Can You Charge an iPhone with Another Android Phone?
259 viewsPhone
You might’ve never thought it possible, but yep, you can charge your iPhone with an Android phone—provided it’s the right kind of Android phone. Some of the fancy new models, like those sleek Samsung Galaxy versions from the S21 onward, come with this cool trick called wireless reverse charging. Essentially, they play the role of a charging pad on the go.
So, how do you go about making this magic happen? Let’s break it down:
Step 1: Check Your Android’s Capabilities
First things first, see if your Android is up for the task. Not every phone has this talent, so dig into the settings or check specs to find out. Samsung’s usually got this feature parked in the Quick Settings, so give that a look.
Step 2: Turn On Wireless Power Sharing
Okay, got a compatible phone? Sweet. Now, wake that Android up, swipe down from the top, and hunt down that Wireless Power Sharing icon. If it’s playing hide and seek, you might need to hit an edit button to add it to your panel. Once it’s on, you’re ready to share some juice.
Step 3: Get Things Ready
You might want to peel off any cases from both phones to ensure they’re cozy against each other. Lay your Android down flat so it doesn’t move around.
Step 4: Stack ‘Em Up
Now for the balancing act—put your iPhone on the back of the Android while it’s in power-sharing mode. The trick is making sure their charging coils match up. You’ll know it’s working when your iPhone gives you that satisfying charging ding.
Step 5: Keep an Eye on It
Don’t expect warp speed charging here. We’re talking a modest amount of juice, so it’s more of a “get-me-through” solution than your everyday charger. And remember, this neat trick drains the Android’s battery as it powers the iPhone.
There you have it—charging your iPhone with an Android is totally doable in a pinch. Keep it as a backup plan when you’re out and about without a cable or charger. Just remember, it’s not as quick as a wall charger and only works on select phones.
Charging an iPhone with an Android phone might seem like a crazy idea, but it’s actually doable. Let’s dig into a few ways you can make it happen, with a few hiccups to watch out for, too.
First off, if we’re talking wires, you’ll need the right cable for the job. Most iPhones, until the iPhone 15, use a Lightning port, while Androids rock the USB-C. Grab yourself a USB-C to Lightning cable (the certified type to keep your phone safe), and make sure that the Android phone plays nice with USB Power Delivery and has enough juice to share. Plug the Lightning end into your iPhone, the USB-C end into the Android, and voila! Your Android should start charging the iPhone if its battery is fuller.
Now, if you’ve got an iPhone 15 with a USB-C port, things get a bit simpler; just use a USB-C to USB-C cable and connect it right to your Android. The device with the most battery becomes the power donor. Easy peasy!
Got a fancier feature in your pocket called Wireless Reverse Charging? Android phones like the Samsung Galaxy S23 and Huawei P60 can send a power lifeline wirelessly. But you’ll need to make sure your iPhone can catch that energy (iPhone 8 or newer). You’ll just have to toggle on Wireless PowerShare on the Android, park your iPhone on its back, and you’re good to go—just make sure nothing’s in the way, like a bulky phone case.
There are a few catches, sure. Charging this way can be a bit inefficient and messy, with about a 15–20% energy loss. Plus, your Android’s battery needs to be above 20% to get the whole thing rolling.
Troubleshooting time: If stuff’s just not working, it might be because of a protocol mismatch—like an Android using QC 3.0 while the iPhone’s craving PD. Swapping out for a proper PD-compliant cable or charger might save the day. If the direction’s off—like your iPhone 15 insisting it should charge older models—you might need to juggle the battery percentages around a bit. Grab a USB-C voltage tester if you’re feeling fancy and want to check which way the juice is flowing.
And one last thing—don’t overdo it. Overheating is the enemy here, so give it a rest if things start warming up too much. Honestly, sticking with original accessories is a smart move whenever you can.
So, here’s the scoop: wired charging wins for reliability if everything’s in sync, but wireless is the chill way if you’re okay with losing some efficiency. Always double-check your cables and connections before jumping right in.
How to Charge an iPhone with Another Android Phone: Step-by-Step Guide
So, it’s totally possible to juice up an iPhone with an Android phone if you’ve got the right tools. Let’s dive into how you can make it happen:
Method 1: Using Reverse Wireless Charging
  • Check Compatibility: First off, see if your Android phone can do reverse wireless charging. Some models from brands like Samsung or Huawei have this feature.
  • Turn it On: Head into the phone settings and look under “Battery” or “Connections” to switch on this snazzy feature.
  • Line ‘Em Up: Place your iPhone on the Android’s back, making sure their centers line up for the magic to happen.
  • Watch for Life: Keep an eye on the iPhone. If it starts charging, you’re golden. If not, just tweak the placement a bit.
Method 2: Using a USB-C to Lightning Cable
  • Grab the Right Cable: You’ll need a USB-C to Lightning cable. Make sure it’s a certified one.
  • Plug and Play: Connect the USB-C end to the Android and the Lightning end to the iPhone.
  • Charging Check: Look for some sign the Android’s sharing its power. If your iPhone lights up, you’re in business.
Method 3: Using a Power Sharing App
  • Find a Cool App: Search for a power-sharing app on Google Play. Install one that works with both phones.
  • Connect Away: Hook up the Android to the iPhone using a compatible cable.
  • Let the App Roll: Follow the app’s steps to get the energy flowing.
Pretty neat, right? As long as you’ve checked everything’s compatible, you should be ready to charge your iPhone with an Android phone like a pro. It’s a handy trick for emergencies or just to show off. Just make sure everything you use is safe and certified.
