How Do You Check Mouse Battery on a Mac?
212 viewsMouse
So you want to know how to check your mouse battery on a Mac, huh? Well, there are a few ways to do that, depending on what kind of mouse you have and your macOS version. Here’s how you can keep tabs on your battery situation:
First off, let\’s chat about the menu bar icon method. That\’s your go-to if you\’ve got the Bluetooth icon up there. If not, you might want to enable it. On macOS Ventura (13 and up), you\’d head over to System Settings and find your way to the Control Center to make this happen. Once that’s done, click on the Bluetooth icon, hover over your mouse\’s name, and voilà! You’ll see the battery percentage right there.
Another way? Well, you could mosey over to your System Settings and hit up the Bluetooth section. Your mouse should show up there with its battery status right beside it. This one\’s pretty straightforward and great if you usually get sidetracked by your menu bar.
For those of us who like to dig a little deeper, you can check the Hardware System Report. Hold down Option, click on the Apple icon, and select System Information. Head to Bluetooth under Hardware, and you should find your mouse there with the battery level info.
Now, you might run into a couple of common hiccups. If you’re not seeing the battery indicator, it could be because your mouse doesn’t follow Apple\’s Bluetooth protocol, especially if it’s from a third party. Or maybe there\’s some software drama going on. Try checking if your mouse is fully compatible and consider re-pairing it.
Got wonky battery readings? It happens. Alkaline batteries can sometimes be a bit imprecise compared to lithium ones. Trying a battery type recommended by Apple might help. Resetting your Bluetooth module can also do the trick.
Oh, and those annoying low battery alerts when you’ve just charged the thing? Your battery might be on its last legs, which tends to happen after a lot of charge cycles. A firmware update could sort out glitches if your mouse model\’s a bit old.
Want to stretch your battery life? Cut down on unnecessary features, like snazzy gesture controls. Keep your mouse in a chill, dry spot when you’re not using it. And if you\’re feeling a bit techy, third-party apps like coconutBattery can give you more detailed insight into your battery’s health.
Remember that depending on your macOS version, some features might differ. macOS Sonoma, for instance, lets you add battery widgets to the Notification Center. Pre-Ventura, you might have to access battery status via System Preferences instead.
In a nutshell, keeping an eye on your mouse’s battery doesn’t have to be a hassle. These methods should help you stay charged and ready to go. And if things go way out of hand, don’t hesitate to hit up Apple Support. They\’ve got your back.
Here’s a rundown on how to keep tabs on your mouse battery when using a Mac. Whether you’re rocking an Apple Magic Mouse or a trusty third-party Bluetooth mouse, I’ve got the inside scoop for you.
Magic Mouse Battery Check:
System Preferences: Wanna take a peek at your Magic Mouse battery? Pop open the Apple Menu up top, head over to System Preferences, and then hit Bluetooth. Boom, you’ll spot your Magic Mouse there with the battery level right beside it.
Menu Bar: If you’re the type who likes the quick glance, check out the Bluetooth icon on your menu bar. Hover over your Magic Mouse there, and it’ll show you the battery percentage. Easy peasy!
Third-Party Bluetooth Mouse:
System Information: Now, for a third-party mouse, you might need to dig a bit deeper. Head to Applications, then Utilities, and hit up System Information. Click on Bluetooth in the sidebar, and fingers crossed, you’ll see your mouse there with some battery info.
Third-Party Apps: Sometimes, macOS doesn’t play nice with all the third-party gear. In that case, you might want to scout for apps like BetterTouchTool or Battery Monitor from the Mac App Store. They can lend a hand with monitoring those tricky battery levels.
Keeping your mouse in check is pretty straightforward with these tips, and let’s face it, nobody wants their mouse dying in the middle of something important. For more nitty-gritty details, Apple Support has your back, or check your mouse manual if things get tricky.
How to Check Mouse Battery on a Mac
Wondering how to check your Magic Mouse\’s battery on a Mac? You\’ve got a few handy ways to do it:
  1. Peek at the Menu Bar
    • Just give the Bluetooth icon up in the menu bar a click. Boom! You\’ll see the battery levels for your connected devices, like your Magic Mouse.
    • Don\’t see the Bluetooth icon? No worries. If you\’re using macOS Ventura or later, go to System Settings > Control Center and choose “Show in Menu Bar” for Bluetooth. On older versions, head to System Preferences > Bluetooth and tick the box that says “Show Bluetooth in menu bar.” Simple as that.
  2. Go Through Control Center
    • Got a newer macOS like Ventura or Sonoma? Click the Control Center icon up top, select Bluetooth, and there you go—the battery details for your Magic Mouse pop right up.
  3. Dive into System Preferences or Settings
    • You can also open System Settings or System Preferences, head over to the Mouse section, and spot the battery percentage right there.
    • Alternatively, check it from the Bluetooth settings pane too—just hover over your device, and you\’ll see the magic numbers.
  4. Tech-Savvy Shortcut: Widgets or Terminal
    • If you like keeping an eye on your gadgets, add the Batteries widget to your Notification Center. You\’ll always know what\’s up with your battery.
    • Feeling a bit more techy? Fire up Terminal, type “ioreg -c BNBMouseDevice | grep \’BatteryPercent\’ =” and hit enter. Bam! Instant battery percentage.
These tips come from folks who’ve been there, done that. So, whether you\’re using an older Mac or the latest and greatest, pick the method that suits you best. That way, you\’re never caught off guard by a surprise mouse shutdown!
