How Can I Find My Wi-Fi Password on My Phone?
340 viewsPhone
When you need to see your Wi-Fi password on your phone, it may be because you want to connect another device to the network but have forgotten the password, or you need to share the password with someone else. Here are the methods to view the Wi-Fi password on different devices:
For Android devices
  • Android 10 and above:
    • Open the Settings app, go to Network & Internet, and tap Wi-Fi.
    • Look for the Wi-Fi network you are currently connected to or the one you want to view the password for, and tap the gear icon next to it.
    • In the Wi-Fi network settings, tap the Share option. You may need to authenticate using your fingerprint, pattern, or PIN.
    • After authentication, a QR code will appear, and below or next to the QR code, the Wi-Fi password will be displayed in plain text.
  • Android 9 and below (non-rooted devices):
    • You can use Google Lens to scan a shared QR code. Launch the Google Lens app or select the Lens icon within the Google app or its home screen widget.
    • Choose an image from your gallery that contains the QR code or opt for “Search with your camera”. Point the camera towards the QR code and press the shutter button. If necessary, adjust the crop to extend beyond the edges of the QR code. Access the results to view the plain text password.
  • Android 4.4 to Android 9 (rooted devices):
    • Make sure your device has root access, like with Magisk. Install a root-enabled file explorer like Root Explorer or ES File Explorer.
    • Open the file manager app, grant root permissions when prompted, and go to the /data/misc/wifi directory.
    • Open the wpa_supplicant.conf file. You’ll see sections like network={ssid="YOUR_SSID" psk="YOUR_PASSWORD"}. Find your network’s SSID, and the password will be listed next to psk=.
  • Using ADB Command (Android Debug Bridge):
    • Enable Developer Options by going to Settings > About Phone and tapping on the Build Number seven times. Then, in Settings, go to Developer Options and enable USB Debugging.
    • Install ADB on your computer from the Android Developer’s website by downloading the Platform Tools.
    • Connect your Android device to your computer using a USB cable. Open a command prompt/terminal window on your computer and type adb devices to make sure your device is recognized.
    • Type the command adb pull /data/misc/wifi/wpa_supplicant.conf to access your device’s Wi-Fi configuration files. This will download the file to your computer. Open the wpa_supplicant.conf file in a text editor and search for your Wi-Fi network name (SSID). The password will be listed next to psk=.
For iOS devices
  • iOS 16 and above:
    • Open the Settings app and go to Wi-Fi.
    • Next to the network you are currently connected to (or any saved network), tap the small “i” icon.
    • Tap on Password. You’ll be asked to use Face ID, Touch ID, or your passcode to view the password.
    • After successful authentication, the Wi-Fi password will be revealed.
Other methods
  • Via QR code scanner:
    • If you have a QR code for the Wi-Fi network, you can use a QR code scanner on either Android or iOS to connect automatically or potentially reveal the password within the QR code data. Most modern Android phones have a built-in QR code scanner in the camera app. On iOS, the Camera app also scans QR codes automatically. Alternatively, you can download a dedicated QR code scanner app from the App Store (iOS) or Google Play Store (Android).
    • Open the QR code scanner and point your camera at the Wi-Fi network’s QR code. Sometimes, scanning the QR code will immediately prompt you to connect to the Wi-Fi network. Other times, the app might display the underlying data encoded in the QR code, which could include the Wi-Fi password. However, the password is not always readily displayed so this method can be hit-or-miss.
  • Checking router settings:
    • Find your router’s IP address, which is usually something like 192.168.0.1 or 192.168.1.1. This can usually be found by tapping the “i” or information icon next to your Wi-Fi network on any connected device.
    • Open a web browser and enter the router’s IP address in the address bar.
    • Log in using the router’s administrative username and password. If you haven’t changed these, they may still be set to the default values, which can sometimes be found on the router itself, in the manual, or through various online resources.
    • Find the Wi-Fi settings section, and you should be able to see or reveal the current Wi-Fi password.
Keep in mind that for some Android devices, like Samsung phones, even with Android 10 or higher, the password may remain hidden and only the QR code will be displayed. Rooting your Android device can void warranties and pose security risks, so proceed with caution and ensure you really need to retrieve the password. And when using third-party apps, always download from reputable sources and check user reviews to avoid malware or privacy threats.
Want to dig up your Wi-Fi password on your phone? Let’s break it down for iPhone and Android users.
Getting Your Wi-Fi Password on an iPhone:
  • Open Settings: Start by tapping the Settings app—it’s your gateway to the magic.
  • Head to Wi-Fi: Once you’re in Settings, hit up “Wi-Fi” to see what’s in your neck of the woods.
  • Check Your Network: Snag the Wi-Fi network you’re hooked up to, then tap that sneaky “i” in a circle next to it.
  • Reveal Password: Find the “Password” field, tap it, and pow! You’ll need your passcode, Face ID, or Touch ID to unlock the treasure. Once you’re in, the password will appear right before you.
  • Snooping on Old Networks: Want to dig into networks you’ve connected to before? Hit “Edit” in the Wi-Fi settings’ top corner and authenticate yourself again. Tap the info icon by any network and follow the previous routine to see its password.
Hunting Down Your Wi-Fi Password on Android:
  • Open Settings: Swipe up your home screen or app drawer to access Settings.
  • Dive into Network & Internet: Tap “Network & Internet,” then hit up “Internet.”
  • Pick Your Network: Spot your connected Wi-Fi network, and tap to continue.
  • Hit Share: Look for a share option—it might show as a QR code icon. Click it.
  • Pass the Security Check: Use your fingerprint, face recognition, or PIN.
After that, a QR code pops up with the password sitting right below.
  • Checking Past Networks (Android 10 and up): If you want passwords from old networks, head back to “Network & Internet.” Select “Saved Networks,” choose a network from this list, and repeat the steps.
And that’s about it, folks! With these steps, you’ll crack the code to your Wi-Fi password fiasco without chasing after routers or digging through manuals.
Alright, if you’re trying to dig up that elusive Wi-Fi password on your phone, here’s the scoop. How you do it kinda depends on whether you’re rocking an Android or iPhone, and also what version of the software you’ve got running on your device. So, let’s break it down.
First up, Android users—this one’s for you! Android doesn’t make it easy to view saved Wi-Fi passwords, and that’s really just about keeping things secure. But hey, there are a few ways around it, depending on what phone you’re using, whether it’s rooted, and other nitty-gritty details.
For those using Android 10 or later, there’s a nifty little sharing feature you can use if you’re already connected to the network. Just head over to Settings, tap Network & Internet, find Wi-Fi, and give it a click. You’ll see the network you’re on—tap to share it and voila, a QR code pops up. Sometimes, the Wi-Fi password is lurking right below in teeny-tiny text, so you might need to zoom in or whip out those glasses.
Now, if you’ve got a rooted phone and want to dig a bit deeper, you can use a file explorer app like Solid Explorer. Navigate your way to /data/misc/wifi, then open up the wpa_supplicant.conf file. Look for your network’s name (SSID) and spot the password next to the psk= line.
Feeling adventurous but don’t want to root your device? Try third-party apps like Wi-Fi Password Viewer. But heads up, you’ll need to tinker with Developer Options a bit—kind of like unlocking the hidden features of your phone.
If all else fails, check your router’s admin panel settings. Once connected to the network, find the router’s IP address under Wi-Fi settings and pull it up in your browser. Use the admin login info from the router sticker, then find your way to the Wireless Settings to see the password.
What about iPhone users? Apple keeps things pretty locked down, but don’t worry, there are ways through the maze. If you’ve got other Apple devices connected via iCloud Keychain, it’s gonna make life easier. For example, you can use iCloud Keychain on a Mac to peek at your Wi-Fi network details and hunt down the password.
Alternatively, with iOS 16 or later, you can use another device that’s linked to the network to help you out. Just tap the info icon in Wi-Fi settings, hit Password, and let Face ID or Touch ID do their thing to reveal it.
Sometimes you have to reset your network settings to get back on track, but be warned—it clears out all saved Wi-Fi passwords from memory. Just go to Settings, then General, followed by Transfer or Reset iPhone, and finally Reset Network Settings. You’ll need to plug in the password again to reconnect, though, so hope you’ve got it stashed somewhere safe.
One last twist, if neither side will yield, don’t sweat it too much. You can always check your router’s admin interface, reset to factory settings, or ping your ISP for help. Sometimes they’re your best bet for a quick fix.
Whew! That’s the rundown for Android and iOS. Hope you find it handy when you can’t remember where you stashed that Wi-Fi password!
Wondering how to peek at your Wi-Fi password right from your phone? Here’s the lowdown on making that happen, whether you’re rocking an Android or an iPhone:
For Android Lovers:
  • Hit Up Settings: First thing’s first, open up that trusty Settings app on your Android device.
  • Find Your Net Stuff: Scroll or swipe to “Network & Internet” or “Connections”—depends on what kind of phone you’ve got.
  • Get on Wi-Fi: Tap “Wi-Fi” and make sure you’re actually connected to the network you’re curious about.
  • Dive Into Details: Tap on that network’s name—you’re going behind the scenes now.
  • Share the Love: Look for a “Share” option, or maybe a QR code button in the extra settings.
  • See It in Text: That QR code they spit out? Scan it with a QR code app or whatever you’ve baked into your phone, and voilà—there’s the password.
For the Apple Fans:
  • Settings Shenanigans: Pop open the Settings app on your iPhone.
  • Wi-Fi Dive: Tap “Wi-Fi” and find the network you’re chilling on.
  • Keychain Magic: Using iOS 16 or newer and iCloud Keychain is key.
    • Dive into “Settings” and tap “Passwords.”
    • Do your Face ID, Touch ID, or passcode thing.
    • Hunt down that network name in the list.
    • Tap to see that well-kept secret—the password.
Here’s the kicker though, the methods can be a bit wonky depending on your device and software jazz. Also, keep things legit and respectful privacy-wise, okay?
This little guide should help most folks, be they iPhone or Android, crack the Wi-Fi password mystery without too much hassle.
