How Can I Block Background Apps on Android to Boost Performance?
320 viewsPhone
On Android devices, apps often run behind the scenes, which can suck up battery power, data, and system resources. This can lead to your battery draining faster, increased data usage, slower device performance, and even potential privacy issues. Blocking background apps can keep your device running smoother and give you a better user experience. Here are some ways you can block background apps on your Android device:
Using Built-in Settings
  • Restrict Background Activity via Battery Settings: Unlock your Android and go to the “Settings” app. Look for “Battery” (it might be listed under “Device Care” or “Battery & performance”). Tap “Battery usage” to see which apps are eating up your battery in the background. Pick the app you want to restrict, tap “Battery,” then “Background restriction,” and confirm.
  • Force Stop Apps: Open “Settings,” head to “Apps,” find the app you want to stop, and tap “Force stop.” Confirm, and the app should stop running in the background. But note, this fix is temporary—once you restart the device, some apps will start up again.
  • Enable Adaptive Battery: In “Settings,” go to “Battery,” then tap “Background usage limits.” Hit the three-dot menu in the top-right and pick “Adaptive Battery.” Switch on the toggle. This feature learns your usage patterns and limits background activity for rarely-used apps.
  • Use Battery Optimization Features: Go to “Settings,” then “Battery,” and tap “Battery optimization” or “Optimize battery usage.” Choose “All apps” from the dropdown, pick the app you want to optimize, and tap “Optimize.” The system handles the rest.
Managing Background Processes via Developer Options
  • Enable Developer Options: Go to “Settings,” scroll to “About phone,” and tap the “Build number” seven times until it says Developer Options are enabled.
  • Set Background Process Limit: Go back to the main “Settings,” tap “System” (or directly “Developer options” on some devices), and then tap “Developer options.” Scroll to “Apps” and find “Background process limit.” Choose how many background processes you want, like “At most 4 processes.”
Disabling Auto-Start Permissions
  • Disable Auto-Start via App Management: In “Settings,” look for “Apps” or “App management.” Select the app, tap “Permissions” or “Auto-start,” and turn off the auto-start option.
  • Adjust Auto-Start Settings via Security Apps: Some devices, like Xiaomi, have security apps that manage permissions. Open the security app, find “Permission Management” or “Auto-start Management,” and disable the auto-start permission for the apps you want to restrict.
Restricting Background Data Usage
  • Restrict Background Data for Specific Apps: On Samsung devices, go to “Settings” > “Connections” > “Data usage.” Tap “Mobile data usage,” pick an app, and turn off “Allow background data usage.” For Google Pixel, go to “Settings” > “Network & internet” > “Data Saver,” and enable Data Saver.
  • Enable Data Saver Mode: Open “Settings,” go to “Network & internet,” and enable “Data Saver.” This will limit background data usage.
Using Third-Party Apps
You can find various third-party apps on the Google Play Store to manage background apps, like Greenify, Advanced Task Manager, and KillApps. These apps offer features that can hibernate or force-stop background apps. But note, some available third-party apps may not be maintained actively, so using built-in options is often more reliable.
Manually Closing Background Apps
Tap the “Recent apps” button (square icon or swipe up if using gesture navigation). Swipe left or right to close apps you don’t need. Or swipe up from the bottom, hold, and release. Then, swipe from left to right and tap “Clear all” to close all background apps.
Managing Background Apps on Specific Brands
  • Samsung: Go to “Settings” > “Battery & device care” > “Background usage limits.” You can set apps to “Never sleeping” to allow minimal background restrictions or restrict background usage.
  • Xiaomi: Long-press an app icon, select “App management,” tap “Background settings” in the “Battery” section, and choose “Restrict background activities.” Or open the app, go to the app switcher, long-press the app preview, and tap the “Lock” icon to keep it active in the background.
Other Methods
  • Use Task Manager: Swipe up to access the task manager, showing recent apps. Swipe an app left or right to close it.
  • Uninstall Unnecessary Apps: Uninstall apps you don’t use to stop them from running in the background.
Notes
  • Blocking background apps may affect their functionality. Apps restricted from background activity might not get real-time notifications or sync data properly. Avoid this for critical apps like messaging or calendar apps.
  • Some system apps or essential apps (e.g., Google Play services) can’t be forced-stopped or restricted.
  • Android devices will automatically manage resources, closing some background apps based on device status and resource availability.
There you go—a rundown of how to manage background apps on Android to keep your device running efficiently.
Alright, so you want to block those pesky background apps on your Android, huh? No worries, I’ve got your back! Here’s how you can handle it without a fuss.
First off, dive into your phone’s settings. Most Android phones have options that let you keep background apps in check. It’s super simple: just unlock your phone, pop open the Settings app, and scroll down to find the Battery settings. It might be hiding under ‘Device Care’ or ‘Battery & Performance,’ but you’ll find it. Check out ‘Battery usage’ to see which apps are gobbling up your battery juice while you’re not looking. Tap on an app and look for something like ‘Background restriction’—kick those background activities to the curb!
Now here’s a nifty trick—Developer Options! It’s this hidden section that lets you dig into more advanced settings. First, enable this mode by tapping seven times on the Build number in your ‘About phone’ settings. Head back to the main menu and you’ll see Developer Options pop up. In there, find ‘Background process limit’ and set the number of processes you want. This lets you really get into the nitty-gritty without needing a degree in computer science.
Moving on, you know how apps just seem to sprout up on their own? Well, that’s the auto-start setting many apps come loaded with. Go back into Settings and look for ‘Apps’ or ‘App management.’ Pick an app and hunt for the Auto-start option—it might be hiding under Permissions. Give it a little tap to turn off the auto-start, and you’re golden.
Your phone’s got some great built-in battery optimization features too. No need to download anything fancy. Open the Battery settings again, find ‘Battery optimization’, and select ‘All apps.’ Choose the app that’s been bugging you and optimize it to save precious energy.
Now, if you’re more the hands-on type, you can simply close apps manually. Just pop open the Recent apps menu by pressing the square icon or swiping up from the bottom if you’re all about gestures. Swipe away any apps you don’t need open anymore—easy peasy!
Lastly, if the built-in tools just aren’t cutting it, there are third-party apps out there that can help you out. I’m talking Greenify, Advanced Task Manager, KillApps—you’ve got options galore to keep your background tasks under control.
So there you have it! With these tricks, you’ll be able to block unwanted background apps on your Android and keep everything running smooth and efficient. Happy tweaking!
How to Block Background Apps in Android: Here\’s the Scoop
So, you’ve noticed your phone battery draining faster than a melting ice cream cone on a hot day? It could be those sneaky background apps eating up all your resources. Time to take action and regain control over your Android. Let\’s dive into why these apps are up to no good and how you can give \’em the boot.
Why Do Background Apps Even Exist?
  1. Here\’s the thing about apps:
    • They\’re always doing something, like syncing your playlists or checking if you\’re connected to Wi-Fi.
    • Some apps have an eagle eye for system events, and they spring into action faster than you can say “notification.”
    • They\’ve got alarms and reminders like it\’s their business, so they keep tabs on updates and more.
    • Honestly, some apps are designed without much thought to conserve resources. Go figure.
How Do You Put These Apps to Rest?
First up: Using the Built-In Settings
Android has got your back with some handy tools:
  • To get started:
    1. Jump into Settings > Apps > [Pick Your App] > Battery.
    2. Turn on Restrict background activity or Optimize battery usage.
    3. If you’ve got Android 9+, dial it up with Background restriction.
  • Heads up: Don’t expect miracles for system apps or those doing crucial stuff.
Then: Cut Off Background Data
Time to stop apps from becoming Wi-Fi vampires:
  • What to do:
    1. Pop into Settings > Network & Internet > Data Usage.
    2. Switch it off for the app under Background data.
And: Optimize Battery Usage
Force apps to play nice with Doze mode:
  • Here’s your game plan:
    1. Slide into Settings > Battery > Battery Optimization.
    2. Choose the app and hit Optimize.
Or: Force-Stop \’Em
If they won’t quit, make them:
  • Take these steps:
    1. Swing by Settings > Apps > [Choose App].
    2. Give that Force Stop button a tap.
  • Note: These apps might revive like a zombie if triggered by system events.
Want More Control? Check Out Developer Options
Limit the backstage antics:
  • Here’s how:
    1. Activate Developer Options (tap Build Number seven times in About Phone).
    2. Wander into Developer Options > Background Process Limit and set it up (think \”At most 4 processes\”).
Feeling Adventurous? ADB Commands Are for You
For those apps that just won’t quit:
  • Try this:
    1. Connect to your PC and turn on USB Debugging.
    2. The magic command is:
      adb shell pm disable-user --user 0 <package-name>
      Swap <package-name> for the app\’s identity (like com.facebook.katana).
  • Just remember: misuse can break stuff.
Extras: Third-Party Apps
Use tools like Greenify to hibernate those resources:
  • They work by tapping into accessibility services or needing root to chill frozen processes.
  • Remember: They might not always play nice with system settings.
Real Power? Root Access Is at Your Fingertips
Root users can:
  • Bring in Titanium Backup to freeze out unwanted apps.
  • Dive into system files to shut down services.
Keep This in Mind!
  1. Trade-offs:
    • Don\’t kill crucial apps—delayed messages are a drag!
    • If you’re too aggressive, you might face error messages or apps ignoring commands.
  2. Watch out for Version Tweaks:
    • Android 12+ gets strict on background activity.
    • Some versions come with ambient modes for extra savings.
Nitty-Gritty Recap
Honestly, managing background apps is all about finding that sweet spot between keeping your phone fast and all apps functioning as they should. Try the settings before going all-out with ADB or root commands. You’ll want to keep tabs on app permissions and background actions to do your phone a favor and keep it running smoothly.
All right, if you want to kick those pesky background apps off your Android and get it running smoothly, here’s the deal.
First up, the age-old trick of diving into your device settings can work wonders. Just pop open your Settings app—easy peasy. Head to Apps & Notifications, and pick the app that’s guzzling your battery. Give it a good old Force Stop slap if you just want a time-out. But, if you’re looking for a permanent fix, hop over to Battery and lay down the Background restriction or Restrict app activity.
Next, we’re talking about Developer Options. Get ready to show your Android who’s boss! Slide into Settings again and scroll down to About Phone. Tap that Build Number seven times (yep, it’s like a secret handshake) to unlock Developer Options. Once you’re in, swing into System, then Developer Options, and take control by limiting background processes. Say goodbye to needless app chaos!
Now, here’s a tip worth its weight in gold: grab yourself a third-party app. Greenify’s a top pick—download it from the Play Store and follow its setup. Choose the apps you want to hibernate and let Greenify do its magic, keeping things tidy and efficient.
Last but not least, let’s talk Battery Optimization. Sneak back into Settings, tap Battery, and find Battery optimization. Once there, restrict background activity for apps that keep chomping on your resources. It’s a simple tweak that can really boost performance.
There you have it! Kick those background apps to the curb with these smart moves. Honestly, you’ll be surprised how much smoother your Android can run.
