How to Add Albums to A Folder on Iphone?
461 viewsPhone
Feel like your iPhone photo library is a chaotic mess? Don’t worry, you’re not alone. The good news is that there’s a handy way to wrangle your pics and vids into shape using albums and folders within the Photos app. Trust me, it’s easier than it sounds.
Let’s kick things off by clearing up the basics. In the Photos app, albums are like playlists for your photos and videos, and folders are essentially containers that hold multiple albums. This set-up helps keep everything nice and tidy.
Alright, let’s first create a folder:
  1. Open the Photos app—not rocket science, right?
  2. Tap the “Albums” tab sitting at the bottom.
  3. Hit that “+” button at the top left and choose “New Folder.”
  4. Give your folder a name that makes sense to you and tap “Save.” Not feeling it later? No problem, you can rename it anytime.
Now, adding albums to your folder is a no-brainer:
Adding a New Album to a Folder
  1. Open the Photos app and tap on “Albums.”
  2. Find the folder you want to add a new album to and open it.
  3. Tap “Edit” in the top right corner.
  4. Hit the “+” button up top.
  5. Select “New Album.”
  6. Name your album and tap “Save.”
  7. Throw in the photos you want in there and tap “Add.”
  8. Finished? Tap “Done” to lock it in.
Moving an Existing Album to a Folder
This part’s a bit tricky because there isn’t a direct way to move an album. Here’s the workaround:
  1. Open the Photos app and create a new album in the folder where you want the old one to go.
  2. Go to the existing album you want to move.
  3. Tap “Select” in the top right corner.
  4. Tap “Select All.”
  5. Hit the three dots at the bottom right.
  6. Choose “Add to Album” and pick the new album in your desired folder.
  7. After moving your photos, ditch the old album to avoid duplicates.
Extra Tips for Organizing Albums and Folders
  • Renaming Folders: Changing folder names is a breeze. Just tap and hold the folder, hit “Rename Folder,” and enter the new name. Done.
  • Reordering Albums: Want to reshuffle your albums? Go to the folder, tap “Edit,” then drag and drop the albums where you want them.
  • Syncing with iCloud: If you use iCloud Photos, your albums and folders will sync across all your devices. So your tidy organization isn’t just local.
With these tricks up your sleeve, your iPhone’s photo library will start looking way less like a junk drawer and way more like a personal gallery. Easy peasy!
To get those albums tucked away into a folder on your iPhone, just follow these simple steps in the Photos app. This will help you organize things and find what you’re looking for without a headache!
First things first, open up the Photos app. You should be greeted by the main screen, with tabs like “Photos,” “For You,” “Albums,” and “Search” at the bottom.
Now, hit that “Albums” tab. This is where you’ll see all your current racks of snaps lined up.
Don’t have a folder yet? No problem.
  • Tap the “+” in the top-left corner.
  • Choose “New Folder.”
  • Want to call it something catchy like “Holiday Snaps”? Knock yourself out! Then just tap “Save.”
Got your folder set up? Awesome. Now it’s time to shuffle some albums in there.
Find the album you’ve got your eye on — just tap to select it. Here’s where you gotta get creative because there’s no hotline straight to putting an album in a folder. But who needs shortcuts, anyway?
Why not create a fresh album inside your folder and move your photos there?
  • Open the folder where you want the new album.
  • Tap “Edit” over in the right corner.
  • Hit the “+” once more and go for “New Album.”
  • Give it a name that makes sense, like “Road Trip Photos.”
  • Select your original album (the one bursting with images) and tap “Select,” then “Select All.”
  • Once you’ve nabbed all the photos you want, tap “Add” or “Done” to get them in place.
Feeling brave? You could go back and give the original album the chop.
  • Return to the Albums view.
  • Locate your first album and tap it.
  • Tap those three dots (the options menu) and choose “Delete Album.” Don’t worry, you’ll be asked to confirm and won’t lose any sleep over it.
And there you have it! You’ve officially wrangled all those stray albums into one neat folder. Now, your photo collection is way easier to handle and won’t turn into a treasure hunt every time you need a pic. Happy organizing!
Getting Your iPhone Albums in Order: A Handy Guide
If you’ve ever found yourself scratching your head trying to wrangle your photo albums into folders on your iPhone, you’re not the only one. It feels like Apple dropped the ball on this one, but don’t worry, there are a few nifty tricks and tips that’ll help you squeeze a bit more organization out of your albums.
First Things First: A Little Background
  • Apple’s Stubborn Streak: The Photos app is great for whipping up albums, but folders? Nope, nada. Your documents can cozy up in folders in the Files app, but not your photos. Go figure.
  • The Dream Setup: You want an easy way to group related albums together, right? Like having “Vacation 2023” and “Family Events” under one roof for stress-free scrolling.
Ways Around Apple’s Folder Fiasco
1. Photos App Tricks: Album Groups on iOS 15+
Now, iOS 15 and later throw you a bone with “Album Categories”:
  1. Pop open Photos > Albums tab.
  2. Hit “See All” next to My Albums.
  3. Press and hold an album > “Add to New Album Group.”
  4. Give your group a snazzy name, like “Travel,” and hit save.
  5. Throw more albums in the mix by pressing and holding an album > “Add to Album Group” > Pick your group.
Watch Out:
  • These Album Groups hang out only in the Albums tab. You won’t find them lurking in your main library.
  • Works only with albums you made manually, not the ones Apple decided to auto-generate for you.
2. Files App: Your New Best Friend
Want real folders? You might have to shuffle albums over to the Files app:
  1. Ship Out Your Albums:
    • Open your album in Photos > Select everything > Tap share > Pick “Save to Files.”
    • Choose where they land (like iCloud Drive or On My iPhone).
  2. Folder Creation: Easy Peasy:
    • Head to the Files app > Go where you parked your albums.
    • Hit the three-dot menu > “New Folder” > Name it some cool, maybe “Photo Albums.”
  3. Move Albums into Folders:
    • Long-press the album file > “Move” > Pick your folder.
Quick Heads-Up: This method makes photo copies, spiking your storage usage a bit.
3. Apps to the Rescue
Some third-party heavyweights like Google Photos, Adobe Lightroom, or Evergreen are stepping up with folder-like options:
  • Google Photos Example:
    1. Snag Google Photos and crack it open.
    2. Tap Library > Albums > New, and create your album.
    3. Use the Folders feature or whip up nested albums.
Pros: Sweet cross-platform access.
Cons: Your photos take a little trip to third-party servers.
Why Aren’t Folders Part of the Photos App?
  • The Apple Approach: Simplified, AI-driven organizing is Apple’s jam; it keeps things neat without much effort.
  • Streamlined Organization: Apple figures most folks are happy to let technology take the wheel with automatic sorting.
Dealing with Glitches
  1. No “Add to Album Group”?
    • Make sure you’re on iOS 15 or newer. Take a peek at Settings > General > Software Update.
    • Album Groups only work with albums you’ve crafted yourself.
  2. Photos Playing Hard-to-Get with Files
    • Double-check your iCloud or local storage space.
    • Make sure iCloud Drive is turned on in Settings > [Your Name] > iCloud > iCloud Drive.
  3. Photo Overload
    • Think twice before using the Files app for anything but backups—not worth the mess for everyday albums.
Smart Tips
  • Regular Nudges: Trim down unnecessary albums and folders regularly.
  • Collaborate with Shared Albums: Got teamwork on your brain? Head to Photos app > Albums > + > New Shared Album.
  • Back Up Your Stuff: Use iCloud Photos for seamless syncing across devices.
Mixing Apple’s features with third-party apps and the Files app gets you close to folder-style organization on your iPhone. Tailor your approach based on what matters most to you—ease of access, storage space, or working together.
So, you want to corral your albums into a neat folder on your iPhone? Let’s dive into a few easy steps to make that happen. First off, you gotta pop open the Photos app—quick as a wink. Then, mosey on over to the ‘Albums’ tab at the bottom of your screen.
Now, here’s what you do next. Hit the ‘+’ icon up top and select ‘New Folder.’ Once you’ve slapped a name on that folder, give ‘Save’ a tap. Easy peasy, right?
The real meat of this is getting those albums into your new digs. Swing back to the ‘Albums’ tab, and if you can’t see all of them, tap ‘See All.’ Then hit ‘Edit’ in the top corner. From here, press and hold the album you’re eyeing to move. Once it’s doing a little dance, drag it over to the new folder like you’ve just won at bingo. Do the same for any other albums crowding your space. Wrap it up by tapping ‘Done.’
Take a second to double-check your handiwork. Go on, open the folder and make sure all the albums are snug inside. If things are looking off, maybe give your iPhone’s iOS a quick update.
This tweak has you organizing your photos with the ease of a pro. Now you’ve got a tidy collection at your fingertips!
