompt is usually enough to satisfy the curiosity. But if you’re really diving in—or suspect something\’s off—those third-party apps will give you all the nitty-gritty details you need to keep your SSD in top shape.
And there you have it, a handful of ways to measure your SSD’s speed without turning into a tech wizard overnight. Happy checking!
