How Do I Get Rid of Siri Suggestions on My iPhone?
498 viewsPhone
All right, so you’re fed up with those Siri suggestions popping up everywhere, huh? Let’s dive into the settings and show Siri who’s boss. Here we go:
First things first, head over to the ‘Settings’ app. Just swipe through your home screen until you spot it—easy peasy!
Once you’re in there, hunt down the ‘Siri & Search’ section. You might need to scroll a bit, but you’ll find it eventually. Tap it and let’s roll.
Now, you’re looking at a bunch of toggle switches under ‘Suggestions From Apple’ and ‘Content From Apple.’ If you wanna ditch the suggestions altogether, just flip those suckers off. You’ve got stuff like ‘Allow Notifications,’ ‘Show in App Library,’ ‘Show When Sharing,’ and ‘Show When Listening’—zap them as you see fit!
But hold on, maybe you don’t wanna blanket-ban Siri across all apps. Totally fair. Scroll down, and you’ll see a lineup of apps. Tap on one to fiddle with its specific settings and turn off bits like ‘Show on Home Screen,’ ‘Suggest App,’ and ‘Suggestion Notifications.’ Customize to your heart’s content.
If you’re really going hardcore, turn off ‘Learn from this App’ on each app’s settings to make sure Siri completely forgets about your likes/dislikes. It’s like tossing out your diary!
Here’s the kicker: Go ahead and check settings for your Lock Screen and search. Sometimes Siri sneaks in suggestions there too.
After you’ve tweaked these settings, you should have a lot less Siri pokey-pokey in your life. Keeping this thing from knowing about your habits is like getting a fresh start. Good luck!
Want to turn off Siri Suggestions on your Apple devices? Let’s break it down into a few simple steps tailored to each device:
1. Shutting Down Siri Suggestions on iOS/iPadOS:
So, first thing’s first, grab your device and head over to Settings, then tap on Siri & Search. Here’s what you need to do:
  • Flick off these options under Siri Suggestions:
    • Show Suggestions (on your lock screen and search)
    • Show Content in Search (suggestions specific to apps)
    • Suggestions When Sharing (for those contact recommendations)
Want to tackle specific apps? Scroll down to the app you’re thinking of (let’s say, Messages or Mail) and turn off Show Siri Suggestions and Learn from this App.
2. Removing Home Screen Widgets:
Those widgets bothering you? Just press and hold the Siri Suggestions widget and tap Remove Widget. Confirm it, and poof, it’s gone.
3. Shutting Down Location-Based Suggestions:
Go to Settings, jump into Privacy & Security, then Location Services. Tap on System Services and toggle off Location-Based Suggestions.
4. Wiping Siri’s Memory Clean:
If Siri’s got too much info, go back to Settings, select Siri & Search, then Siri & Dictation History. Hit Delete Siri & Dictation History to clear it all.
5. Managing Siri on Your Apple Watch:
Open the Watch app on your iPhone, hit Siri, and dive into Suggestions. Switch off all those suggestion types you don’t want.
6. Tweaking MacOS Settings:
Open System Settings and go to Siri & Spotlight. Here, you’ll want to disable:
  • Show Siri Suggestions in Spotlight
  • Show Siri Suggestions in Look Up
  • Suggestions in App Library
7. Tuning Out Search Suggestions:
In Spotlight Search (just swipe down on your home screen), scroll all the way down and tap Turn Off Suggestions.
Some Handy Tips if Stuff Still Pops Up:
  • If suggestions keep bugging you after disabling, try giving your device a restart.
  • Make sure your iOS is updated to the latest version if things look a bit different.
  • For those stubborn app-specific suggestions, dive into each app’s settings under Siri & Search.
Other Ways to Keep Siri Quiet:
  • Utilize Screen Time settings to limit what Siri can do.
  • Set up Focus modes if you want to silence suggestions during certain activities.
  • Another trick: turn off ‘Suggest Shortcuts’ in the Shortcuts app settings.
Just Some Background Info:
Siri Suggestions are powered by on-device machine learning, and they guess what you might need based on how you use your device. Saying goodbye to these features might change things like predictive text in Messages or Mail app. To really turn it off, you’ll need to tweak several settings here and there rather than a one-click fix.
Want to get rid of those Siri Suggestions popping up everywhere on your iPhone? Let’s break it down:
Shutting Down Siri Suggestions:
  1. Head Into Settings:
    Pop into the Settings app on your phone.
  2. Find Siri & Search:
    Scroll and tap on Siri & Search.
  3. Flip the Switch:
    You’ll see options for Suggestions in Search, Suggestions in Look Up, and Suggestions on Lock Screen. Flick those switches off, and you’re good to go. No more unwanted tips from Siri!
Target Specific Apps:
  1. Pick Your App:
    While you’re still in Siri & Search, scroll to find your app list.
  2. Zero in an App:
    Tap on the app that’s been bugging you with suggestions.
  3. Shut It Down:
    Toggle off Learn from this App and Show Siri Suggestions. Do this for any app cramping your style.
Wipe Siri’s Memory:
  1. Dive Back Into Settings:
    Hit up Settings, then Siri & Search once more.
  2. Swipe Away History:
    Opt for Siri & Dictation History and choose Delete Siri & Dictation History to clear out past suggestions.
Do all these steps, and you’ll enjoy a tidier, more tailored experience on your iPhone. Got questions? You can always check out Apple’s Support page on Siri Suggestions.
