How Can I Connect My PS5 Controller to My Phone via Bluetooth?
334 viewsGame Console
So, you want to hook up your PS5 controller to your phone via Bluetooth? No problem! Here’s how you do it just like you’d explain it to a friend:
Alright, first things first, make sure your phone can buddy up with a PS5 DualSense controller. Most newer phones should be good to go, so as long as you have Android 12 or later, or an iPhone running the latest iOS, you’re golden. Also, give your gadgets a charge if they’re running low. Nothing’s worse than something dying midway, right?
Okay, next up—let’s flick on your phone’s Bluetooth. If you’re rocking an Android, just do a swipe down from the top to hit up the Quick Settings and tap that Bluetooth icon. Alternatively, you can dive into Settings > Connected devices > Connection preferences > Bluetooth to flip the switch. On an iPhone? Easy peasy, just go to Settings, tap on Bluetooth, and turn it on.
Now, to get your controller in the mood to pair, press and hold the PS button (the logo thingy) and the Create button (those three lines). Hold ’em together until you see the light bar doing a little blinky dance—means you’re ready to roll!
  • For Android folks, once you’re in the Bluetooth settings, you should see “DualSense Wireless Controller” popping up on the list of available devices. Tap it and once the light on your controller goes steady, you’re all set.
  • iPhone users, do the same—find it under “Other Devices” and give it a tap. When that light goes steady, you know it’s a done deal.
To check if everything’s cool, fire up a game or app that supports controllers and give it a spin. If something’s off, maybe your controller still sees someone else—like an old device. Disconnect that first, you know?
If you hit a snag where your controller isn’t showing up, make sure it’s still in pairing mode. Pro tip: sometimes a quick restart on both your controller and phone works wonders. Plus, keep things close—about 30 feet max.
So, there you have it! With these steps, your PS5 controller should be playing nice with your phone, letting you enjoy a seamless gaming session on the go. Happy gaming!
Connecting your PS5 DualSense controller to your phone via Bluetooth can really amp up your mobile gaming, especially if you’re into remote play or cloud gaming. It’s not too complicated, but there are a few things you need to check out first, like whether your phone’s system is compatible, and then follow some pairing steps. Here’s a rundown that’s easy to follow:
Before you dive in, make sure your device is up to the challenge. Got an Android? It needs to run Android 12 or later to officially support DualSense, but testing shows you might get some functions on Android 11. For folks on iOS, you’re looking at needing iOS/iPadOS 14.5 or newer. Double-check this by heading into your phone’s settings—super easy, just find where it says About Phone or About under General.
Certain Android gadgets might not play ball because of missing bits and pieces under the hood. If things seem hinky, check with your phone maker for more info.
Alright, let’s get to pairing this thing:
Popping this on Android
Give your controller a little prep before the main event. First, shut it off. When it’s time, press and hold the PS button and the Create button (the one on the back-left) until the light starts flashing like crazy.
Head to your phone and make sure Bluetooth’s rocking and rolling—just flick the switch on in Settings > Bluetooth.
When your phone discovers the controller, see where it lists devices and tap on DualSense Wireless Controller to make them buddies.
Doing the same on iPhone/iPad
Activation mode is the same deal—PS button plus Create button. Then, dip into the Bluetooth settings. Keep Bluetooth switched on, and when your phone spots the controller, tap its name where it shows up under Other Devices.
Now onto some hiccups you might hit and how to jump over them:
When your controller isn’t showing up, it could be that Bluetooth’s off or the system’s out of date. Make sure Bluetooth is switched on properly and give the visible device list a swift refresh. Update your OS if it’s behind the times. All else failing, reset the controller by finding the little pinhole on the back and pressing the reset button for about five seconds.
Got a shaky connection? Might be because you wandered too far off with your controller—keep it within about 3 to 5 meters. Other gadgets could be causing interference, too. Try unplugging or switching off nearby Bluetooth gear like speakers or headphones.
Sometimes the controller doesn’t play nice with games due to app optimizations. You might not get all the haptic feedback goodies in non-compatible apps. For smoother sailing, try using the PS Remote Play app or look into games that are more DualSense-friendly.
A couple of handy tips: keep an eye on the controller’s battery—running on empty can mess with connections. Give it a charge before trying again. If nothing works, forget about the controller in Bluetooth settings and start fresh. Sorting through all the compatibility checks and pairing steps will get your DualSense controller synced for some solid mobile gaming action. If it still doesn’t want to play nice, reaching out to Sony support or your phone manufacturer might be the next step.
Want to hook up your PS5 controller to your phone using Bluetooth? It’s pretty easy and here’s how you can do it:
If you’re on Android:
  • First off, flip on Bluetooth in your phone’s settings.
  • To get your controller ready, hold down the ‘PS’ and ‘Create’ buttons until the light starts going wild.
  • Your phone should be searching for devices. Keep an eye out for ‘Wireless Controller’ popping up on the list.
  • Tap on ‘Wireless Controller’ and you’re good to go. If a code baffles you, just type ‘0000’. When the light sticks, you’re connected!
On an iPhone:
  • Open up settings, hit ‘Bluetooth’, and make sure it’s turned on.
  • Time to put the controller in pairing mode—hold the ‘PS’ and ‘Create’ buttons until that light flashes fast.
  • Let your iPhone do its thing. Once you see ‘DualSense Wireless Controller’, you’ve found your match.
  • Connect by selecting the controller. If the light chills out and stays lit, you’re all set.
Ran into a snag? Here’s a few fixes:
  • Double-check that Bluetooth isn’t busy with another device.
  • It helps to have a fully charged controller—low battery might mess with your connection.
  • When things get really stubborn, a quick restart of both phone and controller could do the trick.
So, there you have it! With these steps, you’re all set to blast through some games on your phone. Enjoy!
