How to Check Airpods Battery on Android?
328 viewsPhone
AirPods have become super popular as wireless earbuds, but since they’re mainly designed for Apple’s ecosystem, keeping an eye on their battery status on an Android device can be a bit tricky. Let’s dive into some ways to get this done:
Background
AirPods are built for iOS with cool features like instant pairing, Siri, and on-the-go battery checks. For Android folks, these perks aren’t readily available due to the closed-off nature of Apple’s system. So, we often need a few workarounds to keep track of the battery.
Methods to Check AirPods Battery on Android
Check via Charging Case
Here’s a straightforward trick: use the charging case. When you pop open your AirPods case near your Android phone, a window might show up displaying the battery levels for both the AirPods and the case. This is hit or miss and mostly works with newer AirPods models like the AirPods Pro and (3rd generation), but don’t keep your fingers crossed if you’ve got an older pair or an older phone.
Check via Bluetooth Settings
While Android’s Bluetooth settings don’t give detailed battery info, newer Android versions throw us a bone with some basic insights:
  1. Hop into Settings.
  2. Go over to Bluetooth & device connection.
  3. Find your AirPods in the connected devices list.
  4. Some devices might show you a general battery percentage.
It’s not perfect, but it gives you an idea of where things stand.
Use Third-Party Apps
Thank goodness for third-party apps! There are some neat ones on the Google Play Store that let you keep tabs on your AirPods’ battery:
  • AirBattery: This one’s quite detailed, showing battery levels for each earbud and the case. Plus, it pings you when the battery’s running low.
  • MaterialPods: It’s got a clean interface and mimics the iOS battery pop-up, with some customization options.
  • CAPod: An ad-free, open-source app that lays out battery levels for all components both in-app and in the notification bar.
How to Use AirBattery:
  1. Grab it from the Google Play Store and install it.
  2. Open it up and give it the permissions it needs.
  3. Pair your AirPods through Bluetooth.
  4. Open your AirPods case, and voila, battery levels should show up in the app.
Use Google Assistant
Want a hands-free method? Just ask Google Assistant. Say, “Hey Google, check my AirPods battery,” and you’ll get the current battery percentage.
Use Siri Shortcuts
If you’ve got Siri Shortcuts set up on your Android device (yes, it’s possible), craft a shortcut to quickly check the battery status with a voice command or a quick tap.
Use Widgets on Android Home Screen
For an easy-access option, add a battery widget to your home screen that supports AirPods. Long-press on the home screen, select “Widgets,” and pick a battery widget so you can check battery levels at a glance.
Tips for Using AirPods on Android
Customize AirPods’ Controls
Although AirPods are made for Apple devices, double-tap gestures for playing/pausing and skipping tracks usually work on Android. If you have access to an Apple device, use it to tweak these controls and apply them to your Android use.
Improve Connectivity & Battery Monitoring
Keep your AirPods updated by pairing them with an iOS device now and then. And stick with reliable third-party apps for accurate battery monitoring. Better yet, turn off any unused Bluetooth devices to boost connectivity.
Enable AAC Codec for Better Sound
Boost your audio quality by enabling the AAC (Advanced Audio Codec) on Android:
  1. Head to Settings > Developer Options.
  2. Look for Bluetooth Audio Codec.
  3. Select AAC for a better sound experience.
Wrapping Things Up
Even though checking AirPods battery on Android isn’t super smooth, these tips can help you out. Third-party apps like AirBattery and MaterialPods are your best bet, but the Bluetooth settings method works too on some devices. You could also check battery levels on your smartwatch if you’ve got one. Once you get these workarounds down, keeping an eye on your AirPods battery will be no sweat.
So, you want to check your AirPods’ battery on an Android phone? No worries, just a couple of steps and you’ll be good to go. And yup, you’ll need a third-party app because Android doesn’t do this natively. Let’s dive right in!
First things first, you’ll want to grab a battery-monitoring app from the Google Play Store. A few popular picks are AirBattery, PodAir, MaterialPods, and PodsBattery. We’re gonna walk through the AirBattery setup since they’re all pretty similar.
Once you’ve bagged that app, time to pair your AirPods with your Android device. Fire up the Bluetooth settings on your phone, open up the AirPods case, and hold the button on the back until the light starts flashing. This means they’re in pairing mode. Your Android should spot them in the list of available devices—just tap and connect.
Alright, let’s crack open that AirBattery app. When you launch it, you might need to give it permission to access Bluetooth and tweak some settings like disabling battery optimization to get the best performance. Once that’s sorted, you’re ready to check those battery levels.
Pop those AirPods in their case and flip open the lid. The app should do its thing and show you a neat little pop-up with the battery levels for both your earbuds and the case. If it doesn’t show, try snapping the case shut and opening it again while keeping it close to your phone.
Here’s a bonus: most of these apps are packed with cool features. You can get notifications when the battery’s running low or maybe add a widget to your home screen for quick access. Some even let you tweak touch controls on your AirPods.
Just keep in mind, some Apple-exclusive features won’t work on Android, like Siri and those fancy fit tests.
There you go, you’re all set to keep tabs on your AirPods battery life on Android. No magic required—just a snazzy little app to bridge the gap!
How to Keep an Eye on AirPods Battery Levels Using an Android Phone
We all know that AirPods play nicely with Apple stuff, but what about Android users? While you can hook them up with Bluetooth, figuring out the battery level isn’t as simple as tapping a button. Since Android doesn’t really get along with Apple’s exclusive features, here’s how you can check your AirPods’ battery life without hassle.
Why Android Users Struggle with AirPods Battery Monitoring
So, Apple packed these AirPods with fancy tech like H1/W2 chips, which do neat tricks like battery status pop-ups on iPhones. Unfortunately, Android doesn’t support these features right out of the gate, so we need to get creative and use third-party apps or other techniques.
Ways to Check AirPods Battery Levels on Android
1. Third-Party Apps to the Rescue
There are a bunch of apps out there that mimic iOS-style battery notifications. Here’s the scoop:
a. AirBattery
  • Steps:
    1. Nab it from the Play Store.
    2. Fire it up and allow it to show notifications (you’ll need to dive into Settings > Apps > AirBattery and toggle “Allow notification access”).
    3. Pair your AirPods under Bluetooth (Settings > Bluetooth > Pair AirPods).
    4. Pop open the AirPods case near your phone, and voilà—a pop-up with battery levels for each earbud and the case.
Heads-up:
  • AirBattery needs battery optimization turned off to work properly in the background.
  • Sometimes, pop-ups might be slow or decide not to appear at all.
b. AndroPods
  • Just like AirBattery, but with extra goodies like sound alerts.
  • Turn on notification access and shut off battery optimization for it to work seamlessly.
c. Battry (Paid App)
  • This one’s pretty light on permissions.
  • Comes with a handy widget for quick battery peeks.
2. Grab a Manual Bluetooth Status Check
Your Android might give you basic battery info in the Bluetooth settings:
  1. Connect your AirPods.
  2. Head to Settings > Bluetooth.
  3. Tap the gear icon next to your AirPods. You might see a battery percentage there, depending on your Android version and brand.
Keep in Mind: This method isn’t foolproof. It often works better with Samsung One UI or Google Pixel devices.
3. Try Out a Bluetooth Widget
Apps like Bluetooth Battery Widget or Battery Widget Reborn can snag battery info from connected devices:
  1. Download the widget app.
  2. Place the widget on your home screen.
  3. Select your AirPods from the device list.
Note: The widget’s accuracy can vary, depending on how well your phone plays with Bluetooth.
Troubleshooting the Common Hiccups
Problem 1: No Battery Info Available in Bluetooth Settings
  • Why: Your Android system or skin (like MIUI or ColorOS) might be blocking generic Bluetooth battery data.
  • Solution: Give AirBattery or AndroPods a try. They get around these barriers by tapping into raw Bluetooth data.
Problem 2: App Notifications Not Showing Up
  • Why: Could be battery optimization or restricted background activity.
  • Fix:
    1. Turn off battery optimization for the app (Settings > Apps > [App Name] > Battery > Unrestricted).
    2. Make sure the app is allowed notification access.
Problem 3: Battery Readings Are All Over the Place
  • Why: When AirPods go into low-power mode, battery data can lag behind.
  • Solution: Opening your AirPods case or putting an earbud in can refresh the connection.
The Inside Story: How These Methods Operate
AirPods send out battery info via Bluetooth Low Energy (BLE). On iOS, it gets decoded automatically, but Android needs apps to figure out those BLE signals. Apps like AirBattery have figured out how to decode these using some clever reverse-engineering of Apple’s protocols.
A Few Last Tips
  • Stay Updated: Regularly update your third-party apps for compatibility with the latest AirPods models, like the AirPods Pro 2.
  • Reset Time? If your AirPods keep acting up, consider resetting them (press and hold the case button for 15 seconds) and pair them again.
So, with a bit of help from third-party apps or manual checkups, Android users can keep tabs on their AirPods battery life without being shut out by Apple’s walled garden.
Alright, let’s talk about how you can check your AirPods battery on Android without losing your sanity! It’s a bit different from the Apple experience, but hey, it’s not rocket science.
Method 1: Hit Up Some Handy Apps
Yep, there are apps out there that can spill the beans on your AirPods’ battery life:
  • PodsBattery: Grab it from the Google Play Store, fire it up when your AirPods are connected, and boom—battery info pops up for both the earbuds and the case.
  • MaterialPods: Another one from the Play Store. This app goes the extra mile to give a detailed battery breakdown after you pair your AirPods.
Method 2: Play Your Tunes and See What Happens
Some music apps do more than just play your favorite jams:
  • Spotify: Got your AirPods connected? Dive into Spotify, and sneak a peek at the Bluetooth settings menu; they’ll dish out the battery level right there.
Method 3: Bluetooth Settings Adventure
Ah, the good ol’ Bluetooth settings—where magic happens:
  • Pair Those AirPods: Connect your AirPods to your Android device via Bluetooth.
  • Bluetooth Spies: Zip over to your phone’s Bluetooth settings. Your AirPods should make themselves known in the paired devices list, and if you’re lucky, the battery level will show up somewhere.
Method 4: Widget Wonders
Widgets aren’t just pretty; they’re smart too:
  • Battery Widget Reborn: Score it on the Google Play Store. Customize it to do the heavy lifting of showing off battery status for Bluetooth gadgets, including AirPods.
So, folks, these tricks let you keep an eye on your AirPods’ power while using an Android. Find what works best for you, and enjoy hassle-free listening sessions.
