How to Check Airpod Battery on Android?
380 viewsPhone
AirPods are Apple’s wireless earbuds, and when used with Apple devices like iPhones, their battery levels can be conveniently checked directly on the screen. But what if you’re an Android user who wants to keep tabs on their AirPods’ battery status? No worries, I’ve got you covered. Here are some methods to check AirPod battery levels on Android devices:
Using Third-Party Apps:
  • AirBattery: This one’s super handy for keeping an eye on your AirPods’ battery. First, pair your AirPods with your Android device. Download and install the AirBattery app from the Google Play Store. Open the app, grant the necessary permissions, and follow the prompts to select your AirPods model. Then, open the AirPods case with the earbuds inside near your phone, and a pop-up card will display their battery levels. Simple as that!
  • MaterialPods: This app brings the iPhone-like battery pop-up to Android. Get it from Google Play, launch it, and grant the needed permissions like location access for Bluetooth scanning, overlay display, and background operation. Pair your AirPods with your Android phone, return to MaterialPods, and tap the AirPods icon. If nothing pops up, double-check that your AirPods are genuine. Pick your model and preferred pop-up animation. With Bluetooth on, open the case near your phone, and the MaterialPods pop-up will show the battery levels.
  • CAPod: This one’s great because it’s ad-free and open-source. It shows AirPod battery levels both in the app and in the notification bar. Connect your AirPods via Bluetooth, download CAPod from Google Play, and open it. Tap “Continue” on the welcome screen, grant location permissions, keep the AirPods close, and open the case. You’ll get detailed info about your AirPods, including battery levels, charging status, in-ear detection, and more.
Checking via Bluetooth Settings:
Open the Settings app on your Android device, tap “Bluetooth,” and find your AirPods in the connected devices list. Tap the info icon next to your AirPods to see their battery level. This method usually gives a rough estimate shown as a percentage or a simple icon.
Using Google Assistant:
Just ask Google for help! Activate Google Assistant and say, “Hey Google, check my AirPods battery.” You’ll get the current battery percentage of your AirPods right away. Perfect for when you’re on the go.
Adding Widgets to the Home Screen:
Widgets can be a lifesaver. Long-press on your home screen, select “Widgets,” and pick a battery widget that supports AirPods. Once added, you’ll quickly see your AirPods’ battery level by glancing at your home screen.
Using the Charging Case:
Some newer AirPods models trigger a pop-up window showing battery levels when you open the case near your Android phone. Handy, right?
Other Methods:
  • Samsung SmartThings App: If you’re using a Samsung phone, the SmartThings app can help. Pair your AirPods via Bluetooth, open the app, and you can check the battery levels. Keep in mind, this might only work with certain AirPods models.
  • Siri Shortcuts: Slightly more complicated but doable. On an iOS device, use the Shortcuts app to create a new shortcut that gets the battery level of your AirPods. Add the “Show Result” action, save, and give it a name. Install the Shortcuts app on your Android device, sign in with the same Apple ID, and run the shortcut. This setup will require an iOS device initially.
AirPods are really built for Apple’s ecosystem, so checking the battery on Android isn’t as straightforward. But with a bit of effort, you can definitely find a method that works for you. Just make sure to get third-party apps from reputable sources like Google Play to avoid any security issues. And if things seem a bit off with your battery readings, a quick restart or reinstalling the app often helps.
The tech world is full of little surprises, and sometimes, you’ve just got to find the right workaround to make things work for you. Happy listening!
Alright, let’s get down to the nitty-gritty of checking the battery on your AirPods using an Android phone. Since Android isn’t keen on natively showing this info for Apple gadgets, you’ll need a little help from third-party apps. Here’s the scoop on how to do it:
Step 1: Download a Battery App
First things first, you gotta snag an app that knows how to read the AirPods’ battery levels. A bunch of these are hanging out in the Google Play Store, like:
  • AirBattery
  • PodsBattery
  • PodAir
  • MaterialPods
For simplicity, let’s roll with AirBattery, but honestly, most of these apps work pretty much the same way.
Step 2: Pair Up Your AirPods
  1. Head over to the Bluetooth settings on your Android phone.
  2. Pop your AirPods in their case and flick open the lid.
  3. Press that button on the back until the LED goes wild with white flashes. They’re now ready to mingle.
  4. Your phone should spot the AirPods in the Bluetooth list—just tap to hook ’em up.
Step 3: Get Those Permissions Sorted
After snagging AirBattery, launch the app, and you’ll probably need to give it a few thumbs-ups:
  1. Fire up the app after installing.
  2. It’ll likely ask you for Bluetooth access and to show over other apps. No sweat, just hit “allow.”
  3. If it gripes about battery optimization, best to switch it off for smoother sailing.
Step 4: Now, Check Your AirPods Battery
  1. Keep the AirPods connected and their case lid open.
  2. AirBattery should do its thing and pop up with the battery levels.
  3. Not seeing ’em right away? Try shutting and opening the case again or bring your phone closer.
Bonus Features
These apps have a few more tricks up their sleeves, like:
  • Tracking the battery for each AirPod separately.
  • Giving you the lowdown on the charging case’s juice.
  • Shooting you alerts when the batteries are on their last legs.
A Few Drawbacks
Of course, you won’t get some of the fancy iOS stuff like Siri or automatic tests. You win some, you lose some when mixing AirPods with Android.
Basically, to keep tabs on your AirPods’ battery using Android, just download a handy app like AirBattery, pair your devices, allow it the permissions, then crack open the case to see the battery status.
Alright, so you want to check how much juice your AirPods have left while using an Android device? Things ain’t perfect, but there are a few ways you can do it. Android doesn’t play nicely with AirPods battery info straight out of the box, so you’ll need a few tricks up your sleeve. Let’s dive right in.
Third-Party Apps to the Rescue
OpenPods
  • What It Does: This open-source app is your go-to for keeping tabs on AirPods battery levels. It’ll show you real-time percentages for your earbuds and charging case.
  • How to Use It:
    1. Grab OpenPods from F-Droid. Can’t score it on Google Play, thanks to licensing stuff.
    2. You’ll need to allow Bluetooth and location permissions to get it rolling.
    3. Pop open the AirPods case, fire up the app, and check out the battery levels.
  • Heads Up: Sometimes, accuracy is hit-or-miss depending on how steady your Bluetooth connection is.
AirBattery
  • What It Does: Think iOS pop-up vibes—this app shows battery status in 10% amounts. Fork out a buck for the Pro version for spot-on percentages and a handy notification shade.
  • How to Use It:
    1. Download AirBattery from Google Play Store.
    2. Pair your AirPods and Android device, then open the case near your phone for a pop-up alert.
    3. Want continuous updates? The Pro version lets you stash a widget in the notification shade.
PodsTool
  • What It Does: Simple app for battery checks, plus you get to rename your devices. Some cool features need you to pay.
  • How to Use It:
    1. Get PodsTool from an app store or its website.
    2. Open the AirPods case to connect, and the battery levels pop up.
Other Ways to Do It
Bluetooth Settings
  • How to Use It:
    1. Pair AirPods through Bluetooth settings.
    2. Hop over to Settings > Bluetooth > [Your AirPods] and take a peek if your device shows battery info.
Charging Case LED Light
  • The Lowdown: That LED light on your AirPods case gives rough hints about battery life:
    • Green: All charged up.
    • Amber: Battery’s running a bit low (less than one full charge left).
  • Limitations: Don’t expect precise numbers—this is just a ballpark figure.
WeChat Mini-Program (AirPods Tool)
  • How to Use It:
    1. Fire up WeChat and search AirPods Tool.
    2. Put your AirPods in the case, pop open the lid, and bam—battery levels should show up. Accuracy might need a little tweaking.
Got Issues? Here’s How to Fix ‘Em
Battery Readings Seem Off
  • Why? Laggy Bluetooth or app compatibility hiccups.
  • Fix It:
    • Try restarting the app or reconnecting the AirPods.
    • Make sure your app is all updated.
No Pop-Up Notifications
  • Why? App permissions may not be right, or apps might be getting forced to sleep.
  • Fix It:
    • Double-check that the app has the “Draw Over Other Apps” permission and can run in the background.
    • Turn off battery optimization for the app.
Devices Don’t Support It
  • Why? Older Android versions or manufacturers have dodgy Bluetooth protocols.
  • Fix It:
    • Rely on the LED indicator instead.
    • Test a few apps to see which one works on your device.
Why Android Keeps It Basic
It’s pretty simple—AirPods were designed with Apple gear in mind, using fancy stuff like H1/W1 chips for seamless integration with iOS. Android, meanwhile, uses standard Bluetooth profiles which don’t spill the beans on battery status unless a handy app lends a hand.
Handy Advice
  • Download apps like OpenPods or AirBattery for the best experience.
  • Keeping your AirPods firmware up-to-date via an iOS device couldn’t hurt.
  • If you’re a Huawei user, you might see battery levels right in the Bluetooth settings without fiddling with apps.
By mixing and matching these methods, you’ll keep an eye on your AirPods battery life even if Android doesn’t always play nice.
So, you’re using AirPods with an Android and need to know the battery situation, huh? No worries! There are some neat tricks to get this sorted out.
First up, let’s talk apps. Android might not have that Apple integration, but a couple of apps come to the rescue big-time:
  • PodsBattery: Grab this from the Google Play Store, pair it up with your AirPods, and boom! Instant battery info for both the earbuds and case.
  • MaterialPods: This one’s pretty popular too. Just install it, follow the pairing steps, and you’ll see your gadget’s battery status right in the notification bar.
Looking for something a little more visible? Some of these apps let you slap a widget right on your home screen. Just hold down on your home screen, choose the “Widgets” option, and voila! It’s like having battery stats at a glance.
Now, if you’re not keen on downloading more apps, there’s a simpler way by diving into your Bluetooth settings. Once you pair up your AirPods, check in the menu—sometimes there’s a little battery icon right next to your connected AirPods.
With these tricks up your sleeve, keeping tabs on your AirPods’ battery life while using Android becomes a breeze. Regularly updating your apps and AirPods firmware keeps everything running smoothly. Give these methods a spin—you’ll be glad you did!
