How Can I Fix the Bad System Config Info Error on Windows 10?
339 viewsComputer
So, you\’ve run into the \”BAD SYSTEM CONFIG INFO\” error on Windows 10. It\’s that dreaded blue screen that keeps your computer from booting up properly and might have you pulling hair out in frustration. This usually means something\’s messed up with system files, the registry, or boot settings. Let\’s break it down and see what you can do to fix it.
What\’s Causing the Trouble?
We\’ve got a few usual suspects here:
  1. Corrupted System Files: Your system could have caught a bug from a sudden power outage or an unexpected shutdown. It happens and can lead to this error.
  2. Messed-up Registry: The registry is kinda like Windows\’ brain. If any of those files go haywire, especially in the System32\\Config folder, you\’re in for a bad time.
  3. Boot Configuration Hiccup: If Windows can’t get its boot act together because of a BCD glitch, it’s a big deal.
Let’s Get This Fixed!
Here’s how you can tackle the problem:
Method 1: System File Checker (SFC) Scan
Start here. You can run a quick scan and hopefully get those corrupted files in line.
  1. Go ahead and boot from any Windows installation media, then hit that \’Repair your computer\’ option.
  2. Head to Troubleshoot > Advanced Options > Command Prompt.
  3. Type sfc /scannow and press Enter.
  4. Let it do its thing and cross your fingers as you restart your machine after.
Method 2: Restore Registry Files
If the registry is your culprit, try restoring its files:
  1. Access Command Prompt via recovery options.
  2. Copy and paste each of the following:
  c: cd Windows\\System32\\Config\\RegBack dir copy DEFAULT c:\\Windows\\System32\\Config copy SAM c:\\Windows\\System32\\Config copy SECURITY c:\\Windows\\System32\\Config copy SOFTWARE c:\\Windows\\System32\\Config copy SYSTEM c:\\Windows\\System32\\Config
If it asks to overwrite, just say yes.
Method 3: Repair Boot Configuration
Try this if you suspect boot misconfigurations:
  1. Hit up the Command Prompt in the recovery menu.
  2. Enter these commands:
  bootrec /repairbcd bootrec /fixmbr bootrec /fixboot
If it\’s still a mess, you might need a complete rebuild:
  bcdedit /export C:\\BCD_Backup ren c:\\boot\\bcd bcd.old bootrec /rebuildbcd
Method 4: Windows PE to the Rescue
This one\’s for when nothing else works:
  1. Make yourself a Windows PE USB.
  2. Boot into PE, find your way to Windows\\System32\\Config.
  3. Replace the bad files with the ones from RegBack.
Method 5: Last-Ditch Effort – System Reset or Reinstall
If all else fails, consider this:
  1. Use your Windows installation media to either reset the system (and keep files if you can) or go for a clean install.
Keeping Out of Trouble
Once you’re back in action, prevent future headaches by:
  • Making restore points before you shake up the system.
  • Properly shutting down your computer—no sudden unplugging.
  • Regular backups. Trust me; they’re lifesavers.
  • A UPS could save you from power-related catastrophes.
Now, it really depends on what caused the mess in the first place. Just start with the simple stuff like the SFC scan, and work your way down the list until it’s sorted out.
Alright folks, let\’s tackle this Bad System Config Info issue on Windows 10. This pesky error, which goes by the fancy stop code 0x00000074, often pops up because of system files gone awry, dodgy registry settings, or even some cranky hardware. But don\’t sweat it. We\’ve got a bunch of tricks up our sleeve to help you sort it out.
First things first, try a good old restart and make sure your hardware is snugly connected. You\’d be amazed at what a simple reboot can do. Just shut down, unplug everything, give it a moment, and then plug it all back in. Fingers crossed, that might do the trick!
If not, let\’s dig a bit deeper. Corrupt system files could be the culprits here. Fire up Command Prompt as an admin and type in sfc /scannow to let the System File Checker tool weave its magic. This might take a little time. Be patient!
And while you\’re at it, run CHKDSK to catch any naughty errors on your drive. In the same Command Prompt window, type chkdsk C: /r and let it do its thing. It might uncover some gremlins lurking in the disk.
Next up: the DISM tool. Kind of like a health check for your Windows image. Type DISM.exe /Online /Cleanup-image /Restorehealth and sit back. It\’s a bit like a doctor\’s visit for your PC—probably takes some time, but worth it for peace of mind.
Sometimes, this snag is sitting in the registry. If you have a registry backup (check under C:\\Windows\\System32\\config\\RegBack), you can restore it. Or, for a quick fix, see if a System Restore can bounce things back to normal.
And hey, if all else fails, you might need to reset Windows or kick out some recent updates. Boot into the Windows Recovery Environment (WinRE) and head over to Troubleshoot > Advanced Options. Choose Reset this PC to save your files, or Uninstall Updates if they’re the troublemakers.
For those wanting to dive into boot repairs, whip out your Windows installation media and hit those bootrec commands: /fixmbr, /fixboot, and then /repairbcd. They can really straighten out any boot-related hassles.
Finally, if you\’re still stranded, let Startup Repair take a swing at it. Navigate through WinRE to Troubleshoot > Advanced Options > Startup Repair, and voila, let it have a go.
So there you have it—multiple ways to kick that Bad System Config Info error to the curb. Try these steps, one at a time, and let\’s get your PC humming again!
So, you’ve run into that pesky “Bad System Config Info” error on Windows 10, huh? It’s often a Blue Screen of Death (BSOD) bugbear, but don’t sweat it—there are some ways to tackle it head-on.
  1. Hop into Safe Mode:
    Start by restarting your PC and quickly hit F8 or Shift + F8 to open up Advanced Boot Options. Once you’re in, go for Safe Mode—it’s a trusty starting point.
  2. Play Fix-It with SFC and DISM:
    Inside Safe Mode, crack open the Command Prompt with Admin rights. Type sfc /scannow and let it do its thing. After that, run these commands in sequence, hitting Enter after each one:
    • DISM /Online /Cleanup-Image /ScanHealth
    • DISM /Online /Cleanup-Image /RestoreHealth
  3. Patching Up BCD:
    Get to the Command Prompt via the Windows Recovery Environment (winRE). Then, punch in these commands, pressing Enter each time:
    • bootrec /repairbcd
    • bootrec /osscan
    • bootrec /repairmbr
  4. Driver Check-Up:
    In Safe Mode, head over to Device Manager by right-clicking Start. Peek into each category for any recent driver shenanigans—right-click the suspect and either hit Update driver or Roll back driver.
  5. Give RAM a Pat Down:
    Check if those RAM sticks are snuggly fit in their slots. If you think one might be the troublemaker, test ’em one by one to figure out if any hardware’s misbehaving.
  6. Go Retro with System Restore:
    Still stuck? You might want to roll things back using System Restore through winRE—this can undo whatever ruffled Windows in the first place.
With a bit of luck, one of these maneuvers should do the trick! And if all else fails, calling in backup from a tech expert could save you some headaches.
