How Do I Cancel My Peacock Subscription on My Phone?
361 viewsPhone
Peacock is NBCUniversal’s streaming service, jam-packed with movies, TV shows, and original programming. If you need to cancel your Peacock subscription and you’re on your phone, here’s how you can do it:
Why Cancel Your Peacock Subscription?
  • Sometimes you gotta cut back on streaming costs, especially with Peacock’s Premium and Premium Plus plans. If that’s the case, ditching your paid plan is a good look. You can still enjoy loads of free, ad-supported content after you cancel.
  • Maybe you’ve binged all the good stuff on Peacock already and are curious about other platforms.
  • Or maybe Peacock’s interface isn’t doing it for you, and you’re fed up with how often the content updates. Whatever the reason, here’s how you can cancel it.
Ways to Cancel a Peacock Subscription from Your Phone
Canceling via the Peacock Website
  • Log In: Fire up a web browser on your phone, head over to the Peacock website, and log in with your email and password.
  • Go to Account Settings: Hit the profile icon in the top-right corner and select “Account.”
  • Check Plans & Payments: Click “Plans & Payments” in the account settings.
  • Cancel Your Plan: Click “Cancel Plan,” then confirm by hitting “Cancel Plan” again. You might need to answer a few questions about why you’re leaving. Just be honest, then click “Continue.”
Canceling via the Apple App Store (for iOS)
  • Open Settings: On your iPhone, open up the “Settings” app.
  • Access Your Apple ID: Tap your name at the top to get into your Apple ID settings.
  • Find Subscriptions: Hit “Subscriptions” in the Apple ID menu.
  • Select Peacock TV: Scroll down until you spot “Peacock TV” and tap it.
  • Cancel: Tap “Cancel Subscription” and follow the prompts. Apple will send you a confirmation email, and your subscription will continue until the end of the current billing cycle.
Canceling via Google Play Store (for Android)
  • Open Google Play: Launch the Google Play Store app on your Android.
  • Go to Account Menu: Tap your profile icon in the top-right corner.
  • Check Payments & Subscriptions: Select “Payments & Subscriptions.”
  • Find Subscriptions: Tap “Subscriptions.”
  • Choose Peacock TV: Look for “Peacock TV” and select it.
  • Cancel: Hit “Cancel Subscription” to stop payments and end the service.
Things to Keep in Mind
  • No Fees: Peacock won’t charge you anything to cancel. Feel free to cancel anytime without stress.
  • Service Continuation: Cancel your Premium plan before the billing cycle ends, and you can still use the service until it wraps up. So don’t worry about losing access immediately; you’ve got time.
  • Reactivating is Easy: Want back in? Just log into your account and pick a new plan. Everything will still be there.
Special Cases: Canceling via Other Platforms
If you signed up through something like Roku, Amazon, Xfinity, or DirecTV, you’ll need to cancel through them:
  • Roku: On your Roku device, go to the home screen, open the Channel Store, manage subscriptions, find Peacock TV, and cancel.
  • Amazon: Log into your Amazon account, go to “Account & Lists,” hit “Memberships & Subscriptions,” find Peacock TV, and cancel.
  • Xfinity or DirecTV: Check out their customer support pages for specific instructions.
Canceling your Peacock subscription is pretty straightforward once you know how. Make sure you follow the right steps for your subscription platform so you don’t end up dealing with unwanted charges. Good luck!
Hey there! So, you want to ditch your Peacock subscription on your phone, huh? I’ve got you covered. Depending on how you signed up—whether directly through Peacock or via a third-party service like Apple or Google Play—the steps are a tad different. Let’s dive in!
First up, if you signed up straight through the Peacock app, here’s the deal:
  1. Launch the Peacock App: Open up the app on your phone.
  2. Hit Your Account Icon: Look up in the corner—yep, that’s where your account icon hangs out.
  3. Head to Plans & Payments: You’ll spot an option called “Plans & Payments”—give it a tap.
  4. Say Goodbye to Your Plan: Look for “Cancel Plan” and tap it.
  5. Seal the Deal: Just follow through with any extra steps they throw your way to confirm you’re done.
Now, if you hopped on the Peacock train through iTunes on your iPhone, here’s what you need to do:
  1. Open Settings: Pull up the Settings app.
  2. Tap Your Name at the Top: This gets you into your Apple ID stuff.
  3. Find Subscriptions: Tap “Subscriptions” to see what’s on your list.
  4. Locate Peacock: Hunt down “Peacock” in there.
  5. Cancel Your Subscription: Hit “Cancel Subscription” and confirm it.
For those of you on Android who subscribed using Google Play, here’s the scoop:
  1. Fire Up the Google Play Store: Open the app on your phone.
  2. Tap Your Account Icon: It’s hanging out in the top corner.
  3. Navigate to Payments & Subscriptions: Look for “Payments & Subscriptions.”
  4. Check Out Subscriptions: Hit “Subscriptions” and check what’s listed.
  5. Spot Peacock: Find “Peacock” in there.
  6. Cancel It: Give “Cancel Subscription” a tap and follow any prompts.
A couple of things to keep in mind… Even after you pull the plug, you can still watch premium stuff till the billing cycle wraps. Then, it’s back to the freebie version for you. Oh, and if you bail before your billing period’s up, don’t hold your breath for a refund unless it’s required by law. Also, if you find yourself stuck or things are going south, reach out to customer support—especially if you hooked up with Peacock through a third party.
So, whether you’re on iPhone or Android, or signed up directly or via a third party, you’re all set to kick your Peacock subscription to the curb. Got any questions? Drop them below!
Sure thing! If you\’re looking to pull the plug on your Peacock subscription from your phone, let’s dive into the nitty-gritty of how to do it without hitting any snags.
Option One: Ditching Peacock via iOS
Okay, so for all the Apple folks out there, if you signed up through the App Store, here\’s what you need to do:
  1. Pop into your Settings, tap on your name at the top.
  2. Head over to Subscriptions and find Peacock.
  3. Hit Cancel Subscription and confirm. You\’ll still have access till your billing cycle wraps up.
Sometimes, you might run into a hiccup: if you don\’t see Peacock, it\’s probably stashed away somewhere else, like through Xfinity or Roku. Make sure you\’re checking the right Apple ID too.
Option Two: Bidding Adieu to Peacock on Android
Now, if you\’re rocking an Android device and signed up via Google Play, here\’s the lowdown:
  1. Fire up the Google Play Store app, then click your profile icon.
  2. Go to Payments & Subscriptions > Subscriptions and hunt down Peacock.
  3. Select Cancel Subscription and follow the clues.
FYI, partial billing refunds aren’t usually part of the package. If Peacock isn’t showing up, you might need to see if it\’s bundled with something else, like through Verizon.
Option Three: Cutting Ties Through Peacock\’s Website
If your subscription is somewhere else, like directly through the Peacock site, just do this:
  1. Open up Peacock’s website on your phone’s browser.
  2. Log in, head to Subscription, and hit Cancel Plan.
  3. Follow the steps on-screen. Pro tip: taking a screenshot of the confirmation can be your safety net.
If your plan is billed through Peacock or something like Xfinity, this is the way to go.
What\’s Next: Tackling Cancellations Gone Wrong
We all know things don\’t always go smoothly. Here are some curveballs and how to dodge them:
Uh-oh, Subscription’s Still Alive?
  • What’s going down: Your billing cycle is still covering you.
  • Fix it: Give it 24–48 hours to sort itself out. If you’re seeing charges again, putting Peacock Support on speed dial isn\’t too crazy.
Missing Cancel Button?
  • What\’s up: Another platform’s got their mitts on it, like Roku or Amazon Prime.
  • Your move: Head over to their account settings or ping their support.
Oops, Accidentally Re-upped?
  • Heads-up: Turn off Auto-Renew as soon as you’re out.
Tidbits You Might Like
  • Free Trials: The clock’s ticking—cancel at least a day before the trial ends to dodge charges.
  • Refunds: Don’t bank on mid-cycle refunds. If you think there’s a shot, definitely reach out to support.
  • After You Cancel: You’ll still get Peacock till your current paid period bites the dust.
Running into a wall? These guys can help:
  • Peacock Support: Your go-to for sticky situations.
  • Apple/Google Support: If they’re the ones handling your bills.
All set? Just make sure you\’re dialed into the right billing source before pulling the trigger on your cancellation. Happy browsing!
Hey there, looking to cancel your Peacock subscription on your phone? No sweat; here’s the lowdown to get you sorted quickly.
If you’ve got an iPhone, it’s all about working with Apple ID settings. First off, open up your Settings app. See your name at the top? Give it a tap to dive into your Apple ID. Find ‘Subscriptions’ – it’s like uncovering your digital treasure chest of subscriptions. Tap ‘Peacock’ and then ‘Cancel Subscription.’ That’s the ticket!
Android users, you’ve got it just as easy. Fire up the Google Play Store and tap those three little lines on the top-left to open the menu. In there, you’ve got ‘Subscriptions.’ Find your Peacock subscription and hit ‘Cancel.’ Done and dusted!
Now, if you’re using a mobile browser, it’s a slightly different game. Pull up your browser, head to the Peacock TV website, and log in. Navigate to ‘Account’ and then head over to ‘Plans & Payment’ to turn off your subscription. It’s like flipping a digital switch.
You’ll be free and clear in no time with these steps. If you hit a snag, Peacock’s support page has got your back.
