How Can I Add an Anniversary to My iPhone Calendar?
564 viewsPhone
Open the Calendar App:‌ Find and launch the Calendar app on your iPhone.
Start a New Event:‌ Tap the ‌+‌ (plus) icon in the top-right corner.
Set the Date & Enable Yearly Repeat:‌Enter a title for your anniversary event (e.g., “Wedding Anniversary”).Tap the ‌Start‌ date/time field.Select the specific date of the anniversary using the date picker.Crucial: Scroll down and tap ‌Repeat‌.Choose ‌Every Year‌ from the repeat options.
Save the Event:‌ Tap ‌Add‌ in the top-right corner to save your recurring anniversary event.
Trying to add an anniversary to your iPhone calendar but feeling a bit stumped? No worries, I’ve got you covered! Here’s a simple and straightforward way to make sure you never miss those special dates again:
First thing you want to do is open your Calendar app, which should be hanging around on your home screen. You know the drill—just find the little calendar icon and tap on it.
Okay, now here’s the kicker: tap that big ‘+’ sign in the corner. It’s like your gateway to setting up all sorts of stuff, including anniversaries!
Here’s where you jot down everything you need:
  • Title: Pop in something like “Anniversary Bash” or “Steve and Linda’s Special Day.” Doesn’t have to be fancy, just something that’ll jog your memory.
  • Date and Time: Pick the right day. If it’s an all-day celebration, flip the switch to “All-day” so it’s marked properly.
You don’t want to set this up every single year, right? Here’s what you do:
  • Find the ‘Repeat’ option when you’re setting it up.
  • Tap it and choose ‘Every Year.’ This way, it’ll pop up annually—easy peasy.
All good? Hit ‘Add’ or ‘Save.’ It’s in the top right corner, just waiting for you to seal the deal.
Sure, you’re probably used to adding birthdays straight from your contacts—but anniversaries? They need to be popped into the calendar manually since Apple hasn’t given us a shortcut for that, yet.
Want a heads-up before the big day? Set an alert when you’re filling out the event details. It’ll save you from scrambling last-minute!
And there you have it! You’ve got anniversaries in your calendar, ready to remind you year after year. Pretty easy, right?
How to Add an Anniversary to Your iPhone Calendar: Step by Step Guide
Missing an anniversary might be the last thing you want to do. Here’s a neat walk-through to keep those important dates saved in your iPhone calendar without a hitch.
Doing it the Old-School Way: Manual Entry
If you’re someone who likes having the reins, here’s the lowdown:
  1. Get into Your Calendar App
    • Hit the Calendar app—good thing it’s already there!
  2. Create the Event
    • Smash that + button in the corner.
    • Choose Add Event.
  3. Fill in the Deets
    • Title: Name your event, like “Wedding Anniversary” or whatever strikes your fancy.
    • Location (optional): Add a place that means something to you.
    • For the date, set the start time to 12:00 AM and tick All-Day to keep specifics out.
  4. Recurrence is Key
    • Tap Repeat and select Every Year.
  5. Add Some Reminders
    • Pick your alert times. Maybe “1 Day Before” fits the bill?
    • Throw in another alert if you’re feeling cautious.
  6. Lock It In
    • Hit Add to save.
Let Siri Do the Heavy Lifting
For a quick setup, just have a chat with Siri:
  • Fire up Siri the usual way or just say “Hey Siri.”
  • Tell it: “Add [Event Name] to my calendar on [date] every year.”
    Example: “Add Mom’s Anniversary to my calendar on June 15 every year.”
  • Siri’s got that—just confirm and you’re done.
Hooking Up Contacts
If it’s already in your contacts, here’s how you fine-tune it:
  1. From Inside Contacts
    • Open Contacts, pick your person, click Edit, and add a date like “Anniversary.”
    • Make sure to toggle “Show on Calendar.” Boom, it’s there.
  2. From an Email or Text
    • Tap on an event link you got and choose Add to Calendar.
Hit Some Snags? No Worries
No Annual Repeat?
  • Why It Happened: Missed setting “Repeat” to yearly.
  • Fix It: Dive back into the event, hit “Repeat” and set to “Every Year,” then save.
Events Not Showing Everywhere?
  • The Culprit: iCloud syncing might be off.
  • Get it Together:
    • Head into Settings > [Your Name] > iCloud and make sure Calendars is on.
    • Check that the event is under an iCloud-synced calendar when in the Calendar app.
No Alerts Going Off?
  • Possible Reasons: Alert settings might be wonky or “Do Not Disturb” could be your enemy.
  • What to Do:
    • Edit your event to make sure alerts are set right.
    • Peek into Settings > Notifications > Calendar and keep “Allow Notifications” on.
Tips to Go the Extra Mile
  1. Make it Look Pretty
    • Color-code those anniversaries so they don’t sneak past:
      • Tap Calendars, pick one, tap , and choose a color.
  2. Get Others Involved
    • Edit the event, tap Invitees, and send invites to fam or friends.
  3. Back it Up
    • Go into Settings > [Your Name] > iCloud > iCloud Backup > Back Up Now.
Why Trust iPhone Calendar with Anniversaries?
  • All in the Family: Syncs with Apple stuff like your Watch, iPad, and even the Mac.
  • Pretty Flexible: Think recurring events, alerts galore, and location-based nudges.
  • Guardians of Your Data: Keeps it all safe and sound with encryption if you’re on iCloud.
So there you go! With these tidbits in your pocket, you’ll have those special dates on lock. And hey, make sure your iOS is spiffed up (catch that via Settings > General > Software Update).
Looking to sneak in those important anniversaries on your iPhone calendar? Here’s how you can do it:
First Way: Using the Calendar App
  • Start by opening up your Calendar app.
  • You’ll want to hit the little “+” icon at the top.
  • Now, fill in all the fun details!
    • Get the name of the anniversary in there (like “Wedding Anniversary”).
    • Make sure the date is spot on.
  • Here’s a trick: head to the “Repeat” section and choose “Yearly” so you never forget.
  • Finally, hit “Add” and you’re all set!
Second Option: Using the Contacts App
  • Pop open your Contacts app.
  • Find the person tied to the anniversary and go into edit mode by tapping “Edit.”
  • Add a date by scrolling and tapping “Add Date.”
    • Choose the right date type. If “Anniversary” isn’t an option, just pick “Other” and label it yourself – something like “Anniversary” works.
  • Remember to hit “Done” to lock in the changes.
By following these steps, your important dates will pop up each year, so you’ll always be on top of your game when it comes to remembering those special moments.
