What’s the Best Way to Charge a Nintendo Switch Without Using the Dock?
414 viewsGame Console
The Nintendo Switch, launched in 2017, has won hearts with its hybrid feature that lets you play on the go or on a bigger screen at home. While it’s typically charged with the official dock or AC adapter, there are plenty of ways to juice it up without these. Here’s the lowdown:
Charging with the official AC adapter: Your Nintendo Switch gets along quite well with the Nintendo Switch AC adapter (model HAC-002). Just plug the USB end into the console’s bottom and then stick the adapter into a wall outlet. Make sure everything is snug, and you’re good to go. It usually fills up in about 3 hours.
Charging via USB-C port: The Switch’s USB-C port is a handy feature. You can use other USB-C chargers, but beware! Not all of them are fit for your console. Always go with a charger that matches the Switch’s needs – you’re looking for at least 39W of power. Phone chargers, typically around 13W, will have your Switch sipping power rather than chugging it. Stick with the official charger or a third-party one made for the Switch to be safe.
Charging with a USB-C power bank: A USB-C power bank is your Switch’s best friend on the go. Hook up your USB-C cable from the power bank to the USB-C port on the bottom of the Switch. Again, make sure the output matches what your Switch can handle. Bigger, reliable power banks are your safest bet to avoid running out of juice mid-game.
Charging using a third-party charging stand: There are some nifty third-party stands out there, like the Nintendo Adjustable Charging Stand or the HORI Compact PlayStand. These not only keep your Switch stable but also charge it while it’s propped up. Connect the stand to a power source, pop the Switch onto it, and voila! Some stands also let you tweak the viewing angle or offer extra USB ports for charging other gadgets.
Charging using a TV adapter: Want to play on the TV without the dock? A USB-C to HDMI adapter is your answer. Hook up your power cable and HDMI cable to the adapter, then connect it to the Switch and a power source. Your Switch will charge while you enjoy the big screen.
Charging using the Joy-Con Charging Grip: Plug the AC adapter directly into the Joy-Con Charging Grip to power up your Joy-Con controllers. Alternatively, you can connect a USB-C cable from the Charging Grip to the dock, which should be plugged into a power outlet.
Charging using a car charger: On a road trip? A USB-C car charger plugged into the cigarette lighter socket will do the job. Just make sure the charger meets the Switch’s power needs. A high-quality car charger will prevent any mishaps.
Charging using a laptop: You can even charge the Switch using a laptop if it has a USB-C port. But don’t count on it too much; the charging speed will depend on your laptop’s power supply and port capabilities. Some laptops might not provide enough power to charge your Switch effectively.
Precautions:
  • Use compatible chargers: While the Switch’s USB-C port is versatile, stick to high-quality chargers. This is especially important when in docked mode since the console draws power differently.
  • Avoid low-quality chargers: Cheap, off-brand chargers might save you a few bucks but could damage your Switch or even cause a fire.
  • Monitor charging status: Always keep an eye on the battery icon. If it’s not showing a charging symbol or the Switch gets too hot, unplug it straight away and check your charger and cable.
  • Do not overcharge: Although there’s overcharge protection, it’s still wise not to leave it plugged in for ages to keep the battery healthy.
The Switch’s USB-C port makes it easy to stay powered up. Whether you’re using the official dock, an AC adapter, a USB-C charger, a power bank, or a charging stand, just be mindful of the power requirements and prioritize safety. Happy gaming!
So, you want to charge your Nintendo Switch but leave the dock out of this equation? Let’s break down some simple ways to do just that, without getting lost in tech jargon.
First up, the obvious choice: the trusty AC adapter that came with your Switch. It’s as easy as pie to use. Just plug the USB connector into the bottom of your Switch, and then connect the AC adapter into a wall socket. Boom! You’re charging. And here’s a fun fact: if your Switch is in sleep mode, it should be juiced up in around three hours.
Got your AC adapter out of reach? No worries. A USB-C cable is your next best friend. Whether you’ve got a smartphone charger, a handy battery pack, or even a USB port on your computer, you’re good to go. Just remember the golden rule of charging: not all power sources are created equal. A charger with 5V/2A will fill up your battery faster than those low-powered ones.
You might be tempted by third-party chargers, and that’s cool, but tread carefully. Ensure they meet the power cravings of your Switch—ideally 5V/1.5A or higher. While bargains are tempting, some cheap options could do more harm than good, and nobody wants a fried Switch.
So there you have it, dock-free charging in style. Whether you’re lounging on the couch or out and about, as long as you’ve got an AC adapter or a trusty USB-C cable, you’re set. Keep those game adventures rolling!
Hey there! So, if you’re trying to figure out how to charge your Nintendo Switch without its dock, you’ve got a few solid options. Let’s jump in:
Plugging Right In
Your Switch has a nifty USB-C port on the bottom. Who needs all that extra gear, right? Here’s what you can do:
  • Stick to the basics with the official adapter: Just plug the USB-C end of the charger right into the Switch when you’re playing or kicking back in tabletop mode. It’s like your device’s bread and butter for charging.
  • Third-party chargers are a thing too: Can’t find the official one? Don’t worry. Look for a USB-PD compliant charger that dishes out at least 18W. But hey, steer clear of those dodgy ones that could leave your battery dead as a dodo.
Other Ways to Juice Up
Power on the Go: Portable Power Banks
A power bank is a lifesaver, especially if it supports USB-C PD, with a minimum of 18W. Grab one with a decent capacity—say, 10,000mAh or more—and you’ll have the power to keep gaming away from home!
USB-C to USB-A Cables
If you’re really in a pinch, a USB-C to USB-A cable will let you plug into any standard USB-A port—like your laptop, TV, or car charger. It’s not the fastest option, but it gets the job done.
Fixing Charging Hiccups
When Nothing Happens
  • Double-check your gear: Try your charger and cable with another device. If it’s a dud, time to swap it out.
  • Give the USB-C port some TLC: If there’s grime in the port blocking the connection, gently clean it with a soft brush or compressed air.
Battery Drain Saga
If your Switch is losing juice even on Sleep Mode, here’s what might help:
  • Crank down the screen brightness.
  • Switch off Wi-Fi and Bluetooth if you’re off the grid.
  • Shut down background apps/games before charging.
Picking Up After a Long Time Out
If your Switch has been in hibernation for months:
  • Plug it in for a couple of hours. Sometimes the battery needs a little time to shake off the cobwebs.
Playing It Safe
  • Those unofficial docks or sketchy chargers can spell trouble—avoid them like the plague unless they’re PD certified.
  • Be gentle with the USB-C connector; forcing it into the port can mean game over for your console’s innards.
A Quick Rundown on Why a Dock Isn’t Necessary
The dock mostly hooks your Switch up to the TV. Charging’s a whole separate affair done through that trusty USB-C port. When docked, your Switch tunes into 15V/2.6A (39W), but goes for a calmer 5V/1.5A when you’re handheld.
By sticking with these hacks, you can keep charging anywhere, no dock required. Stick to reliable gear to keep your battery running like a champ!
Alright, so your Nintendo Switch is running low on juice and you don’t have the dock handy? No sweat. Here are some tried-and-true ways to keep it powered up:
1. Grab the Original AC Adapter:
You know that handy charger you got with your Switch? The one labeled HAC-002? Just plug it into an outlet, stick the USB-C end into your Switch, and you’re off to the races. It’s super safe and gets the job done right.
2. USB-C Cable with a USB Charger:
Here’s another trick: snag a good USB-C to USB-A cable, along with a wall charger that pushes out 5V/1.5A to 5V/2A. Pop the USB-C end into your Switch and plug the other end into the charger in the outlet. If you’re unsure, brands like Anker are usually solid choices.
3. Bring the Power Bank:
If you’re out and about, a portable power bank is your best buddy. Look for one that supports USB-C PD (Power Delivery) and packs at least 18W output. Just connect your USB-C cable from the power bank to your Switch, and you’re good to go.
4. USB Ports to the Rescue:
Believe it or not, you can charge your Switch from USB ports in your car, laptop, or even some TVs. It’s not the speediest option, but in a pinch, it works. Just hook the USB-C end to your Switch and the other somewhere with power.
5. Trustworthy Third-Party Chargers:
You can go down the road of third-party chargers designed for the Switch. Just make sure you’re picking from reputable brands to keep your device safe and sound.
Keep an eye on your charging gear and skip the cheap stuff to avoid any nasty surprises. These tips should help keep your Nintendo Switch ready for action.
