How to Change Color of Text Messages?
399 viewsPhone
Messaging apps are a huge part of our daily lives, right? But let’s be honest, the default text color can get pretty boring. So, how about we spice things up a little and change it? Now, the default messaging app on your device might not offer this directly, but no worries—there are ways around that. Check out these handy methods for different devices:
For iPhone:
  • Via the Settings App: Pop open your iPhone’s “Settings”, scroll down to “Messages”, tap “Text Message Settings”. If there’s an option for “Text Message Color”, you’re in luck—go ahead and choose your color.
  • Using Third-Party Apps: Download apps like Text Message Color Changer and Message Color Changer from the App Store. They’re packed with customization options.
  • With a Little Help from Siri: Got an iPhone 6 or newer? Just ask Siri— “Hey Siri, change my text messages to [color name]”. It’s as simple as that.
  • Browser Extensions: Yep, there are browser extensions for this too, like Text Message Color Changer. Grab one and follow the tweaks.
For Android:
  • Default Messaging App: Open your messaging app, hit the three-dot menu at the top-right, go to “Settings”, find “Chat settings”, and look for “Background” or “Theme”. Pick your color, and you’re set.
  • System Font Color: Head to “Settings”, then “Display” or “Display & Brightness”. Look for “Font Size and Style” (or similar), and you can change the text color here too, but it affects all apps.
  • Third-Party Apps: Apps like Textra and Chomp SMS from the Google Play Store offer tons of customization. Just search for text message customization, and you’ll have a variety to choose from.
For Samsung:
  • Samsung Messages App Settings: Open the Samsung Messages app, tap the three-dot menu, select “Settings”, and then “Background & Chat Colors”. Choose your color and you’re good to go.
  • Using Themes: Dive into your device settings, go to “Display”, and check out “Themes”. Find one you like, apply it, and enjoy the new look across your device.
For Other Devices:
  • Third-Party Messaging Apps: Apps like WhatsApp, Telegram, and Facebook Messenger let you change text message colors too. Just poke around their settings.
  • System Settings: Some devices let you tweak the system font color or theme from their settings. Have a look in display or theme settings.
Remember, the exact steps can differ between devices and apps, so feel free to poke around the settings or check out official help docs for your device. If you’re dabbling with third-party apps, make sure they’re trustworthy to keep your info safe.
I hope this makes texting a bit more fun and colorful for you. Happy customizing!
Want to jazz up your text message colors? Whether you’ve got an Android or an iPhone, there are some things you can try.
For all you Android users, there’s more wiggle room. Android 12 and newer versions let you play around with this cool feature called Material You. It’s all about matching your phone’s theme with your wallpaper. Just head to Settings, dive into Wallpaper & style, and pick a color scheme that vibes with your wallpaper. It’s like your phone picking out a new outfit!
If you’re rocking a Samsung, it’s a similar game plan. Jump into Settings, find Wallpaper and style, then tap on Color palette. Choose whatever tickles your fancy and check out the snazzy new look in Google Messages.
Those with special visual preferences can fiddle with accessibility features. Swing by Settings, hit up Accessibility, and explore Color and motion settings. Whether it’s color correction or a good old color flip with inversion, you’re covered.
And hey, if the built-in stuff doesn’t cut it, there’s always a slew of third-party apps like Textra that offer more customization.
Now, our iPhone friends might find it a tad restrictive. The bubble colors are set: blue for iMessages and green for SMS. It’s like the universe telling you, “That’s how it is, bud.” So, if you’re craving that blue bubble, make sure you’re both on iMessage with a stable internet connection.
The bottom line? Android users have a buffet of choices to make those texts pop, while iPhone folks are riding with the classic blue and green combo. Sometimes, you’ve just got to roll with what you’ve got. Happy texting!
So you’re itching to give your text messages a splash of color, right? Well, the options kind of swing with what you’re working with, be it your phone, app, or whatever else. Let’s dive into a few ways you could jazz up those texts:
1. Changing Text Color in Built-In Messaging Apps
Alright, here’s the scoop: most out-of-the-box messaging apps (think your basic Android Messages or iOS Messages) are pretty locked down when it comes to tweaking text colors. It’s mostly about keeping things looking uniform and easy to read. But don’t throw in the towel just yet. There are a few workarounds you might want to try on certain platforms.
For Android with Custom ROMs or themes:
  • You could snag a third-party launcher like Nova Launcher. Substratum is another good pick.
  • Then, hunt down a theme that lets you mess with message bubble or text colors.
  • It’s usually as simple as diving into your settings and finding where you can tweak Themes, specifically under Messaging settings.
For iOS, it’s a bit trickier:
  • You can’t directly mess with text colors in iOS Messages, sadly. However, one sneaky trick involves using Screen Time by pulling Messages off the “Always Allowed” list. But beware, it might go grayscale for a bit.
  • Otherwise, apps like WhatsApp or Telegram are your friends here since they offer more flexibility with how your messages look.
2. Third-Party Messaging Apps to the Rescue
Telegram’s got your back:
  • Jump into a chat, long-press the message, and hit up Formatting. From there, select the text you want to jazz up, and you’ve got a palette to choose from.
WhatsApp? Not so much, but…:
  • While it doesn’t play well with color natively, you can get creative using third-party bot tools like a Stylish Text Generator for those colorful Unicode messages.
3. Getting Technical with Developer Options (For the Brave)
For the adventurous techies among you, especially on Android, you could dig into the app code:
  • Fire up your Android Studio, and start poking around in the messaging app’s source code.
  • Specifically, you’d head over to the styles.xml file and make your tweaks there.
  • Once you’re done, patch that APK back together and load it up. Keep in mind, it’s definitely not for the faint of heart.
4. System-Wide Swaps for Accessibility
Sometimes, it makes more sense to go big-picture with system-wide changes:
If you’re team Android:
  • Head into Settings, hit up Accessibility, and explore Color Correction to see what hues you can make system-wide.
For iOS holders:
  • The path is through Settings under Accessibility, then Display & Text Size, and finally Color Filters to bring in those tint overlays.
5. Troubleshooting Hiccups
If you’re facing a few glitches, like color changes not playing nicely:
  • Check out whether it’s an OS limitation getting in the way or maybe it’s the app itself acting out.
  • A classic restart or cache clean-up might do just the trick.
There you have it, jumping into Telegram for colored messages is usually the easiest, while more technical hurdles await the tinkerers out there. Remember to test things here and there to make sure it stays readable for anyone who might be on a different device. Happy texting!
You know how sometimes chatting can feel a bit… well, plain? Brightening things up by changing the color of your text messages can really add some flair. Here’s the lowdown on how you can get it done on both iPhone and Android:
Alright, let’s talk iPhones first. Apple doesn’t let you switch up the text bubble colors straight out of the box. But fear not! There are some nifty third-party apps that can help you jazz things up:
Check this out: by grabbing apps like “Color Text Messages” or “FancyBubble” from the App Store, you can bypass the limitations. Once you’ve got one installed, dive into the options to style your message bubbles however you fancy. Just follow the app’s instructions, choose your colors and styles, and then you’re set to send these customized messages via iMessage.
Now, what’s up with Androids? Most Android devices, especially ones like Samsung with One UI, have more tricks up their sleeves and let you tweak your message appearances right from the get-go. Here’s how you can do it if you’re in luck with built-in settings:
  • For Samsung users, pop open Samsung Messages, hit settings, and shuffle over to the Backgrounds and bubbles section to start customizing.
  • If you’re rocking Google Messages, it’s worth peeking into Settings > Advanced > Chat Features for any color options that might be hiding there.
But if your device is a bit of a stick-in-the-mud when it comes to native customization, you still have options. Try out apps like “Textra” or “Chomp SMS” from the Google Play Store. Once you set one of them as your default SMS app, they’ll unlock a world of themes and bubble color choices for your messages—and voilà, instant personality boost for your chats!
By playing around with these apps and features, you can make your text messages stand out and reflect a bit of your personal flavor. Who knew texting could be so colorful, right?
