How Can I Check My Monitor Model in Windows 10?
452 viewsComputer
Checking out the model of your monitor in Windows 10 can be done with a mix of software tools and a good old look at the screen itself. Let’s break it down step by step to help you figure it out.
Ways to Find Out Your Monitor Model
1. Through Windows Display Settings
If you want a quick peek using Windows, here\’s how:
  • Right-click anywhere on your desktop and pick Display settings. Then head to Advanced display settings.
  • If you use more than one screen, pick the right one and check out the Display information.
  • Try to spot the Monitor name or Model in the Display adapter properties section.
Why? This taps into your monitor’s EDID, which holds some basic gear info for the OS. But hey, how well this works depends a lot on your drivers.
2. By Checking the Device Manager
If you\’re up for a bit more technical stuff, try this:
  • Hit Win + X and click on Device Manager.
  • Pop open the Monitors section and double-click on your monitor.
  • Switch to the Details tab and choose Hardware Ids from the dropdown menu.
  • See if there\’s a model code (something like MONITOR\\ABC123) and look it up online.
The scoop? Those hardware IDs often tell you exactly what’s what, dodging any generic name issues from regular drivers.
3. Using the System Information Tool (msinfo32)
For those who love the nitty-gritty:
  • Press Win + R, type msinfo32, and smash that Enter key.
  • Head over to Components and then Display.
  • See if you can catch Name or Description with the details you need.
Heads up, though. If the drivers aren’t up to date, you might just see “Generic PnP Monitor.” Yeah, it can be a little vague sometimes.
4. Command Line/PowerShell Magic
If you like using the terminal, here\’s how to get the info:
  • Command Prompt: wizmic path Win32_DesktopMonitor get Name,MonitorManufacturer
  • PowerShell:
    Get-WmiObject -Namespace root\\wmi -Class WmiMonitorID | ForEach-Object { Write-Output \"Manufacturer: $([System.Text.Encoding]::ASCII.GetString($_.ManufacturerName))\" Write-Output \"Product Code: $([System.Text.Encoding]::ASCII.GetString($_.ProductCodeID))\" }
    FYI: PowerShell here decodes some techie stuff into plain text.
Running Into Issues? Let’s Sort \’Em Out
Scenario 1: Seeing “Generic PnP Monitor” Instead of Your Model
  • Why It Happens: Your drivers might be out of date or missing.
  • Fix It:
    1. Hop onto the manufacturer\’s site (like Dell or HP) and nab the latest INF driver.
    2. In Device Manager, right-click your monitor, choose Update driver, and then let it browse to your newly downloaded INF file.
    3. Give your computer a restart and check again.
Scenario 2: Your Monitor Doesn’t Show Up at All in Device Manager
  • Why It Happens: Could be a loose cable, or sometimes the hardware is just acting up.
  • Fix It:
    1. Double-check those cables (HDMI, DisplayPort, or whatever you’re using).
    2. Try plugging the monitor into another computer and see if it’s okay there.
    3. If nothing else works, try resetting the monitor with its onboard menu.
Scenario 3: EDID Data Goes Haywire
  • Why It Happens: Usually due to bad firmware or display adapter hiccups.
  • Fix It:
    1. Try third-party tools like Monitor Asset Manager to grab the raw EDID data.
    2. You might have to check the EDID values against info from the manufacturer.
A Few Other Tricks
  • Have a Look at the Monitor Itself: Check out the back or bottom for any labels with the model number (something like \”LG 27GN850-B\”).
  • Take a Peek at the OSD Menu: That’s your monitor\’s built-in menu for any information.
Why You Should Mix It Up
Depending on Windows alone might not always cut it because of all the driver drama. Combining software searches with a bit of hands-on inspection is usually your best bet. And if you’re in charge of quite a few monitors (like at a workplace), you can use PowerShell scripts for handling big numbers.
If you want even more control, check and see if your monitor’s manufacturer has a special tool (like Dell Display Manager) that lets you tweak things like color settings or firmware updates.
Looking to figure out which monitor model you’ve got in Windows 10? Don’t worry, it’s a breeze. Here are some simple ways to do it:
  1. Display Settings:
    • Give a right-click on your desktop and hit Display settings.
    • Slide on down to Advanced display settings and give it a click.
    • Check under Display information — you might spot your monitor’s name or model here.
  2. Device Manager:
    • Right-click the Start button and choose Device Manager.
    • Pop open the Monitors section.
    • Right-click your monitor, then tap on Properties.
    • In the Details tab, choose Hardware Ids from the dropdown to sniff out any model info.
  3. System Information:
    • Press Windows+R to pop open the Run box.
    • Type in msinfo32 and smack Enter.
    • Head to Components > Display.
    • You might stumble upon some deets about your monitor, like the model number.
And here’s the kicker: You don’t need anything fancy, just what Windows 10’s already got on board. If it plays hard to get, maybe check those cables or update your display drivers in Device Manager. Easy peasy.
To check your monitor model in Windows 10, there are several reliable methods you can use. Here’s a step-by-step guide incorporating multiple approaches:
  1. Using Windows Settings:
    • Open the Start menu and click the Settings icon (the gear).
    • Go to System > Display, then scroll down and click on “Advanced display settings.”
    • On this screen, you’ll find key details about your monitor including the model, resolution, and refresh rate. This method provides a quick way to access basic monitor details without additional tools .
  1. Using Device Manager:
    • Right-click on the Start menu and select “Device Manager.”
    • Expand the “Monitors” section.
    • Right-click your monitor entry and select “Properties.”
    • In the Properties window, under the “Details” tab, you can choose various properties from the drop‐down list to view the device’s identification information. This is useful when Windows has already identified the monitor model, although sometimes it might display as a generic name .
  1. Using PowerShell with WMI:
    • Open PowerShell with administrative privileges.
    • Run the following command:
Get-WmiObject WmiMonitorID -Namespace root\wmi |
  Select-Object @{l=”Manufacturer”;e={[System.Text.Encoding]::ASCII.GetString(_.ManufacturerName)}},   @{l=”Model”;e={[System.Text.Encoding]::ASCII.GetString(.UserFriendlyName)}},
  @{l=”SerialNumber”;e={[System.Text.Encoding]::ASCII.GetString($
.SerialNumberID)}}
• This command retrieves detailed information directly from the monitor’s firmware, decoding the manufacturer, the user-friendly model name, and even the serial number using the Windows Management Instrumentation (WMI) classes. This approach is particularly effective when you need more precise technical details that might not be visible in the standard display settings .
  1. Third-Party Tools:
    • Tools like Speccy, HWInfo, or AIDA64 can also provide comprehensive details about your monitor.
    • After installation, navigate to the display section within these applications to view model numbers and other specifications. These tools are especially useful for troubleshooting or when you plan to set up multi-monitor configurations with detailed hardware insights .
Each of these methods has its benefits—Windows Settings and Device Manager are quick and built into the operating system, while the PowerShell command provides a deeper dive into hardware details, and third-party tools offer a comprehensive overview if you’re troubleshooting specific issues. Using multiple methods not only verifies the monitor’s model but also ensures that you have access to additional specifications should you require them for advanced display adjustments or hardware compatibility checks.
