How to Check Ethernet Port Speed Windows 11?
390 viewsComputer
If you’re curious about checking your Ethernet port speed on Windows 11, you’ve landed in the right spot. There are a few down-to-earth ways to get it done using tools on your computer.
First off, you might wanna try the Settings method. Here’s how you can roll with it:
  1. Get into Settings: Hit the Start button on your taskbar or just press Windows + I to pop open the Settings. Easy peasy!
  2. Head over to Network & Internet: Click on ‘Network & internet’ from the sidebar.
  3. Choose Ethernet: For those using a cable, hit up the ‘Ethernet’ option. If Wi-Fi’s your jam, you’ll need to click on ‘Wi-Fi’.
  4. Dig into Properties: Under Ethernet settings, find ‘Properties’ and give it a click.
  5. Find Out Your Link Speed: Look for the “Link speed (Receive/Transmit)” bit. It’ll show you the Ethernet speed, like 100 Mbps or 1 Gbps, depending on your setup.
Wanna dive into the old-school methods? Here’s a peek:
Control Panel Style:
  1. Fire Up Control Panel: Simply search for ‘Control Panel’ and open it up.
  2. Go to Network and Sharing Center: Switch to ‘Large icons’ or ‘Small icons’ view, then hit ‘Network and Sharing Center’.
  3. Peek at Your Connection: Click on the link for your active Ethernet connection next to ‘Connections’.
  4. Check Out the Status Window: A window showing your connection details will pop up.
  5. Spot the Speed: The ‘Speed’ field will let you know your connection’s speed.
Feeling a bit techy? PowerShell’s got your back:
  1. Pop open PowerShell: Right-click the Start button, then choose ‘Windows Terminal’ or ‘Windows PowerShell’.
  2. Run This Command: Drop in this line:
  3. Get-NetAdapter | select interfaceDescription, name, status, linkSpeed
    and hit Enter.
  4. See What’s What: The output shows all network adapters and their speeds. Zero in on your Ethernet adapter for what you need.
Lastly, don’t forget our buddy, Task Manager:
  1. Open Up Task Manager: Press Ctrl + Shift + Esc.
  2. Navigate to the Performance Tab: Click the ‘Performance’ tab.
  3. Select Ethernet: Go for the ‘Ethernet’ option on the left.
  4. Check the Link Speed: Right there, you’ll see the magic number showing your speed.
There you have it—simple tricks to figure out what’s happening with your Ethernet port speed on Windows 11. Give them a whirl and make sure your setup is as slick as it should be!
Your Guide to Checking Ethernet Port Speed on Windows 11
The Basics
Knowing your Ethernet port speed is key for nailing down any connectivity issues, confirming whether your device supports something like gigabit speeds, and making the most of your network. Whether your internet is dragging, you’re double-checking your adapter specs, or you’re making sure you can hang with high-speed networks, understanding this is clutch.
How to Check Your Ethernet Speed
Option 1: Windows Settings
Here’s What You Do:
  1. Hit up Settings (Windows key + I).
  2. Go to Network & Internet and select Ethernet.
  3. Pick your active Ethernet connection.
  4. Scroll down to Properties, then look for Link speed (Receive/Transmit)—it’ll tell you if you’re hitting something like 1000/1000 Mbps for gigabit.
Heads Up: What you see here is more about the negotiated rate with your router or switch rather than the actual port capacity.
Option 2: Control Panel
Steps:
  1. Fire up Control Panel by searching through the Start menu.
  2. Head into Network and Internet, then Network and Sharing Center.
  3. Tap Change adapter settings. Right-click on Ethernet and hit Status.
  4. Check out the Speed field—for example, 1.0 Gbps if you’re cruising at gigabit speeds.
Catch: The speed here shows your current connection speed, which can fluctuate based on network conditions.
Option 3: Device Manager
Steps:
  1. Give the Start button a right click, then go to Device Manager.
  2. Open up Network adapters and double-click your Ethernet device.
  3. Pop over to the Advanced tab and snoop around for settings like Speed & Duplex or Link Speed.
Why Do This?: It’s perfect for verifying if your adapter supports gigabit speeds—look out for anything like “1.0 Gbps” or “1000 Mbps.”
Option 4: Third-Party Tools
Get help from tools like NetSpeedMonitor, or use built-in utilities in security suites such as PC Manager to keep tabs on real-time speed and track historical data.
Common Pitfalls & Fixes
Speed Doesn’t Match Expectations
  • Why?: Older drivers, iffy cables, or your router/switch might not be up to the task.
  • How To Fix It:
    • Update your network adapter driver through Device Manager by selecting Update driver.
    • Try a Cat 5e/6 cable—it can handle gigabit speeds better.
    • Make sure your router/switch ports have gigabit capabilities (like being able to hit 1 Gbps).
Speed Reporting Is Off
  • Why?: Software could be misreporting, or there might be a duplex mix-up.
  • How To Fix It:
    • Manually adjust speed/duplex settings in Device Manager. Go to the Advanced tab and pick 1.0 Gbps Full Duplex.
Stuck at 100 Mbps
  • Why?: Old cables (Cat 5), driver hang-ups, or BIOS settings could be the culprits.
  • How To Fix It:
    • Swap out those cables for Cat 5e/6.
    • Turn off power-saving features for your network adapter in Device Manager.
Extra Tips
  • Spot Checks: Peek at the Ethernet port LEDs—some devices show green or orange for gigabit.
  • Speed Tests: Use websites like Ookla for speed tests to see how your actual internet performs compared to port capability.
Using these pointers, you’ll be well on your way to sorting out your Ethernet connection in Windows 11. Dive in and get your network running smooth!
Wondering how to check your Ethernet port speed on Windows 11? Let’s dig right in and get you sorted!
First Up: Network Status in Settings
  • Get into Settings: Hit the Start button, then dive into ‘Settings’ or just press Win + I.
  • Check Out Network & Internet: Once you’re in Settings, find ‘Network & Internet’.
  • Peek at Ethernet Status: Click on ‘Ethernet’ to see what’s happening with your connection. Check the speed under ‘Properties’ like you’re scanning a menu at your favorite restaurant.
Next Move: Command Prompt
  • Fire Up Command Prompt: Press Win + X and pick ‘Command Prompt (Admin)’ from the list.
  • Type Like a Pro: Punch in netsh interface ipv4 show subinterfaces and hit Enter. There you’ll find your speed in the ‘Speed’ column. How neat is that?
The Power of PowerShell
  • Hop Over to PowerShell: Tap Win + X again and go for ‘Windows PowerShell (Admin)’.
  • Swing Into Action: Type Get-NetAdapter | Select-Object Name, LinkSpeed and smash Enter. Check out the link speeds—simple as pie!
And Don’t Forget: Task Manager
  • Launch Task Manager: Press Ctrl + Shift + Esc to pop it open.
  • Navigate the Performance Tab: Head to ‘Performance’ and click on ‘Ethernet’ in the sidebar. You can’t miss the speed in the top right corner.
By running through any of these methods, you’ll easily nail down your Ethernet port speed in Windows 11. This info is handy for sorting out network troubles and making sure your connection’s as speedy as you need it.
