How Do I Turn Off Siri on My AirPods?
357 viewsHeadphones
To turn off Siri on your AirPods, just tweak a few settings on your iPhone or iPad. Here’s how to get it done:
First up, make sure your AirPods are connected to your iPhone or iPad. You’ll see the AirPods icon in the Bluetooth settings if they’re good to go.
Next step: dive into your Settings app. Easy to find on your home screen.
Head over to the Bluetooth section in Settings. Spot your AirPods in the device list and hit the little info button right next to them.
Now, go to the section for adjusting what happens when you press or double-tap your AirPods. Depending on your model, you might see something like ‘Press and Hold AirPods’ or ‘Double-Tap on AirPod.’
If one of these actions is set to fire up Siri, switch it to something else like ‘Noise Control’ or ‘Play/Pause.’ Just like that, no more accidental chats with Siri through your AirPods.
If you’re feeling extra serious about tuning out Siri altogether, you can even turn off that “Hey Siri” command. Pop back to the main Settings menu, scroll to ‘Siri & Search,’ and flip off ‘Listen for “Hey Siri”’ along with any other Siri options you see.
Quick recap: To ditch Siri on your AirPods, just swap the Siri action for something else in Bluetooth settings, and maybe disable “Hey Siri” too if you’re all-in.
Hopefully, this helps you regain control over your AirPods without those surprise Siri moments!
Alright, let’s talk about why you might want to switch off Siri on your AirPods. Ever been in the middle of a workout and suddenly Siri jumps in uninvited? It can be pretty irritating! Not to mention, you might be into keeping things private and prefer not having accidental voice commands running the show. Plus, let’s be real—turning off unnecessary features might help squeeze out a bit more battery life. These earbuds are sensitive to touch, so getting a handle on some settings can really make a difference.
Now, here’s how you can turn off Siri on your AirPods:
  1. First up—stopping Siri from getting triggered by your AirPods’ touch controls:
    • Here’s the skinny:
      • Grab your iPhone or iPad and open up the Settings app.
      • Look for Bluetooth, then tap the ℹ️ icon next to your AirPods.
      • Check out the settings under Press and Hold AirPods. Pick either Left or Right—whichever earbud tends to wake up Siri.
      • Swap out Siri for Noise Control or just turn it Off.
    • Quick tip: This way, you can dodge Siri but still hang onto some cool features like noise control.
  2. Moving on—how about nixing Siri altogether on your iOS device:
    • Here’s what you do:
      • Head over to Settings > Siri & Search.
      • Flip off the switches for Listen for “Hey Siri” and Press Side Button for Siri (or Press Home Button for Siri if you’re rocking an older iPhone).
    • Doing this seals the deal, disabling Siri across everything tied to your AirPods. No more accidental chitchats with Siri!
Some other stuff to keep in mind:
  • With AirPods Pro (2nd Gen), double-check that your Press and Hold duration isn’t set to wake up Siri. Find this in Bluetooth > AirPods Settings.
  • Stuck on an outdated iOS? Jump into Settings > General > Software Update to make sure you’ve got the latest version. Keeps those settings straight!
  • If all else fails, a good ol’ reset might help. Hold down the setup button on the case for 15 seconds and try pairing them up again.
Want Siri back in action? No problem. Switching it on is a breeze:
  1. Just run through the steps and select Siri under Press and Hold AirPods.
  2. Head back to Settings > Siri & Search to flick the switches back on.
Adjusting these settings can make using your AirPods way more pleasant. Tailor it to your vibe and keep those accidental interruptions in check!
Alright, let’s get those Siri functions off your AirPods. It’s actually simpler than you might think!
Option 1: Turning Off “Hey Siri” for AirPods Pro and AirPods 2nd Gen and later
  • Hit Up Settings: Grab your iPhone and pop open the “Settings” app.
  • Swipe to Siri & Search: Find and tap “Siri & Search.”
  • Bye Bye “Hey Siri”: Just flick the switch next to “Listen for ‘Hey Siri'” to nix the voice trigger feature for your AirPods. Easy peasy.
Option 2: Adjusting Siri from AirPods Settings
  • Dive into Bluetooth Settings: Head over to “Settings” and tap on “Bluetooth.”
  • Find Your Buds: Locate your AirPods under “My Devices” and tap the little “i” next to them.
  • Tweak the Double-Tap/Press Actions:
    • For AirPods 1st/2nd Gen: Check out “Double-Tap on AirPod,” and go ahead and switch the setting to “Off” or something else like “Play/Pause.”
    • For AirPods Pro/3rd Gen: Under “Press and Hold AirPods,” switch up the setting from “Siri” to “Noise Control” or just turn it off.
Option 3: Ditch Siri Announcements on AirPods
  • Open Notifications Settings: Get into “Settings” then tap on “Notifications.”
  • Find Announce Notifications: Scroll around and tap “Announce Notifications.”
  • Switch Off Announcements: Flick off the switch next to “Announce Notifications,” or if you prefer, just pick which apps Siri should keep quiet about.
So there you have it! Tweaking Siri settings on your AirPods isn’t rocket science, right? If you’re looking for more details or run into hiccups, you can always peek at Apple’s official support page. There’s loads more info there.
—Your Go-to Guide in the Crunch
