How Can I Check the Refresh Rate of My Monitor on Different Systems?
360 viewsMonitors
If you’re curious about how many Hz your monitor is rocking, there’s a pretty easy way to check it out on Windows. Now, before we jump in, why does this matter? Well, the refresh rate is basically how many times per second your screen updates its display, which is super important if you want smooth visuals, especially when you’re gaming or watching fast-paced videos. Here’s how you can get the lowdown on your monitor’s refresh rate:
Alright, first up, let’s dive into your display settings. Right-click on your desktop – yup, just anywhere on it – and you’ll see a menu pop up. Click on “Display settings” and voila, you’re in the display configuration zone.
Once you’ve got the Display settings window open, scroll on down until you find “Advanced display settings.” Click it, and you’ll get a whole new screen with all sorts of details about your displays.
Now, keep your eyes peeled for the “Display Information” section. You should see some deets about your current monitor setup, including the resolution and, of course, the refresh rate. It’ll look something like “Refresh rate: 60 Hz” or “144 Hz,” depending on what monitor you’re rocking. If you’ve got more than one screen hooked up, make sure you’re checking the right one in that dropdown menu.
Thinking about switching up your refresh rate? No worries, I’ve got you covered. Just click the dropdown menu under “Choose a refresh rate,” and pick from the options that pop up. Higher is usually better for things like gaming, so go for the max if possible!
Speaking of gaming, if you’re rolling with an Nvidia graphics card, you’ve got another trick up your sleeve. Right-click your desktop again and choose “Nvidia Control Panel.” Head to “Display” and then “Change resolution.” You’ll see a dropdown that lets you mess with different resolutions and their refresh rates.
Not a fan of digging through settings? Websites can do the refresh rate detective work for you. Just run a quick online test, and these sites will spill the beans on your refresh rate.
And there you have it! Easy-peasy steps to check your monitor’s Hz. Time to get those visuals smoother than a fresh jar of Skippy peanut butter.
Want to know how fast your monitor can refresh? It’s pretty simple, whether you’re on Windows or a Mac. Let’s dive in.
On Windows:
  • First off, hit the Windows button on your keyboard, then select that little gear icon to get into Settings. If you want to be quick about it, try pressing Windows + I simultaneously.
  • Next, go to System, and from there, head over to Display.
  • As you scroll, you’ll come across Advanced Display Settings – give that a click.
  • There you’ll find your monitor’s specs, including how many times it can redraw in a second, labeled as “Refresh rate (Hz)”.
On Mac:
  • Mac users, click that iconic Apple logo up top, and head into System Preferences.
  • Pick Displays and make sure you’re hanging out in the Display tab.
  • Here’s the trick: hold the Option key and select Scaled. Voilà! You’ll see a list of refresh rates. The one with the checkmark is your current setting.
Here’s a quirky tip: If you’re still scratching your head, your monitor’s manual or the manufacturer’s website might have the scoop on your refresh rate. It’s a bit old school, but it works!
And there you have it. Poke around your settings following these steps, and you’ll uncover your monitor’s refresh rate without breaking a sweat. Your screen will be sharper, and who doesn’t want that?
