How Do You Stop Apps from Running in Background?
299 viewsPhone
Background apps can be a real drain on your PC’s performance. Even when you’re not actively using them, they’re there, consuming your RAM and CPU, slowing things down, killing your battery, and chomping through your data. If you’re on Windows 11 and want to shut these apps up, here’s how you can do it, step by step.
Understanding Background Apps
Background apps keep running even when you’re not actively using them. Maybe they’re minimized to the tray or just hiding out of sight, but they’re still pulling resources. Think email clients checking for messages, music players running tunes while you browse, or social media apps pinging you about new notifications. Handy? Sure. But if you’ve got too many of them going, they can bog down your system, shorten your battery life, and mess with your internet speed.
Why Stop Background Apps?
  • Boost Performance: Killing unnecessary background apps frees up your system resources, which means the stuff you’re actually using runs faster and smoother.
  • Save Battery Life: Background apps can be battery hogs, especially if they’re always syncing or doing stuff. Stop them, and your device lasts longer on a charge.
  • Cut Down on Data Usage: Some apps use data even when you’re not looking—downloading updates, syncing, streaming. Stopping them can save you data, which is great if you’re on a limited plan.
  • Security: Some background apps might have vulnerabilities that could be exploited. By turning off those you don’t need, you’re reducing the risk.
How to Stop Apps from Running in the Background
There are a few ways to do this on Windows 11:
Method 1: Using Task Manager
Task Manager is your go-to for checking what’s running and stopping what you don’t need.
  1. Open Task Manager: Hit Ctrl + Shift + Esc, or right-click the taskbar and choose “Task Manager”.
  2. Spot Background Apps: Go to the “Processes” tab to see everything running. Find the ones you don’t need.
  3. End Tasks: Right-click on an app and select “End task” to stop it.
Method 2: Through Settings App
Use the Settings app to manage app permissions and background activity.
  1. Open Settings: Click the Start menu and hit the gear-shaped Settings icon.
  2. Go to Apps: In the Settings app, head to the “Apps” section on the left sidebar.
  3. Select Installed Apps: Click “Installed apps” to see everything installed on your device.
  4. Find the App: Scroll or use the search bar to locate the app you want to manage.
  5. Access Advanced Options: Hit the three-dot menu next to the app name and choose “Advanced options”.
  6. Change Background Permissions: Under “Background apps permissions”, use the dropdown to select “Never”.
Method 3: Via Battery Settings
If battery life is your worry, you can manage which apps can run based on their power usage.
  1. Open Settings: Press Windows Logo + I.
  2. Go to Battery Settings: Navigate to “System > Power & battery”.
  3. Access Battery Usage: Scroll down to “Battery usage” and click to expand.
  4. Manage Background Activity: Find the battery-hogging apps. Click “More options” and pick “Manage background activity”.
  5. Disable Background Activity: From the dropdown under “Let this app run in the background”, select “Never”.
Method 4: Using Local Group Policy Editor
If you’ve got Windows 11 Pro, Education, or Enterprise, you can use the Local Group Policy Editor to stop all background apps.
  1. Open Run Dialog Box: Press Windows Logo + R to open Run.
  2. Launch Group Policy Editor: Type gpedit.msc and hit “OK”.
  3. Navigate to the Policy: Go to “Computer Configuration > Administrative Templates > Windows Components > App Privacy”.
  4. Modify the Policy: Double-click “Let Windows apps run in the background”. Choose “Enabled”, then use the dropdown to pick “Force Deny”. Click “Apply” and “OK”.
Method 5: Using Registry Editor
For Windows Home users, the Registry Editor can do the trick. Just be careful, as messing with the registry can mess up your system if you’re not sure what you’re doing. Always back up before you start.
  1. Open Registry Editor: Search for “Registry Editor” in the Start menu, and open it. Click “Yes” if prompted.
  2. Navigate to the Key: Copy/paste this path: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows
  3. Create a New Key: Right-click the “Windows” folder, and pick “New > Key”. Name it “AppPrivacy”.
  4. Create a DWORD Value: Right-click the right pane and select “New > DWORD (32-bit) value”. Name it “LetAppsRunInBackground”. Double-click it, set the value to 2, and click “OK”.
  5. Restart Your System: Restart to apply the changes. This stops all background activities.
Considerations and Precautions
Some things to keep in mind:
  • Essential Apps: Don’t disable apps you need, like system optimizers, antivirus software, and VPNs, as these need to run in the background to do their thing.
  • App Functionality: Some apps won’t work right without background activity, especially those that need real-time updates or notifications.
  • System Stability: Be cautious with tools like Registry Editor or Group Policy Editor. Missteps here can destabilize your system. Always back up before making changes.
  • App-Specific Settings: Some apps have their own settings to control background activity. Check within the app for these options, especially for third-party apps not managed by Windows Settings.
Wrapping Up
Keeping a handle on background apps on your Windows 11 device can seriously improve its performance. By using the methods above, you can easily shut down unnecessary apps, free up system resources, and speed things up. Just be mindful of what you disable so you don’t mess with your device’s functionality or security. Regular checks can keep your PC running smoothly.
So, you want to stop apps from running in the background on your Android phone, huh? No sweat! There are a few ways to clamp down on those pesky apps hogging your battery. Let’s dive into the nitty-gritty:
Your phone’s settings are your best friend for managing those background apps.
  • Peep into Settings: Things kick off with a quick unlock and a tap on that cog icon.
  • Find Battery Options: Track down the “Battery” section—it could be lurking under “Device Care” or “Battery & performance,” depending on your device.
  • Suss Out Battery Usage: Give “Battery usage” a tap to check out which apps are sucking up all the juice. This helps you spot the culprits running in the background.
  • Pick the App to Tame: Once you’ve got a suspect, tap on it.
  • Clamp Down on Background Activity: Look for “Background restriction” or “Allow background usage” under “Battery” and make sure to restrict that app’s sneaky antics.
If you’re feeling adventurous, Developer Options let you mess with more advanced settings.
  • Fire Up Developer Options:
    • Make your way to Settings > About phone.
    • Tap “Build number” seven times. Yep, seven. You’ll see a message telling you Developer Options are ready to roll.
  • Jump into Developer Options:
    • Back up to the main Settings and head to “System.”
    • Tap “Developer options.”
  • Trim Down Background Processes:
    • Find “Background process limit” and decide how many you want ticking away. For example, no more than 4, maybe?
Sometimes it just feels right to handle things personally by closing apps yourself.
  • Check Out Recent Apps: Hit the Recent Apps button (often a square or swipe up if using gestures).
  • Give Unwanted Apps the Heave-Ho: Swipe left or right to boot apps you don’t need.
Plenty of apps love to fire up automatically and cause trouble before you know it.
  • Head Back to Settings: Dive back into Settings.
  • Wrangle Your Apps: Scroll down to “Apps” or “App management.”
  • Locate the Offender: Pick the app you want.
  • Turn Off Auto-start: Find “Permissions” or “Auto-start” and flip it off for the app.
Your Android’s got some neat battery optimization tricks to keep things running smoothly.
  • Pop Open Battery Settings: Tap into Settings once again.
  • Snag Battery Optimization: Look for “Battery optimization” or “Optimize battery usage.”
  • Opt for All Apps: Use the dropdown to pick “All apps.”
  • Optimize Your Pick: Track down your app, tap it, and select “Optimize.”
Okay, so after jumping through these hoops, you’ll be well on your way to saving battery life and keeping your device running smooth. Keep tabs on which apps are being cheeky, and your phone will thank you!
Okay, folks, let’s tackle that pesky issue of apps gobbling up your battery by running in the background. You know those little digital vampires that drain your devices and leave you wondering why your phone’s at 5% before noon? Let’s dive right into it—with a twist of human flair.
What’s the Deal with Background Apps?
First off: what do these apps think they’re up to, hanging around in the background? Here’s the scoop:
  • Apps sometimes get permission to send notifications or update content, even when you’re not using them. That’s a cheeky little move on their part.
  • Those timely alerts from messaging apps like WhatsApp and Slack? They keep those apps wide awake and eager to ping you with every message.
  • Ever notice your music or fitness apps continuing their magic behind the curtain? They’re real clingy about keeping up the tunes or tracking your steps.
  • And let’s not forget about some apps with coding hiccups—running rampant without good reason.
  • Some apps pull sneaky tricks and jump back into action right after your device fires up.
What to Do on Android
Alright, Android users, here’s your toolkit:
  • Restricting background activity can really save your device’s bacon. Head into your settings and cut those apps off when they’re idle. You’ll be keeping your battery and data usage in check, hallelujah!
  • Check out the auto-start permissions that some apps love abusing. Dig into your settings and yank the welcome mat away from troublemakers.
  • Why not let your phone do some of the heavy lifting? Battery optimization features help weed out background activity without nipping your main app functions.
  • Feeling adventurous? Diving into developer options lets you set background process limits—just tread carefully, as you wouldn’t want to upset your phone’s core workings.
  • If you’re still facing problems, third-party tools like Greenify might be your knight in shining armor, if you don’t mind a bit of tinkering.
Now, iOS Fans, Here’s the Lowdown
If you’re swiping around on an iPhone, here’s what you got:
  • Give that “Background App Refresh” a rest. Those apps don’t need the luxury of constant updates—toggle them off as much as you fancy.
  • There’s always the classic move: force-closing apps just to show them who’s boss. Swipe them away and they’ll know not to linger.
  • Mess around with the location services settings. Some apps just can’t resist following your every move, but you’ve got the power to stop them.
  • Getting bombarded with notifications can keep apps running longer; cut down those alerts to reclaim some battery life.
Here Comes the Catch-All Tips
It doesn’t matter whether you’re Team Android or an Apple enthusiast; these pointers work universally:
  • Keep an eye out for updates; some apps are silently crying for fixes and updates help curb weird background activity.
  • Spot apps that you never touch and delete those hangers-on. Your storage and sanity will thank you.
  • Use your battery usage data to sniff out the culprits and shut them down or uninstall them, depending on how brutal they’re being.
  • If all else fails, a factory reset—dramatic, but effective—might cleanse your device of any lurking gremlins.
Getting Personal
Look, some apps are just sneaky—take social media, for instance. Opt for ‘Lite’ versions or just use the good ol’ browser instead. For email, switching to manual sync can give you a breather and for streaming, make sure to truly quit those apps when you’re done.
Wrapping It Up
What really matters? You need a bit of persistence and the willingness to test different methods until your device calms down. While it’s tempting to go all out on restrictions, chances are you’ll want a balance that doesn’t compromise your smartphone experience. Just keep tweaking, and enjoy a more reliable and long-lasting battery life. Cheers to reclaiming power!
Want to know how to stop those pesky apps from hogging all your device’s memory and battery in the background? You’re in luck—here’s how to do it on Android, iPhone, and Windows.
Android Adventures: Your trusty Android device needs some TLC, so let’s start there. You’ll want to dive into the ‘Settings’—yeah, the gear icon. Look for ‘Apps’ or some variation like ‘App Management.’ Find the app that’s guilty of freeloading, tap on it, and hit ‘Force Stop.’ Done and dusted! Also, to really cut the cord on its data usage, head over to ‘Data Usage,’ pick that same app, and flip the switch on ‘Background Data.’ Voila!
iPhone Insights: So you’ve got an iPhone? Here’s the deal. Pop open ‘Settings’—easy peasy. Slide over to ‘General,’ then ‘Background App Refresh.’ You can shut off the whole shebang or pick a few apps to silence. It’s as simple as flicking a light switch.
Windows Wisdom: Now onto Windows… Click on ‘Start’—yeah, that trusty button down there—and find your way to ‘Settings.’ Make a beeline for ‘Privacy,’ then hunt down ‘Background Apps’ on the panel. You can either stop all apps cold from running in the background or decide which ones stay put. Your choice!
And there you have it, a real-world, no-nonsense way to keep your device humming without unwanted app interference.
Here are some spots you might reference for extra help:
  • Google Support: support.google.com
  • Apple Support: support.apple.com
  • Microsoft Support: support.microsoft.com
