How Can I Change the Charging Sound on My iPhone?
373 viewsPhone
Changing your iPhone’s charging sound can be a fun way to mix things up a bit! You can do this by using the Shortcuts app on your phone. Let’s dive into the steps you’ll want to follow:
First up, grab your Shortcuts app, which should already be on your phone if you’re running iOS 12 or later. Accidentally deleted it? No worries, just download it from the App Store.
Next, head into the Shortcuts app and tap on Automation at the bottom. You’ll want to start a new one by hitting Create Personal Automation.
Now, here’s where you set the trigger. Scroll to the Charger option. Do you want a new sound when you plug your phone in or when you pull it out? You can pick Is Connected for when it’s juicing up or Is Disconnected if you want a tune for unplugging. Click Next when you’re done.
Time to add some flavor! Go for Add Action and here’s where you can get creative. Type in Play Music if you’re all about those tunes from your Apple Music library. Prefer for Siri to have a say? Search for Speak Text and decide what you want Siri to announce.
If you go the music route, just select your jam from the library. Make sure to set shuffle to Off and repeat to None. If you’re having Siri speak, enter the text you want her to say, like “Charging started!” and tweak her voice options if you want.
Once you’ve got that set, hit Next. Make sure Ask Before Running is turned off so your new sound kicks in automatically. Tap Done and you’re set!
Plug your phone in now to check out your fresh charging sound.
And hey, if you’d rather not hear that default ding, flip the silent switch on the side of your phone or head to Sounds & Haptics in settings to turn off System Haptics.
So there you have it, easy peasy! Now your iPhone can charge with a bit of flair!
Okay, let’s dig into how you can swap out that classic iPhone charging sound for something a bit more personal. Apple’s got its own strict ways, so it doesn’t exactly hand us the keys for a quick sound change. But fear not, there’s a nifty trick using the Shortcuts app that’ll let your phone play any sound you fancy when it charges.
First up, a little reality check: Apple keeps things locked down at the system level, so we can’t just switch out the default sound. Instead, we can add a custom sound that plays right after. The catch? The original chime might still play unless you silence your phone or turn down the volume.
Alright, here’s what you’ll need: make sure your phone’s rocking iOS 14 or newer because those are the ones that play well with shortcuts. And yep, you’ll need the Shortcuts app which generally comes pre-installed, but feel free to snag it from the App Store if it’s gone AWOL. Don’t forget to have your chosen sound file ready to roll.
Let’s hit the ground running with Method 1: Using a Pre-Saved Audio File. First, get that audio prepped. If you’re pulling it from a video, whip out Shortcuts, start a new one, and slap on the “Encode Media” action. Flip the switch to “Audio Only.” Add “Base64 Encode,” run the shortcut, and snag that code. You’re halfway there!
Now, creating the automation: In Shortcuts, bounce over to Automation and hit the “+” to kick things off. Pick “Charger,” and once you’re set on “Is Connected,” it’s go time. Add these actions: start with “Text” and drop in the Base64 code you snagged earlier, go for “Base64 Decode” set to “Decode,” and finally, hit up “Play Sound.”
Don’t forget to switch off “Run After Confirmation”—we don’t want any breaks in the flow. Once done, you’re set!
Feeling a little fancy? Check out Method 2: Text-to-Speech via Siri. Create a new automation just like above, but switch things up by adding “Text.” Type in whatever witty phrase you want Siri to belt out when you plug in, and top it off with “Speak Text.” You can personalize Siri’s voice in Settings under Accessibility if you’re feeling bold.
If things go sideways—like your automation isn’t triggering or the audio playback’s dead—ensure “Run Without Asking” is toggled on, reboot your phone if needed, and make sure your files are MP3 or AAC.
Thinking outside the Apple box, there’s also third-party apps like Toolbox Pro that might tickle your fancy. Sure, they can offer more customization, but watch out for subscription traps.
Finally, keep in mind—as if we could forget –that all these tricks might nudge the battery life a smidge and future updates may shake things up. But hey, that’s life, so make sure your shortcuts are backed up.
There you have it! With a bit of tech-savvy tinkering, charging your iPhone becomes as unique as your ringtone. Now, instead of that familiar chime, hear your favorite jingle, catchphrase, or even Ricky Bobby’s pearls of wisdom when that phone juice starts flowing!
Want to give your iPhone a bit of flair every time you plug it in to charge? Changing the charging sound is no big deal, and you can totally switch things up using the Shortcuts app. Let’s dive into how you can make it happen:
First up, pop open the Shortcuts app. It’s already there on your iPhone if you’re running iOS 12 or later, so no worries about downloading anything new.
Next, head over to the ‘Automation’ tab at the bottom. Tap ‘Create Personal Automation’ and then pick ‘Charger’ from the list. This is where the magic starts!
Okay, now you’ll want to set what triggers the sound. Choose ‘Is Connected’ so it plays your chosen tune or text whenever you plug in your charger. Hit ‘Next’ when you’re ready.
Time to add some fun! Tap ‘Add Action’ and decide whether you want a cool sound or some text spoken. If you go for ‘Speak Text’, type a phrase—maybe something quirky like ‘Juice up time!’—or pick ‘Play Sound’ and choose or add a custom sound file.
Don’t forget to switch off ‘Ask Before Running’—this saves you from extra taps every time. Hit ‘Done’ to save your new automation, and then give it a whirl by plugging in your charger.
Lastly, if you’re really looking to jazz things up, check out some third-party apps in the App Store. Just follow the instructions they provide, and you’re good to go.
A couple of quick tips: Make sure your phone’s software is up to date for compatibility, and double-check your sound file formats.
And there you have it! Personalize that boring old charging sound and make your iPhone a little more ‘you.’
