What’s the Easiest Way to Tell What Type of Kindle I Have?
641 viewsEbook
Below is an article in English about how to determine the type of Kindle you have:
How to Identify Your Kindle Model
Since the first Kindle debuted in 2007, Amazon has put out a ton of different models. A lot of us get confused about which one we actually own. Figuring out what type you have is super useful for getting the right accessories, firmware updates, and making sure everything works as it should. Here’s how you can nail down which Kindle version you have.
Checking the Device for Model Information
  • Model Number on the Device: Most Kindles have a model number printed somewhere on the back or bottom. If you spot something like “MODEL NO. XXX,” a quick online search will tell you exactly what it is.
  • Serial Number in Settings: Turn on your Kindle, head to the home screen, tap the gear icon in the top-right corner, and dive into the settings. Tap on “Device Options” and then “Device Info” to find your serial number and model name. The serial number’s prefix might just give it away. For instance, “G001LG” or “G001PX” points to a Kindle Paperwhite 5 (2021).
Checking the Packaging or Documentation
If you still have the original package or the manual, you’re in luck. The model name and number are usually plastered somewhere on there.
Identifying by Appearance
  • Kindle Oasis: This one’s a dead giveaway with its premium design and those physical page-turn buttons on the side. Look out for the warm light feature on the Oasis 3 (2019) that the Oasis 2 (2017) doesn’t have. The Kindle Scribe (2022) might look familiar but has a chunky bezel on the left and a USB-C port; it’s also built for screen writing.
  • Kindle Paperwhite: Several generations of this one exist. The Paperwhite 5 (2021) has a black Amazon swoosh on the back and “Kindle” in white letters on the front, while the Paperwhite 4 looks similar but without warm light. The Paperwhite 3 (2015) sports a black “Kindle” logo on the front, and the older Paperwhite 2 (2013) has a black Amazon logo on the back. The OG Paperwhite (2012) has a big “Kindle” logo on the back.
  • Kindle Voyage: This one’s the thinnest Kindle, measuring just 7.6mm, with soft-touch page-turn buttons. Its distinctive look makes it easy to spot.
  • Kindle Basic: Early versions of this humble gadget have a full keyboard at the bottom. The 7th-gen Kindle Basic (2014) has a white “Kindle” logo on the front, while the 8th-gen Kindle Basic 2 (2016) shows off a black Amazon logo on the back. The 10th-gen Kindle Basic 3 (2019) features the Amazon arrow without the “Amazon” text. The latest 11th-gen Kindle Basic 4 (2022) mimics the Paperwhite 5 but with a smaller display and matching text coloring.
Checking Your Amazon Account
Head to your Amazon account on a computer or your phone, go to “Manage Your Content and Devices,” and find your Kindle. Click on it, and you’ll get all the juicy info about your device, including the model name and number.
Searching Online for Model Identification
If none of the above works, snap some photos of your Kindle and compare them to images online. Plenty of websites offer visual guides for this kind of thing. Online forums and Kindle communities are also goldmines for tips and model identification help.
Knowing your Kindle model lets you buy the right stuff, keep your software fresh, and troubleshoot like a pro. Use these tips to figure out your Kindle model and enjoy your device to the fullest.
Is there anything else I can help you with?
Trying to figure out what type of Kindle you’ve got in your hands? You’re not alone—it’s not always obvious! Here are a few super handy tricks that’ll help you uncover your Kindle’s true identity.
First up, did you know there’s a quick and easy way to check the model directly on the device? If your Kindle’s strutting version 5.14 or later, you can dive into the Device Info section in the settings. Here’s how to unravel this mystery:
  • Dig into Settings: Tap those three little dots hanging out in the top corner of your screen.
  • Device Options Are Your Friend: Head over to “Settings,” then hit up “Device Options.”
  • Unlock Device Info: There’s a “Device Info” button—hit it, and voilà! You’re staring at your Kindle’s model name and number.
Now, if you’re pinched for info or dealing with a stubborn old Kindle model, you’ve still got options. Try snooping around your Amazon account:
  • Log In Like a Boss: Hop onto Amazon and slide into your account.
  • Peek at Your Devices: Find the “Devices” tab at the top—it’s your golden ticket.
  • Locate Your Kindle: Your Kindle should be chilling in the list of connected devices. Click on it and bask in the details.
Oh, let me tell you—the serial number can spill the beans too. Here’s the scoop:
  • Grab the Serial Number: Go into “Settings,” then “Device Options,” hit up “Device Info,” and your serial number’s right there.
  • Back Check: If all else fails, flip your Kindle over—that model number might be gracing its backside.
  • Surf Online: Armed with your serial or model number, stroll over to online charts to match up with your Kindle type.
Here comes the fun bit: sizing up your Kindle’s physical traits. If you’ve got the knack for sniffing out details, look at:
  • Shape, size, button layout, you name it, each Kindle has its own swagger.
  • For instance:
    • The Kindle Paperwhite 6 (2024) sports a softer finish and smooth edges.
    • The Kindle Oasis 3 is all about that warm light feature for cozy nighttime reads.
Trust me, comparing these attributes with shots online is your visual guide to cracking the case.
In a nutshell, pinpointing your Kindle model can be a piece of cake—once you know where to look. Device Info is your best bet, but your Amazon account and serial number detective work aren’t too shabby either.
Figuring out what kind of Kindle you have doesn’t have to be a headache. Here’s how you can nail down which model you’re holding:
First up, dive into your Kindle’s settings. That’s your quickest bet for pinpointing your model. For devices made from 2016 onwards, just head to Settings, then Device Options, and tap on Device Info. You’ll see the magic words like “Kindle Paperwhite (11th Generation)” pop up. If your Kindle is older (we’re talking before 2016), check under Settings and poke around for anything saying “Device Info.” Terms like “Kindle Keyboard” or “Kindle Touch” should give you a good clue about what you’re dealing with.
Now, let’s move on to physical features. Amazon’s Kindles come in all sorts of flavors with distinctive designs. If your Kindle doesn’t mind a splash of water, you might have the Paperwhite or Oasis. They have larger screens and more crisp displays than their basic cousin, which is a no-brainer for bookworms who love reading by the pool. If there are buttons to help you turn pages physically, chances are, you’ve got an Oasis.
Don’t forget the importance of the serial number—a nerdy, but useful trick. You can check for it either on the device at Settings, Device Info or hop onto your Amazon account, run over to the Devices tab, and check the details there. Sometimes the serial number can tell you quite a bit about your Kindle, so it’s worth a look. Just don’t go posting it online; you want to keep that private!
The original box can also be a treasure trove of clues. Look for any labels or descriptions that hint at what’s inside. And if you’re still scratching your head, check your firmware version in the settings and match it to an Amazon timeline to get a rough idea of when your Kindle first hit the shelves.
If all else fails or nothing matches up exactly, don’t lose hope. Try comparing features like the screen size or the charging port type. USB-C means you’ve got one of the newer kids on the block. If you’re still stumped, maybe a quick call to Amazon support with your serial number can clear things up.
So, don’t sweat it. By following these tips, you should be able to pin down what Kindle model you have in no time!
Hey, have a Kindle and can’t quite pin down its model? No worries, let’s get to the bottom of it.
Check Out the Settings:
Pop over to the device’s menu from the home screen. Tap on ‘Settings,’ then look for ‘Device Info’ or ‘Device Options.’ That’s where your Kindle model hides out with its serial number.
Sniff Out the Serial Number:
The opening characters of your serial number are a dead giveaway for your Kindle’s identity. You’ll find it either in the settings or on the back somewhere. Do a quick Google search with those numbers, or head over to Amazon’s support page for a proper ID.
Give It a Once-Over:
Kindles have their quirks—screen sizes, button layouts, and what’s printed on the back. Check these out and match them with the pictures and descriptions from Amazon or tech blogs.
Peek Into Your Amazon Account:
Log in and cruise over to ‘Manage Your Content and Devices.’ Click on ‘Devices’ to find the scoop on your Kindle, even the model name.
Hit Up Amazon Support:
If all else fails, Amazon’s customer service is pretty solid. They’ve got a guide called ‘Identify Your Kindle E-Reader’ that’s worth checking out.
These should help you nail down which Kindle you’ve got. Dive into Amazon’s official support, or snoop around some trusted tech sites for more juicy details.
